Old 15-04-2010, 12:42 AM   #1 (permalink)
Default Gigabyte Ex58 UD5 got spacing problem ?
Is it true that the Gigabyte Ex58 UD5 has some serious spacing problem. You cannot place 2 graphics cards and a PCI card together ? (Read it somewhere)
Please help me as I was thinking of buying this motherboard. I want to make sure that I can use it to configure a 2-Way/3-Way ATI CrossFireX™/NVIDIA SLI with other PCI addon cards.
vicky2008 is offline
Old 15-04-2010, 10:08 AM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: Gigabyte Ex58 UD5 got spacing problem ?
Post a picture here, we will tell.
asingh is online now
Old 15-04-2010, 10:52 AM   #3 (permalink)
Can I use 3 way CrossfireX/SLI with a wireless network PCI adapter ?
Old 15-04-2010, 11:34 AM   #4 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
I dont think 3way SLI will be possible(Well depends on what card you are using)
If you use the huge 5series card's from ATI, it won't be possible. Well you can use the last PCI-E slot but in that case you wont be able to use PCI slot. In 2way SLI too using of a PCI slot will be tiresome.
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is online now
Old 15-04-2010, 11:53 AM   #5 (permalink)
Super Moderator
asingh's Avatar
I cannot even find that board. Can you give the link for it.
Though you will not get x16 x16 x16 on three slots. It will move to x16 x16 x8 or x16 x16 x4. You could mount a card on the 2nd PCI connector. The one next to the heat sink is quite useless.
Old 15-04-2010, 12:24 PM   #6 (permalink)
Is there any x58 board that can be used to configure atleast 2 way crossfire using two cards like ati 5850 with a PCI card like a wireless wifi card ?
Old 15-04-2010, 06:58 PM   #7 (permalink)
BE FREE
if you go for sli 2 way or cf 2 way you can't use the pci slot, not possible in any of the similar boards from gigabyte, so I planned to never go for cf or sli and settled for single hd 5850, as I needed that single pci slot very badly.
"To know that we know what we know, and to know that we do not know what we do not know, that is true knowledge." ~ Copernicus
azaad_shri75 is offline
Old 15-04-2010, 10:14 PM   #8 (permalink)
Super Moderator
asingh's Avatar
See these boards.
MSI Eclipse Plus (3 way SLI/Xfire with x16 x16 x16 -- you can put the accelerator on the 1st and 4th slots and have space for the PCI)
MSI X58 Platinum
MSI X58 PRO
MSI X58 PRO-E USB3
MSI X58 Platinum SLI
MSI X58 PRO-E
100% cpu usage problem anant197 Tutorials 2 03-04-2010 01:36 PM
Creative Speaker Problem, inspire 5.1 5200 mumblehere Hardware Q&A 0 17-03-2010 01:29 PM
problem with windows xp Jaskanwar Singh Software Q&A 3 26-02-2010 10:09 AM
Wireless Problem harmads Software Q&A 2 20-02-2010 08:29 PM
problem reading digit dl dvds agpraneet Hardware Q&A 0 17-02-2010 05:27 PM
- by c4u
