Old 14-04-2010, 06:23 PM   #1 (permalink)
Default RAM Dilemma
Hi, I am new here! I need some help on deciding RAM and a friend of mine suggested I try the forums here. I am basically going to assemble a new system soon and I have decided on the following:
Intel Core i5 750
Gigabyte P55M-UD2
I'd like to go with 2x2GB but I am not sure if I should purchase 1333 MHz CL7, 1600 MHz CL9 or 1600 MHz CL7 (is that even available here??)
Is the clock speed more important or the timings? Also with the configuration I mentioned above, I heard I cannot use a 1600 MHz stick at that speed. Is that true? I don't want to overclock the RAM or the processor. Please advice. Also I'd like to get prices for the RAMs I mentioned. If I get an idea of the prices, hopefully that should also help me in making the decision.
ShadowKnight is offline
Old 14-04-2010, 09:44 PM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: RAM Dilemma
Which company RAMs..?
asingh is online now
Old 14-04-2010, 10:16 PM   #3 (permalink)
I am open to any big players like G.SKILL, Corsair, Transcend, Kingston. From what I am reading, it seems Corsair is the most popular manufacturer and gives better performance but is a bit more expensive. Do correct me if you feel I am wrong. My primary concern is the type of RAM itself, manufacturer is a secondary concern
Thanks.
Old 14-04-2010, 11:49 PM   #4 (permalink)
Super Moderator
asingh's Avatar
You will not see a world of difference between 1333 and 1600. Get the cheaper one. Corsair is nice. Get the 1333 with the tightest timings.
Old 15-04-2010, 01:58 AM   #5 (permalink)
So basically you think I should purchase a Corsair 1333 MHz with the tightest timings? What kind of price difference do you think I'll see in a Corsair 1333 MHz CL7 and a 1600 CL7? If it's like 500 Rs. or something then I guess I'll go with the 1600 version.
Also Corsair was what I had in mind and that's what I am going to finalize. Can you recommend a Corsair brand? I heard the XMS series is good.
Thank you Asigh for your time.
Old 15-04-2010, 10:07 AM   #6 (permalink)
Super Moderator
asingh's Avatar
XMS series are good. Not really sure about price differences. To get a decent ballpark figures, just browse the below sites.
primeabgb.
lynx-india
theitwarez
Which is better RAM? kanishka Hardware Q&A 11 19-03-2010 04:41 PM
Can RAM of different frequency be used together? go4saket Hardware Q&A 3 13-03-2010 12:09 PM
RAM problem.... scotyard QnA (read only) 9 20-08-2007 01:31 PM
RAM confusion!915 motherbord wale urgent help neded!mein RAM lagao ya vapas kar do? tango_cash Hardware Q&A 5 28-07-2007 07:54 PM
- by c4u
