Originally Posted by ritvij
Hey m gonna assemble a new pc with the following specs :
C2D E8400
MSI P45 Platinum
4 GB Corsair DDRII RAM
640 GB X 2 WD HDD RAID I + 80 GB WD
XFX GTX 260 Graphics
BenQ G2420HD Monitor
PSU 620W Corsair
Altec Lansing Speakers VS2421
can ny1 suggest somthng better...
it will be used for movies, gaming and lots of programming...
RPLY FAST????:-P
if you wanna go intel's way, then go with jaskanwar's suggestion....
under amd:-
Phenom II X4 955 3.2GHz B.E. @ 7.9k(oc it to get 965 perforemance....)
ASUS M4A785TD-V EVO @ 6.3k
Sapphire HD5850 1GB GDDR5 @ 15.8k or MSI HD5770 HAWX 1GB GDDR5 @ 10.2k
Transcend 2*2GB DDR3 1333MHz C9 @ 5.4k
Western Digital Caviar Black 1TB @ 5.3k
Cooler Master Centurion 690 @ 4.2k
Corsair VX550W @ 4.7k
BenQ 22" E2220 FULL HD LCD Monitor @ 8.5k
coolermaster n520 @ 2.4k
total:- 60.5(with 5850 and cm 690) else 52k(with 5770 and nzxt gamma).... choice is yours....
if this exceeds your budget then get nzxt gamma or 5770....
---------- Post added at 02:52 PM ---------- Previous post was at 02:49 PM ----------
if doing decoding stuff, then get phenom else Athlon II X4 630 2.8GHz @ 5.1k would suffice you....
