Old 05-04-2010, 12:24 PM   #1 (permalink)
Obsessed with Technology
Default 1TB for Backup (EXT or INT)
I want to buy a 1TB HDD but confused over whether to buy a internal or external one.
The reason for confusion is that I want to use the HDD for backing up Games and Movies that I dont use or have already played them. Data gets generated at 3-4 GB per day (*cough*).
I currently have a 160 GB portable Ext HDD. But it is full upto the brim. And I am confused on the idea of using a int HDD for Backup.
So basically should i go for int or ext HDD, the main usage is Backup.
Please help guys.
AMD Athlon 64 X2 Dual Core Processor 4200+ 2.19 GHz, 2.5 GB Ram, 120 GB Hard Disk, XFX 8600GT
Visit my blog devrathnd.blogspot.com
Devrath_ND is offline
Old 05-04-2010, 05:11 PM   #2 (permalink)
Crowman
Krow's Avatar
Default Re: 1TB for Backup (EXT or INT)
I'd say internal as you get them cheaper. Get WD Caviar Green @ 4k. Doesn't give the best transfer speeds, but is a power saver and probably the best drive for backup. I heard that the Seagate drives have reduced warranty to 3 years, so stick to WD.
Choice is yours: If you want to be able to carry your data with you:
1TB WD My Book Essential @ 5k. Pretty bulky, but good for external backup, requires external power source.
Else, go for internal drives.
1TB USB powered drives will cost 10k.
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 06-04-2010, 01:38 AM   #3 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
i hv Seagate BlackArmor 1tb (with eSATA and USB 2.0) support, i purchased this External HDD for 6.9K jus for back up (of my movies, mp3 and my game ISO (which are in excess of 250GB+)..lol... as i hv a lappy (core i3 based) and my rig (core i7, see siggy) so wanted a eSATA based ext hdd, as both my lappy and PC hv this port and also, it takes way way LESS time in transferring the game ISO;s (...ahem..) in eSATA mode than using the USB 2.0..
the choice is totally urs, as i wated to carry my games with me as and wen i travel, so i took an ext hdd, if u jus need a back up (with no or minimal carrying around) u can stick with an Internal hdd.. (wich is way cheaper than an ext one ..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 06-04-2010, 07:28 PM   #4 (permalink)
Crowman
Krow's Avatar
Yeah, if your motherboard supports eSATA, then get an external drive with eSATA support, that is in case you choose external drives.
If you want high transfer speed with internal drives, then WD Black 1TB @ 5k is where you should look.
Krow is offline
Old 01-05-2010, 11:38 AM   #5 (permalink)
So finally my exams are over and planning to buy the HDD. Between an Ext and Int HDD whats the price difference. I am quite paranoid of having an int HDD for backup. So final piece of advice.
Toshiba Introduces 750GB and 1TB Laptop HDDs topgear Technology News 0 26-03-2010 05:48 AM
Seagate Free Agent Desk 1TB OR Seagate Raptor 1TB USB jetboy Hardware Q&A 5 24-02-2010 01:22 AM
Help needed for Data Recovery from maxtor 1tb external storage device fohimuddin Hardware Q&A 0 05-02-2010 10:55 PM
Matrix multiplication in java Tushar.bar Programming 6 07-05-2008 02:30 PM
Anybody plz help me with C bizzare_blue QnA (read only) 12 23-12-2004 06:59 PM
- by c4u
