Old 21-04-2010, 09:25 PM   #1 (permalink)
meetdenis's Avatar
Exclamation DVD drive doesn't play Digit DVDs
I am a Digit subscriber.
I have an LG DVD writer drive. I have been using it since two years.
In Dec 2009, I upgraded my system and ever since, the DVD drive refuses to run any of the Digit DVDs.
I am quite at my wits end trying to solve the prob.
I know the problem does not lie with the DVD drive as it loads other DVDs and CDs fine.
I am using Win XP SP3 with a resolution of 1024 x 768.
My config is as follows -
2 x 1GB @ 800 MHz Kingston RAM
Cooler Master 460W PSU
Gigabyte GA-EP45-UD3L
C2D E7400 2.8 Ghz
ZOTAC GTX 260
Can any one please help me to solve this problem?
meetdenis is offline
Old 22-04-2010, 12:10 AM   #2 (permalink)
walkmanguru's Avatar
Default Re: DVD drive doesn't play Digit DVDs
Your DVD drive is not compatible with Dual-Layer DVD
walkmanguru is offline
Old 22-04-2010, 04:06 PM   #3 (permalink)
Kindly check your optical drive using Dual-Layer DVDs (8.4GB)
The Digit DVDs are dual-layer media hence try with some other brand/make.
let us all see the "i" in the "u".
insaneYLN is offline
Old 22-04-2010, 04:48 PM   #4 (permalink)
Get a new DVD Drive
it's not compatible
Aspire is offline
Old 23-04-2010, 09:21 PM   #5 (permalink)
meetdenis's Avatar
Quite possible.
...but my drive ran Digit DVDs prior to Dec 09 i.e. before I upgraded. Digit DVDs have been dual layered ones since much before that, I guess.
Also, could you recommend a good, inexpensive DVD writer?
Old 23-04-2010, 09:33 PM   #6 (permalink)
BE FREE
lg/hp - 1.1k.
"To know that we know what we know, and to know that we do not know what we do not know, that is true knowledge." ~ Copernicus
azaad_shri75 is offline
Latest Hardware Prices & Quotes..!! suave_guy Hardware Q&A 5604 14-03-2011 02:05 PM
Backup Carriers DVD within 5 Minutes bigit Software Q&A 0 22-02-2010 12:15 PM
WinX DVD Author the best tool to Personalized DVD from Your Own Video in Clicks bigit Random News 2 21-06-2007 01:15 PM
- by c4u
