17-04-2010, 10:10 PM
Who stole my Alpaca!
Will this SMPS do or do I need better?
Hi all,
Let me first quote what the system in question has running.
AMD Phenom X2 550 BE
2 GB of Ram
Asus M4A78-Em/1394
80 GB IDE Drive
80 GB Sata Drive
500 GB Sata Drive
LG DVD-RW
ViewSonic VA1918wm
iBall Cabinet with whatever 400 Watts SMPS came with it D: .
Well I have a 5670 1 Gb Card on its way and Im very curious as to whether ti will run on the current SMPS. My guess is it wont. However if it wont could you suggest me a SMPS which wouldn't burn a hole in my pocket please  .
Thanks in advance
18-04-2010, 12:29 AM
Re: Will this SMPS do or do I need better?
Originally Posted by FilledVoid
Hi all,
2 GB of Ram
Asus M4A78-Em/1394
80 GB IDE Drive
80 GB Sata Drive
500 GB Sata Drive
LG DVD-RW
ViewSonic VA1918wm
Thanks in advance
the graphics card will run provided you remove both your 8o Gb HDDs. & also lower the Vcore (proccy voltage) to about 1.2V. still i feel under load your PSU won't handle. may result in random shutdowns & down the line a few BANGs
ok so sasta PSU: VIP Gold 400W. no Zebronics please. little better is VIP Gold 500W or FSP Saga II 400W (if you prefer silence & white is your favorite colour). also FSP is more efficient & a tad bit costly
18-04-2010, 06:14 AM
Lol thanks . I'm not sure those will be available but I surely will check it out. Heres a list I could buy from possibly. Getting quality parts from Kerala is a pain so I think Ill buy online instead. Out of this listing which do you think would be a good choice
18-04-2010, 08:59 AM
15.0 GHz
go for Corsair VX Series if u have budget. or else Seasonic or Gigabyte is fine.
18-04-2010, 09:50 AM
Simply a DIGITian
+1 for Corsair VX450, Tagan, Seasonic are also good.
Don't look at CM Extreme Power Series, though Real Power Series would be fine.
- Read The Forum RULES First.
- Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
- Before Starting A New Thread Read The STICKY THREADS First
- Before Participating In Bazaar Section Read The BAZAAR RULES
18-04-2010, 12:10 PM
BLUE IS THE COLOUR
Where do you live in kerala? I am from Ernakulam and I am getting all the quality products here.They may not be be readily available in the stores.But if you order they will make it available for you.
Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|Realwatts Pro 500W|APC 650VA
18-04-2010, 01:32 PM
Thats the thing. Its never ever readily available. Its always a 1 week or more wait  . I can get anything I want as long as I wait that long lol.
18-04-2010, 09:16 PM
no problem. however you not mentioned any budget. so provided the bare minimum PSUs. however for your system you not need anything like Corsair VX450W, provided in future u wish do a full scale upgrade.
ok, my recommendation: CORSAIR CX400W. 5years warranty. your PC will die, but your PSU will still retain warranty. what u say? moreover pricing is like icing on cake
18-04-2010, 11:01 PM
That sounds great  . Ill see if I can put in a purchase or see if I can get one locally from my dealer. if my dealer has any other alternatives Ill post.
Question though. I have a basic cabinet, is the SMPS going to fit in it D: .
19-04-2010, 12:13 AM
Super Moderator
If you could measure the back panel dimensions, and map it to what the sites say, you should be good. Maximum, if the back gap fits, you might have incorrectly aligned screw holes. For that you can force-punch some holes. Should be fine. But just measure the back gap, and cross-reference it to the PSU you are interested in..!
21-04-2010, 10:08 PM
OK so my dealer finally restocked his wares and he now has two high end SMPS well actually three but Im ruling out one already.
1. Coolermaster 460W think its a regular one or Silent Pro series?
2. Prime
3. Coolermaster Extreme Power Series ( At this moment I'm avoiding this one)
Any idea on how the other two are?
21-04-2010, 11:38 PM
Super Moderator
1 = Fine.
2 = Never heard of.
3 = Plague (avoid it).
21-04-2010, 11:46 PM
2. Prime
well for your config, 400W Real Power will be enough. however Silent Pro will cost a bit more. Prime? whats that? looks like Prime ABGB started manufacturing their own PSU nowadays
well as i always say, gift your enemy the 3rd option (CM Extreme Power BOMB)
22-04-2010, 02:13 AM
I have a similar query. What should be the minimum wattage of the SMPS for the following config?
M/b: asus p5kpl-am/ps intel g31
cpu: intel p4 2.8ghz HT
ram: 3(1+2)gb ddr2 800mhz
gpu: sparkle geforce 8400gs 512mb
hdd: 80+500gb sata
dvd rw: lg sata
addl fans: 80mm (3)
tv tuner(optional)
22-04-2010, 08:53 AM
Thank you guys I appreciate the help much. Since the first is readily available Ill go with it. I haven't heard of Prime either btu it definitely costs alot D: . I will post the pictures when Im done .
Cheers.
22-04-2010, 05:33 PM
hdd: 80+500gb sata
dvd rw: lg sata
addl fans: 80mm (3)
tv tuner(optional)
Zebronics 450W sata will be enough. i'll suggest VIP 400W Gold @ 1.5k. will handle any future upgrade.
22-04-2010, 11:30 PM
Er Silly question perhaps but I just had to ask. Does the Asus EAH5670 1GB Card require an external power source (Any Other power connector other than the PCI-E slot) ? Just confirming before I get my Power unit tomorrow.
23-04-2010, 12:00 AM
Super Moderator
Absolutely no external power connector needed. It will pull what it needed off the PCI.Ex16 dock. Enjoy.
23-04-2010, 12:07 AM
#19 (permalink)
Much appreciated. I was worried I would botch something up. Also I think the other SMPS name was Prime Source . Must have forgot to jot down a word when I was listening to the dealer .
