Old 07-04-2010, 11:44 PM   #1 (permalink)
Angry External Hard disk failure pls help
i have seagate free agent GO external hard disk.
when i plugged into the usb port, it gets recognised..but the drive is not opening.
the error shows
"Drive is not accessible...the file o r directory is corrupted and unreadable."
i had around 298GB of files in the 320GB capacityHD.
1)what could be the problem
2)is the hard disk gone?
3)can i retrieve the files from the HD
4)if yes how can i do so.
pls help me people.
dilipc is offline
Old 07-04-2010, 11:59 PM   #2 (permalink)
Democracy is a myth
rhitwick's Avatar
Default Re: External Hard disk failure pls help
Ur HDD has crashed. Try recovering the data first. Use "Recuva" or "Recover My Files" for that.
After that, format it.
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is offline
Old 08-04-2010, 12:55 PM   #3 (permalink)
i can retrive only deletd files from HD..
can anyone tell me how to retrieve the files which is not deleted.
i used recuve suggested by rithwhik bhai.is there any other software to retrieve the files .
guys please hellp
dilipc is offline
Old 08-04-2010, 01:09 PM   #4 (permalink)
You have to do first of all check the hard disk and also the partition could be damaged, in that case just use the Disk Director it is really helpful for you.If your hard disk died then this thing can help you, or smth like this. And the last way to restore data from died hard disk is freezing.
[url=http://www.r4carte.fr/]nintendo r4[/url]
aaronaugusts is offline
Hard Disk girishrn Hardware Q&A 5 25-03-2010 07:43 PM
HELP how to recover files from HDD RAW format abhasbajpai Reviews 4 26-12-2009 06:10 PM
i want hard disk (external) AMITAGARWAL02 QnA (read only) 13 30-03-2008 08:23 PM
IITd online treasure hunt "Krypton" started fun2sh Random News 1005 07-03-2008 05:44 PM
External Hard Disk.... hell_storm2004 QnA (read only) 4 02-11-2007 06:23 PM
- by c4u
