Old 20-04-2010, 01:45 PM   #1 (permalink)
Default Need help in making a choice over peripherals
Hi,
I'm planning to add/upgrade some of my peripherals of my pc. Please give a few suggestions.
1. Monitor: Suggest some good 20" lcds within rs7500. I'll be sitting 2.5-3m from the screen while watching movies; i don't have any hd content, just dvd quality - so i guess 22" is not a good option. I'll also be doing graphic design, programming and net surfing.
---------- Post added at 01:45 PM ---------- Previous post was at 01:20 PM ----------
I cannot edit or delete my post.. Help! When i try to edit it the original post disappears, only whatever i write in the msg box is displayed.. Can anyone help me?
eruku.ade is offline
Old 20-04-2010, 08:24 PM   #2 (permalink)
Pro/An---tagonist xD
Default Re: Need help in making a choice over peripherals
Check the price of the Benq G2200HD.M not sure whether it is 9k or 7.5k.
Its 22 inch btw.
Amd athlon II X3 435 unlocked to Phenom II X4 B35 8-) | MSI 785 G-E53 | Corsair Vengeance 4GB DDR3 RAM @ 1600 Mhz| Seagate 500 gb 7200.12|
Jripper is offline
Old 20-04-2010, 09:54 PM   #3 (permalink)
...contd
2. HDD: 50GB fits my req. Budget rs2500. My choice WD cavier blue and Seagate Barracuda 7200.12. Which is better?
Old 20-04-2010, 10:06 PM   #4 (permalink)
bORn To RIse....
rahul.007's Avatar
get:-
benq g2220hd lcd @ 7.6k
wd caviar blue @ 2.45k
phenom II 955 B.E 3.2 ghz(its hot) no more:mrgreen:|coolermaster hyper 212 evo:cool: | msi 790gx-g65|msi radeon hd6770:hyper: |corsair 2*2gb + kingston 2gb 1333mhz ddr3|seagate 500gb sata X 2, 1tb X 1|lg dvd|seasonic s12ii 520w:punch: |cooler master elite 310|cooler master 120 mm fans X 2|benq g2220 HD|logitech keyboard+mouse|Creative SBS A100|apc 550va|kodak c913|motorola fireXT:wink:
DO WHAT YOU THINK, BUT THINK BEFORE YOU DO.. :)
rahul.007 is offline
Old 20-04-2010, 10:06 PM   #5 (permalink)
...contd
3. Surround Speakers: Budget rs3500. I have selected creative inspire m5300 and t6100. Here i have a problem. According to my room measurements, the attached cables are short, so i have to extend them. Now i understand that t6100 has a different connector (not the standard rca) for the front right satellite. Is it possible to extend it? Else I'll go for the m5300. Also, does t6100 has a radically better sound quality than m5300? Any other suggestions?
Thanks
Old 21-04-2010, 12:33 PM   #6 (permalink)
50 GB?? :-O
You mean 500 right?
Jripper is offline
Old 21-04-2010, 03:57 PM   #7 (permalink)
Oh sorry, yes i mean 500gb.
(i was typing from my cell phone, so instead of a 0 a space went there by mistake)
any suggestion about the speakers?
---------- Post added at 03:57 PM ---------- Previous post was at 03:50 PM ----------
Old 21-04-2010, 09:23 PM   #8 (permalink)
bORn To RIse....
rahul.007's Avatar
no idea about speaker stuff....
How to Record Voice of a adjacent Room with Bluetooth enabled peripherals & Mobile jbohaj Mobiles and Tablets 2 16-04-2010 11:22 AM
Making Laptop a wifi hotspot spider Hardware Q&A 1 28-03-2010 10:10 PM
My P4 3.0 Ghz HT processor fan making heavy noise when playing flash games pulsar_swift Hardware Q&A 8 28-03-2010 08:54 AM
Recipe for making Maggi noodles crawwww Chit-Chat 21 25-02-2010 09:47 PM
Due Kernel I/O error, system refuses to boot randomly gary4gar Open Source 33 04-05-2008 10:22 AM
- by c4u
