Old 15-04-2010, 07:16 PM   #1 (permalink)
D PrankMaster
prankie's Avatar
Exclamation GTX280 not running with AsRock motherboard!
This is my system configuration
AMD Phenom II X2 550BE
AsRock M3A785GXH/128M
2GB DDR3 1333Mhz RAM
550W Cooler Master Real power supply
and Zotac Geforce GTX280 Graphics card
The problem is that despite the system being brand new, the gfx card fails to run..
But when I inserted my friend's old Radeon card in the system it ran perfectly!!
There is no display on monitor when 280GTX is plugged in. The card is not faulty as it runs on my other AMD rig with Asus mobo. I have tried resetting the BIOS, and have also contacted the tech support, but they haven't replied yet...
what could be the prob???
My Rig: AMD Phenom II 1090T | Gigabyte GA880GM-USB3| Sapphire HD6850 | 2x4GB Corsair Vengeance DDR3 1600Mhz | 2x500GB Seagate HDD | Silverstone Strider 500W | Alteclansing Octane 7 | Microsoft Natural Ergonomic 4000 | Logitech MX518 | Rantopad H1 | APC 0.6KVA
My Gadgets: Nikon D3100 | PSP1000 | XBOX360 20GB | Sansa Clip+ | Soundmagic PL50 | Meelectronics M9BK
prankie is online now
Old 15-04-2010, 07:40 PM   #2 (permalink)
I am the night! I am....
vickybat's Avatar
Default Re: GTX280 not running with AsRock motherboard!
Buddy it may be loose connectivity issue. Try to tighten the screws properly and check the cable connectivity.
core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book , hp dvd writer,Apc 650 va, logitech z313
vickybat is offline
Old 15-04-2010, 08:07 PM   #3 (permalink)
D PrankMaster
prankie's Avatar
cables are connected properly, the card shows green light, even the fans runs.. but no display!
Old 15-04-2010, 08:25 PM   #4 (permalink)
mortal kombat
quan chi's Avatar
dude then i think the issue would be something minor like vickybat said some connectivity issue.though it might not be a connectivity issue but something similar.
you can check your screen refresh rate.
try to check all the settings again.
quan chi is offline
Old 15-04-2010, 08:49 PM   #5 (permalink)
D PrankMaster
prankie's Avatar
If the PCI-E card is detected by the mobo, then no display comes from onboard graphics.. in my case, there is no display via card's DVI out, onboard graphics showing display..!
Old 15-04-2010, 09:19 PM   #6 (permalink)
your mobo got 2 Pcie X 16 slots? if yes u may need a switch card. i not sure, but u may need it. or try installing card in 2nd slot.
Sam is online now
Old 15-04-2010, 09:24 PM   #7 (permalink)
Pro/An---tagonist xD
Hmmm...does a screen's refresh rate have anything to do with improper display from a graphics card?Like this one,for example?
Say if a monitor's refresh rate is 60 Hz,does it mean that there will be no display if a graphics card is attached?
Amd athlon II X3 435 unlocked to Phenom II X4 B35 8-) | MSI 785 G-E53 | Corsair Vengeance 4GB DDR3 RAM @ 1600 Mhz| Seagate 500 gb 7200.12|
Jripper is offline
Old 15-04-2010, 09:36 PM   #8 (permalink)
D PrankMaster
prankie's Avatar
@sam
my card has 3 PCI-E slots, with speeds 16x. 8x and 4x respectively.. i tried swapping the cards on all the slots, but no joy..
@Jripper
Screen's refresh rate shudn't be a concern.. btw, I'm using samsung 2033sw (20") LCD as the display
Old 15-04-2010, 09:51 PM   #9 (permalink)
Super Moderator
asingh's Avatar
In the above issue refresh rate is not a problem, the GTX280 is perfectly capable to punch out those refresh rates. It is an industry standard.
Prankie, see you board below. And I have highlighted a manual switch unit that is used to enable/disable multi GPU assignments on your board.
Is that paddle set for Cross fire mode. You will have to check the manual for that. Also when mounting discrete accelerators you will need to disable the IGP. It is working with a Radeon card, cause the board will internally Xfire, but conflicting with your GeForce. Disable the IGP from the BIOS. Let us know.
asingh is online now
Old 15-04-2010, 11:58 PM   #10 (permalink)
D PrankMaster
prankie's Avatar
That paddle is set to 16x which is the default poition, I'll chk the bios once again tomorow..
Thanks for giving ur valuable time for my problem
I'll update you ppl tomo..
Old 16-04-2010, 02:25 AM   #11 (permalink)
mortal kombat
quan chi's Avatar
Thats strange.
but still do first as asigh has said.one thing is sure there is some minor hw/sw conflicting issue here.
most importantly do this.
quan chi is offline
Old 16-04-2010, 11:04 AM   #12 (permalink)
@sam
oh yes, it got 3 @ 8X + 8X + 4X. or 16X when using paddle card.
not exactly. the bios or board will check if the mounted card is HD4350. HD3450 or so. if yes Hybrid CrossFire. else the IGP should turn off my itself. matters looks its only cause is paddle card. & using paddle card very very annoying.
i not think if the board trying crossfire with a Opposition's card
Sam is online now
Old 16-04-2010, 01:42 PM   #13 (permalink)
Super Moderator
asingh's Avatar
At times I have seen issues, when the IGP is not manually turned off.
Old 16-04-2010, 03:34 PM   #14 (permalink)
yes. some boards do offer problem. however bios update usually solves the same. u think OP issue cause, ATI IGP trying mate with an Nvidia discrete GPU?
Sam is online now
Old 16-04-2010, 06:13 PM   #15 (permalink)
BE FREE
^ so what could be the possible out put of mating ..............
"To know that we know what we know, and to know that we do not know what we do not know, that is true knowledge." ~ Copernicus
azaad_shri75 is offline
Old 16-04-2010, 08:13 PM   #16 (permalink)
BSOD, most probably
Sam is online now
Old 16-04-2010, 09:00 PM   #17 (permalink)
D PrankMaster
prankie's Avatar
**UPDATE**
tried friend's 9600GT on the motherboard, and it worked flawleslly... now I'm confused!! is there a compatibility issue with GTX280?
Old 16-04-2010, 09:29 PM   #18 (permalink)
Super Moderator
asingh's Avatar
Have you manually disabled the IGP -- when you were testing other cards..?
Old 16-04-2010, 09:42 PM   #19 (permalink)
D PrankMaster
prankie's Avatar
The graphics priority was set to PCI-E from the very first time I inserted the card...
I enquired at some AsRock forums and found out that there might be some incompatibility with my current config and card. the solution is custom BIOS which AsRock might provide.. I think they wud be workin on it that's why they haven't replied..
New asus P5QPL-AM MOTHERBOARD PROBLEM sanads Hardware Q&A 4 15-05-2010 04:45 PM
Which motherboard for i5-750? digitraju Hardware Q&A 3 13-04-2010 07:37 PM
Please suggest cor2duo processor and motherboard & ram at 10k sanads Hardware Q&A 20 27-03-2010 11:19 AM
asrock motherboard with AGI sujeet2555 Hardware Q&A 7 07-09-2007 10:38 AM
- by c4u
