Old 16-04-2010, 07:06 AM   #1 (permalink)
Question choosing a multimedia phone
hello everyone i am going to buy a new mobile which should have ...
wifi
good battery backup
music quality
gps
accelerometer for auto rotate UI
camera 3M or more
screen 2.4" or more
....i have seen 2 models nokia n79 & 5800xpressmusic..pls. sugggest me a phone which is better than these or choose one of them which is best
zipzap1 is offline
Old 16-04-2010, 12:51 PM   #2 (permalink)
Reverse Engineering rocks
Sid_gamer's Avatar
Default Re: choosing a multimedia phone
Nokia 5800 is a good phone but I think u should go with the Android offering from Samsung that is the Samsung Galaxy Spica I5700 or if budget permits then u can go for the Samsung Galaxy I7500....
Both phones have good features including the one's u have mentioned above...
Follow this thread to know more about these phones-
Official Samsung Spica Discussion Thread
I am also buying a new phone now and my requirements are mostly the same as your's, I have created a thread in the Mobile Monsters section after reading it you'll understand better...
This is it's link - Need suggestions on buying a good cellphone..
Cheers,
sid_gamer
i7-920|DFI LanParty DK X58-T3eH6
G.Skill-1600MHz,2Gbx3|ZotacGTX260 AMP2
Seagate 1Tb|CM Silent Pro M600
AOC-2236vW-Full HD|LG DVD/RW
Altec Lansing FX3021|MX-518
Delux DLC SH-490|CorsairH70
Sid_gamer is online now
Old 16-04-2010, 01:20 PM   #3 (permalink)
Pro/An---tagonist xD
You can check user comments and detailed specifications of phones at gsmarena.com.
However some of the comments are spoof and are posted to mislead you.So be careful.
Amd athlon II X3 435 unlocked to Phenom II X4 B35 8-) | MSI 785 G-E53 | Corsair Vengeance 4GB DDR3 RAM @ 1600 Mhz| Seagate 500 gb 7200.12|
Jripper is offline
Virus attack on java phone! ANURAG SHARMA Mobiles and Tablets 3 09-02-2010 10:32 PM
nokia secret codes dashang Mobiles and Tablets 25 19-01-2008 03:27 PM
Nokia 5700 Xpress Music - My detailed Review Cool G5 Mobiles and Tablets 37 29-12-2007 01:14 PM
can apps ..... Sparsh007 Mobiles and Tablets 10 12-11-2006 01:46 PM
Motorola E398 from the prize winning Phone Reviewer!!! hbk88in Software Q&A 1 15-12-2004 08:43 PM
- by c4u
