thank u guys,really appreciate it
.I had the PSU replaced with a brand new one.But still the problem persists.
Btw is the fan on the PSU suppose to spin when u connect the cable directly to the socket,I mean no connectors plugged to the mobo and just the psu plugged on?.
Here's a new development ,I unplugged the 4 pin EPS CPU connector and the system switches on fine.The fan on the PSU spins,as does the one on the procy.
The cabinet fans too work fine now.And the moment i plug the 4 pin CPU connector,its back to the same prob again.
Does it mean that the (4+4) EPS connectors,but of no use.I guess there's something wrong with the mobo.Is it safe to use the PC without the 4 pin connector?
