Old 17-04-2010, 01:37 AM   #1 (permalink)
Unhappy Some Strange Problem with my PC
Hello,
Recently i am experiencing problem my pc, every time i power on my pc, sometimes CMOS get rest automatically, sometimes i need to clear CMOS to make PC Boot (otherwise everything will work fine and only black screen). I have changed many CMOS batteries, they will work fine for around for 3-4 month, then again problem starts
I am Using ECS 945GCT-M2 Motherboard.
A help in this will be really appreciated
alizeeshan_payne is offline
Old 17-04-2010, 02:55 AM   #2 (permalink)
Its Best only if its open
ankushkool's Avatar
Default Re: Some Strange Problem with my PC
Its quite complicated... there can be a prob with the battery socket! is ur mobo under warranty?
ankushkool is offline
Old 17-04-2010, 08:18 AM   #3 (permalink)
Nope,
Please suggest me Cheap and good motherboard for Dual Core Processor (and should support higher) with PCI Express Slot
Old 17-04-2010, 12:29 PM   #4 (permalink)
Originally Posted by alizeeshan_payne View Post
Nope,
i'll suggest get this motherboard: Gigabyte GA-G41M-ES2L. should cost 2.6-2.8k. & by far is one of best selling Intel onboard graphics mobo. get it.
Sam is online now
installation problem veb Buying Advice 0 09-02-2010 11:40 PM
problem with amd anthlon x2 4600,geforce 9500gt bhadkow Hardware Q&A 2 08-02-2010 11:28 PM
APC UPS problem prvprv Hardware Q&A 1 28-01-2010 05:08 PM
Strange problem in LAN sainit Networking 2 13-08-2007 11:49 AM
Strange Mobo Problem........ cvvikram CPU / Motherboards 8 17-06-2005 01:36 PM
- by c4u
