Results 1 to 15 of 15
  1. #1
    bORn To RIse.... rahul.007's Avatar
    Dec 2009
    wherever you think....
    Default Does msi 790gx support thuban????
    HEY GUYS I JUST HAD A QUERRY IN MY MIND REGARDING COMPATIBILITY ISSUES OF MSI 790GX WITH AMD THUBAN.... IN SOME THREADS I READ THAT IT DOESN'T SUPPOTR WHEREAS IN SOME IT WAS WRITTEN THAT IT WOULD SUPPORT AFTER A BIOS UPDATE WHICH WOULD BE RELEASED SOON.... PLEASE CLARIFY....
  2. #2
    sam
    sam is online now
    Forum Moderator sam's Avatar
    Jan 2010
    Guwahati
    Default Re: Does msi 790gx support thuban????
    Quote Originally Posted by rahul.007 View Post
    buddy, 1 very small request. type lower case man.
    ok, as far as i know. AMD announced Thuban will run in 770, 780G, 785G, 790X, 790GX & even 790FX, provided they have the bare minimum TDP support. and most important is, if the board manufacturers release proper BIOS updates. your board is 790GX & it'll run. sure shot. just thing which you should be concerned is that MSI care to release a bios for your board.
  3. #3
    15.0 GHz VarDOS's Avatar
    May 2008
    Beside A Road
    ^yes, thuban can run on 790GX. I think instead of MSI, Biostar will be cool. Cheap boards good performance with SLI on it.
  4. #4
    Dec 2009
    will keep in mind....
    and i also have 1 more querry.... thuban would initially be 140w.... does it mean that each board which supports 140w proccy supports thuban????
  5. #5
    Super Moderator asingh's Avatar
    May 2008
    New Delhi
    That depends on the board architecture. If it is capable enough.
  6. #6
    sam
    sam is online now
    Jan 2010
    Guwahati
    thuban wil be 95W & 125W. not 140W. sorry my mistake. 95W will be X4's & couple of X6's also. AMD may initially release C2 revision Thuban @ 140W but C3 will surely be 95W&125W.
  7. #7
    I am the night...I am... vickybat's Avatar
    Aug 2009
    Gotham City
    Guys just want to know if a socket am2 based asus m2a-vm can support the athlon 2 x4 630 cpu.
    My brother needs to upgrade from his 4400+ cpu without changing the board.
    Core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book ,Seagate freeagent ext hdd 1tb , hp dvd writer,Apc 650 va, logitech z313 , Micromax Funbook , Klipsch image S3 (IEM).
  8. #8
    Dec 2009
    but my main querry is that is there any phenom or phenom 2 which goes to 140w??? if no then why are a no of boards 140w ready???? i think it straightaway means that a mobo supporting 140w proccy should support thuban.... or are there any 140w varients in phenom series yet to be showcased????
  9. #9
    sam
    sam is online now
    Jan 2010
    Guwahati
    cause the not so World Famous Phenom II X4 965 BE C2 revision used to have a TDP of 140W. C3 is 125W. also rumors were Thuban will be 140W for the X6's (Thuban will be the codename for some X4's also). however the geniuses at Sunnyvale put the whole Thuban thing within a 125W (95W for a X6 maybe). also 140W was declared as maximum TDP. so anything having 140W TDP will support Phenom II X4 BEs.
  10. #10
    Alpha Geek pulsar_swift's Avatar
    Nov 2009
    PUNE
    Quote Originally Posted by Sam.Shab View Post
    Wow excellent news, i have ASUS M4A785TD V EVO with 130W TDP CPU support.
  11. #11
    sam
    sam is online now
    Jan 2010
    Guwahati
    Quote Originally Posted by pulsar_swift View Post
    nope. ASUS M4A785TD V EVO got 140W proccy support. have u tried using the GPU NOS thing?
  12. #12
    Nov 2009
    PUNE
    ya 140W. So will it support thuban ?
  13. #13
    Pro/An---tagonist xD
    Dec 2009
    Kolkata
    Errr...I am not sure,but by thuban do you guys mean the hexa-cores by amd??
    Desktop :- Amd athlon II X3 435 unlocked to Phenom II X4 B35 | MSI 785 G-E53 | MSI R6850 Cyclone power edition [OC edition] | Corsair Vengeance 4GB DDR3 RAM @ 1600 Mhz | Corsair GS600 | Seagate 500 gb 7200.12 | Cooler Master CM 690II Advanced | Dell ST2220L |
    Laptop:- Dell Inspiron 15R Turbo => i5-3210m,4gb RAM, 1 tb HDD, AMD HD 7730M 2gb.
  14. #14
    Dec 2009
    yup.........
  15. #15
    sam
    sam is online now
    Jan 2010
    Guwahati
    it'll. even the al chepo Biostar TA785G3+ should support it, provided bio* minds releasing a new bios for it.
  1. Replies: 0
    Last Post: 31-01-2012, 03:36 PM
  2. AMD hexa-core Thuban CPUs coming in May 2010?
    By mayneu in forum Technology News
    Last Post: 01-02-2010, 05:53 AM
  3. Doubt about Biostar 790GX 128M motherboard
    By rchi84 in forum Hardware Q&A
    Last Post: 01-06-2009, 11:41 PM
  4. AMD's 790GX Platform Officially Launched
    By nvidia in forum Technology News
    Last Post: 08-08-2008, 06:08 PM
