Old 03-04-2010, 09:49 PM   #1 (permalink)
Modern Philosopher
metalfan's Avatar
Unhappy Very urgent help needed!!!!!!!!!!!!!!
I just opened my pc , went to the kitchen and when came back it was showing colourful lines (dazzling yellow orange colours),,, got tensed switched it off ,when turned on my lcd showed no signal did turned on and off few times then it worked but loaded slowly here are my queries -
friend told me that possible reason is overheating due to dust (i have never serviced my pc from purchase time 3 yrs+) is this the reason if so then do i need to service my cpu from HCL people as it has a seal to be opened by HCl people only if any other thing u could suggest PLZ HELP IAM SCARED
Things rare to find are easily imaginable..................Like a good engineering college with above 2 lac AIEEE rank...........
metalfan is offline
Old 03-04-2010, 09:57 PM   #2 (permalink)
bORn To RIse....
rahul.007's Avatar
Default Re: Very urgent help needed!!!!!!!!!!!!!!
cant tell you exactly what is wrong with your pc.... but as you said it loaded slowly, i guess it has something to do with either dust clogging or may be that your hdd is on the verge of crashing.... try defragmenting it and do clean your cabby from inside as 3+ years without any cleaning is a lot of time.... no idea abt whather to call hcl or not as i always had an assembled pc, but i thing they give their warranty only for 1 year and then you can open your cabby.... but do confirm it from someone who knows....
phenom II 955 B.E 3.2 ghz(its hot) no more:mrgreen:|coolermaster hyper 212 evo:cool: | msi 790gx-g65|msi radeon hd6770:hyper: |corsair 2*2gb + kingston 2gb 1333mhz ddr3|seagate 500gb sata X 2, 1tb X 1|lg dvd|seasonic s12ii 520w:punch: |cooler master elite 310|cooler master 120 mm fans X 2|benq g2220 HD|logitech keyboard+mouse|Creative SBS A100|apc 550va|kodak c913|motorola fireXT:wink:
DO WHAT YOU THINK, BUT THINK BEFORE YOU DO.. :)
rahul.007 is offline
Old 03-04-2010, 10:19 PM   #3 (permalink)
Super Moderator
asingh's Avatar
OP:
We need the system configuration.
asingh is online now
Old 03-04-2010, 10:47 PM   #4 (permalink)
I M A *STAR*
saqib_khan's Avatar
Yes, you better service the PC if you have not opened it from 3 years. Dust can be a reason.
Blogging at:
Technostarry
saqib_khan is offline
Old 04-04-2010, 07:18 AM   #5 (permalink)
anurag100's Avatar
hai guys, can any one help me to fix my midi in the m-audio audiophile 2496 pci card for my intel based mac 10.5.6
anurag100 is offline
Old 04-04-2010, 10:29 AM   #6 (permalink)
Modern Philosopher
metalfan's Avatar
Wink Re: Very urgent help needed!!!!!!!!!!!!!!
config is P4 ,intel onboard video and asus sound 80gb DDR2 512 mb ram srry for quick and absurd reply but ....................u know pc is not working how slowly i am typing
metalfan is offline
Old 04-04-2010, 08:36 PM   #7 (permalink)
bORn To RIse....
rahul.007's Avatar
just replace that hdd and then check pc.... also better upgrade your ram and add a 2gb stick.... would cost you around 2k-2.2k.... and please get your pc cleaned....
Old 05-04-2010, 02:43 AM   #8 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
@metalfan if you want, you can follow tons of youtube videos or web pages about servicing/cleaning your system. it is not hard.
Rollercoaster is offline
Old 05-04-2010, 09:20 AM   #9 (permalink)
Modern Philosopher
metalfan's Avatar
THank @ everyone u guys r really helpful,,,besides now my pc is working fine without doing anything just that it showed Wzfkil some file missing but its working fine but i will definitely service my pc for sure
metalfan is offline
Urgent please suggest (Acer 5740/Dell Inspiron/ Dell Stuido15 )??????? phanisrinivas Hardware Q&A 11 19-04-2010 02:17 PM
PC rig help !! URGENT bashphoenux Hardware Q&A 2 17-03-2010 07:24 PM
Suggestions needed for purchase ajai5777 Hardware Q&A 11 12-02-2010 06:30 PM
Help needed for Data Recovery from maxtor 1tb external storage device fohimuddin Hardware Q&A 0 05-02-2010 10:55 PM
Installing VLC in FC-6??? The Unknown Open Source 14 20-08-2007 06:39 PM
- by c4u
