Originally Posted by kanhadey
Please!
I want to assemble a system between 30-32 k. Pls suggest me a gud config including ALL specs. Config should include the LCD and a 9800 GT gfx.
Processor: AMD Athlon II X4 630 2.8 GHz @ 4.7k
Mobo: Biostar TA785G A3 @ 3.7k
Ram: Kingston 2 GB 1333 MHz DDR3 @ 2.75k
HDD: Seagate 500 GB SATA with 32 MB Cache @ 2.3k
Display: BenQ 22" G2220 FULL HD LCD Monitor @ 7.5k
PSU: Gigabyte 80 Plus Active PFC 460W @ 2.2k
Keyboard & Mouse: At your Choice @ 0.6k
Optical Drive: LG SATA 22X @ 1.1k
Gfx Card: Sapphire HD5750 1GB GDDR5 @ 8.2k
Total 33k
This is the best config you can get at this budget. Why you are going for 9800 GT? It is a very old card and support only DirectX 10. Now DirectX is on the horizon and also lots of Dx 11 titles are coming. So I've suggested the HD 5750 card. It is a Dx 11 card with very power requirement (thanks to its 40 nm manufacturing process)
