Old 04-04-2010, 09:29 PM   #1 (permalink)
anurag100's Avatar
Unhappy Please help Urgent help needed...Please
Hi guys......... I need your help
can any one help me to fix my midi in the m-audio audiophile 2496 pci card for my intel based mac 10.5.6
Here is my intel based mac configuration.
Intel core2duo processor
gigabyte 945GCM-S2L motherboard
Intel GMA950 -video
(M-audio) Deltaseries - Audiophile 2496 pci soundcard
Its running on mac 10.5.6 leopard
Installation disc used - iPC intel&amd 10.5.6 with patches
Please help me, i am stuck with my music work.
anurag100 is offline
Old 05-04-2010, 11:29 AM   #2 (permalink)
change is constant!!
khmadhu's Avatar
Default Re: Please help Urgent help needed...Please
whats u r exact problem..? please elaborate
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
khmadhu is offline
Old 06-04-2010, 06:37 AM   #3 (permalink)
anurag100's Avatar
I have installed some patches for my audio card. There are no official drivers. All outputs of sound card are working just alone MIDI is not working...please suggest a solution
Urgent please suggest (Acer 5740/Dell Inspiron/ Dell Stuido15 )??????? phanisrinivas Hardware Q&A 11 19-04-2010 02:17 PM
Very urgent help needed!!!!!!!!!!!!!! metalfan Hardware Q&A 8 05-04-2010 09:20 AM
Want A Phone For 7-8K..Help Urgent TheLetterD Mobiles and Tablets 12 19-03-2010 07:54 PM
Suggestions needed for purchase ajai5777 Hardware Q&A 11 12-02-2010 06:30 PM
Installing VLC in FC-6??? The Unknown Open Source 14 20-08-2007 06:39 PM
- by c4u
