Re: Power cut effect on external Hard disk
* Is there any effect of sudden power cut on the external hard disk ? I think the companies should have provided some protection against such abrupt power cuts.
yes,there will be some effect but that's very very rare, if power goes when the hard disk is full busy in writing data,there may be chance of getting bad sector.
better buy one ups to protect u r PC
* also i have not created any partition .will it effect the efficiency of HD. what should i do if i want to create a partition (without losing data). I have read Norton partition magic gives this option.
having 1 TB a single partition!. that's not recommended. atleast create 3 partitions to avoid single point of failure.
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
