Old 06-04-2010, 04:00 PM   #1 (permalink)
Default Problem in pen drive
I have Kingston DataTraveler 2GB pen drive. When I insert it in USB Port. Then it installs driver for pen drive. After installing driver, when I open My Computer, then it shows pen drive as Removable Disk (with drive letter). When I try to open it, it shows "Please insert the disk". I tried running this pen drive in Windows XP, Windows Vista, Windows 7 and in Fedora 12. Other pen drives run properly. Please tell me frnds how to correct this error. This pen drive contains lots of important data. Please don't tell me to format it.
abhijangda is offline
Old 06-04-2010, 04:36 PM   #2 (permalink)
CA50's Avatar
Default Re: Problem in pen drive
pen drive might be faulty, if it is still under warranty then go for it.
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Old 06-04-2010, 06:22 PM   #3 (permalink)
Democracy is a myth
rhitwick's Avatar
I think its faulty. Can u try formatting it again? Report back...
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is offline
Old 07-04-2010, 12:35 AM   #4 (permalink)
Thats what i dont want to frnd. It contains my father's very important data. Isn't there any way without formatting it.
Old 07-04-2010, 12:46 AM   #5 (permalink)
Democracy is a myth
rhitwick's Avatar
Then try accessing it and recovering it with "Recuva" or "Recover My Files"
rhitwick is offline
Old 07-04-2010, 03:31 PM   #6 (permalink)
sorry rhitwick, i tried recover my files but it didn't work. It was also not able to detect disk.
Any other method frnds.
Old 07-04-2010, 03:58 PM   #7 (permalink)
Passionate
jayantr7's Avatar
hey....try to open it with windows explorer,copy all files to pc and format ur pendrive..it can help try it...i know it sounds funny...but i also got 10%this type of prob it was fixed with this
---------- Post added at 03:58 PM ---------- Previous post was at 03:41 PM ----------
did anything helped written here?
Digitally Impulsed
jayantr7 is offline
Old 07-04-2010, 04:22 PM   #8 (permalink)
format pen drive & than try recover files using recuva.
Sam is online now
Old 08-04-2010, 10:35 AM   #9 (permalink)
TheHumanBot's Avatar
pen drive not detecting the only solution i can see is
go to manufactures site find a format utility & it will sove your problem 100%.
i did it many times. and then try recovering your files as above replied.
if you dont try this anyway your pen drive will be unaccesible.
Twitter Handle : /TheHumanBot
TheHumanBot is offline
Old 08-04-2010, 10:44 AM   #10 (permalink)
change is constant!!
khmadhu's Avatar
first try with quick format(high level)... and try recovering files.(this increases the chance of recovering files )
if this does'nt work then try with complete format (low level)
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
khmadhu is offline
Latest Hardware Prices & Quotes..!! suave_guy Hardware Q&A 5604 14-03-2011 02:05 PM
Data retrieval from dead pen drive devips Hardware Q&A 2 18-02-2010 04:22 PM
Pen drive problem cosx Hardware Q&A 2 22-01-2008 02:50 PM
Pen drive wrought havoc mad1231moody Software Q&A 10 17-01-2008 05:36 PM
Problem with USB pen drive skghosh44 Hardware Q&A 2 24-09-2007 09:46 PM
- by c4u
