Old 13-04-2010, 07:10 PM   #1 (permalink)
Am here for u
Vensanga's Avatar
Default New Rig @ 38k
Will be needing these things after one month for Intel rig so guys pliz help me...
1.Processor
2.Motherboard
3.Graphics Card
4.Ram
5.Power Supply
6.LCD Monitor
(Already owned Cooler Master Elite 334 Ati Radeon Cabinet,WD 500gb Blue)
My budget is around 38k for these rig....
Acer aspire TimelineX 4820T, Nokia 5800XM
Vensanga is offline
Old 13-04-2010, 07:28 PM   #2 (permalink)
Legendary Darknight
latino_ansari's Avatar
Default Re: New Rig @ 38k
1. core i5 750 - 9.7k
2. gigabyte p55 ud2 - 7.5k
3. sapphire 5670 - 5.5k
4. kingston ddr3 4gb - 5.5k
5. corsair 450w - 3.8k
6. benq g2020hd - 6.3k
total - 38k....
6.
latino_ansari is offline
Old 13-04-2010, 09:16 PM   #3 (permalink)
Pro/An---tagonist xD
The above configuration is good if u wanna go intel inside.
However you wil get better bang for buck if you grow red horns.
xD
Amd athlon II X3 435 unlocked to Phenom II X4 B35 8-) | MSI 785 G-E53 | Corsair Vengeance 4GB DDR3 RAM @ 1600 Mhz| Seagate 500 gb 7200.12|
Jripper is offline
Old 13-04-2010, 09:39 PM   #4 (permalink)
Am here for u
Vensanga's Avatar
thanks man but i think i have to increase my budget to get what i have in mind...
3.Graphics - better...
4.Ram - Gskill
6. Monitor - Samsung
Will it be ok is i stick with Core2duo??? will i regret in the future??? with Core2duo i will be able to get better graphics and Monitor..
Vensanga is offline
Old 13-04-2010, 10:02 PM   #5 (permalink)
Wise Old Ghoul
Piyush's Avatar
4.Ram - Gskill
cre2duo is almost obsolete nowadays
better go for AMD based rig
in that way u can then buy a good gfx card
Piyush is offline
Old 13-04-2010, 11:04 PM   #6 (permalink)
Am here for u
Vensanga's Avatar
your right about core2duo obsolete but my main purpose is gaming and also used for downloading....i kept my system on more than 12 hours a day....am afraid i will have problem with AMD if i kept my system on for that long.....
Vensanga is offline
Old 13-04-2010, 11:33 PM   #7 (permalink)
BSD init pwns System V
hellknight's Avatar
Are you kidding.. My system is on 24/7 with AMD Phenom II 720 BE @ 3.6 GHz processor.. the only time when I've to shutdown the system is when there is no electricity or when my dad gets angry...
My blog :- www.openenclave.wordpress.com
hellknight is offline
Old 14-04-2010, 08:32 AM   #8 (permalink)
Am here for u
Vensanga's Avatar
ha3...thanks and the same goes for me too....i often got a nice scolding from my parents saying "Shutdown your system when you are away do you know how much the electricity bill is".....hahaha
Neway let me think abt AMD first...i usualy go for INTEL rigs and am not really familiar with AMD....
Vensanga is offline
Old 14-04-2010, 09:14 AM   #9 (permalink)
Make Way the LORD is Here
ssk_the_gr8's Avatar
dude u can go with amd without any worries .. many of us here have been using it for years without facing any problems...
(Gen.1:26-27) New Testament
FORUM RULES - Updated
Don't Buy from Sulekha
ThinkDigit Forum Workspace Showoff Contest
ssk_the_gr8 is offline
Old 14-04-2010, 11:08 AM   #10 (permalink)
laborare est orare
Cilus's Avatar
At a budget of 38k, Intel is not the way to go. The suggested configs are great, but don't expect to play demanding games like Crysis, GTA 4 and the new DirectX 11 games like Battlefield Bad Company in 5670 with all the Eye candy enabled. You have to go for medium or lower-medium setting.
According to me Phenom II 965 + HD 5770 is a better option than Core i5-750 + HD5670.
There is no earth shattering performance difference between Core i5 and Phenom II 965. i5 is marginally better. But there is high performance difference between HD 5770 and HD 5670.
My suggestion is
Phenom II X4 965 3.4 GHz @ 8.6k
ECS A785GM-M @ 4.6k or MSI 785GM-E51 @ 4.6k
Corsair 4GB DDR3 1600MHz C9 Titanium @ 5.8k
PSU: Gigabyte 550W @ 3.7k
Display: BenQ 22" G2220 FULL HD LCD Monitor @ 7.5k
Graphics Card: PowerColorHD5770 1GB GDDR5 V2 @ 9.6k or XFX HD 5770 @ 9.6k (3 Yrs Warranty compared to 2 Years of other brand)
Total is around near to 40k. But the street price of most of the item is lower than the mentioned price. So probably you will get everything within your budget. This config will provide you best performance on your budget and quiet future-proof.
Cilus is online now
Old 14-04-2010, 12:05 PM   #11 (permalink)
bORn To RIse....
rahul.007's Avatar
i myself brought my amd rig 3 weeks back.... it remains open for at least 8-10 hrs a day for downloading stuff.... temprature never soars above 41'C.... if i play call of duty 4 or some other demanding game, max temp. never goes above 48'C.... if i encode from .vob to .amv(divx) or vice-versa, max temp reached is 55'C.... in short amd is best for you....
phenom II 955 B.E 3.2 ghz(its hot) no more:mrgreen:|coolermaster hyper 212 evo:cool: | msi 790gx-g65|msi radeon hd6770:hyper: |corsair 2*2gb + kingston 2gb 1333mhz ddr3|seagate 500gb sata X 2, 1tb X 1|lg dvd|seasonic s12ii 520w:punch: |cooler master elite 310|cooler master 120 mm fans X 2|benq g2220 HD|logitech keyboard+mouse|Creative SBS A100|apc 550va|kodak c913|motorola fireXT:wink:
DO WHAT YOU THINK, BUT THINK BEFORE YOU DO.. :)
rahul.007 is offline
Old 14-04-2010, 12:27 PM   #12 (permalink)
AMD = value for money in your budget.
ico is offline
Old 14-04-2010, 01:06 PM   #13 (permalink)
My suggestion is
change PSU to Corsair VX450W as the pricing almost same. also ram to 1333Mhz kit. rest everything good. also get ECS mobo or Biostar TA785G3 HD. don't get MSI's E51. not so good.
Sam is online now
Old 14-04-2010, 09:22 PM   #14 (permalink)
See??I told you it will be better for you to grow red horns.\m/
And don't worry about power and heating problems with amd.They are long gone.
Jripper is offline
Old 14-04-2010, 10:11 PM   #15 (permalink)
Wise Old Ghoul
Piyush's Avatar
trust us
AMD is a sure shot for u
u'll never have any heating issues
Piyush is offline
Old 14-04-2010, 10:50 PM   #16 (permalink)
Am here for u
Vensanga's Avatar
thanks alot guys...will be going for amd and as i have said will not be able to buy just now and will have to wait for maybe one or two months...in that time i may be able to increase my budget and the prices of some hardware might also fall..thank you guys...
Vensanga is offline
Old 15-04-2010, 01:01 PM   #17 (permalink)
by that time X4 630 C3 revision will come out. Lower heat. lower power consumption (maybe). very good OC ability. also cost should be lower quite a bit. add to it GTX460 will come out. you may get HD5850 within your budget then.
Sam is online now
Very high end configuration rig needed..Please suggest kanishka PC Components / Configurations 179 14-07-2010 07:00 AM
Monster Rig arpanmukherjee1 Hardware Q&A 12 25-02-2010 10:13 PM
Need a gaming RIG in 55k cool.vicky Hardware Q&A 5 12-02-2010 02:00 PM
Please help in building a new rig: Urgent falling Hardware Q&A 36 07-02-2010 02:25 PM
- by c4u
