Old 16-04-2010, 10:32 PM   #1 (permalink)
Default Need Help In Buying 22" LCD Monitor
Hi I want to Buy a 22" LCD Monitor. My budget is Rs 8000
My System Config is: AMD Sempron LE1150 2Ghz
Acer EM61SM/AM Motherboard (Manufactured by Foxconn for Acer OEM) - Nvidia MCP61 Chipset
Onboard Graphics: Nvidia Geforce 6100 nforce 405
RAM: 3*1 GB Transcend DDR2 667 Mhz
PSU: Gigabyte Superb 460W
HDD: WD 80GB and 500GB
OS: Windows 7 Ultimate 32 bit
I have shortlisted 2 models ie AOC 22" Wide 2236Vw and BenQ G2220HD 22inch
It will be used only for browsing, watching movies and other office apps
Does my onboard graphics sufficient or i require a GPU? Will my CPU get stress bcoz of LCD's high resolution. If yes then should i lower the size of monitor say 20" with lower resolution?
So waiting for your suggestions
virajkin is offline
Old 16-04-2010, 10:44 PM   #2 (permalink)
Cool G5's Avatar
Default Re: Need Help In Buying 22" LCD Monitor
Samsung 2233SW = End of the Story
Onboard should do fine except if you plan to game, that's it.
Cool G5 is offline
Old 17-04-2010, 02:59 AM   #3 (permalink)
Its Best only if its open
ankushkool's Avatar
According to digit comparison AOC 2236Vw is better!
here check this thread: 22" lcd monitor
ankushkool is offline
22" lcd monitor kartikkapo Hardware Q&A 30 24-06-2010 12:59 PM
24" LCD Monitor maximus Hardware Q&A 19 07-04-2010 11:31 AM
need help in buying a good 19' LCD monitor jackal_79 Hardware Q&A 13 21-05-2008 04:20 PM
Need Help in buying lcd monitor assasin Hardware Q&A 22 04-03-2007 06:48 PM
Help in buying a LCD monitor. john_the_ultimate Hardware Q&A 53 29-01-2007 12:06 PM
- by c4u
