Old 03-04-2010, 02:54 PM   #1 (permalink)
spm
Default upgrade dillemma......
wanna upgrade old p4 system.............
i have a lcd monitor -samsung syncmaster b1930 18.5 inch with max res 1360 x 768
i have a dvd writer so no need for a new one.......
i would need a mobo+cpu+ram(ddr3)+power supply+HDD.
i use the system for some CAD apps like autocad, catia, pro Engineer. and also watch a lot of movies and some gaming like nfs, hitman and all(but no fps games) at low details is enough....
should i opt for a graphics card and if yes will it stay in ma budget.....
please suggest a good configuration that is future proof.....
the budget is limted to some 15k to 20Kmax
spm is offline
Old 03-04-2010, 03:05 PM   #2 (permalink)
Default Re: upgrade dillemma......
Athlon II X4 630 2.8GHz @ 5.1k
Biostar TA785G A3 @ 3.7k
Transcend 2GB DDR3 1333MHz C9 @ 2.9k
Western Digital Caviar Blue 500GB @ 2.3k
FSP Saga II 400 Watts @ 2.3k
total: 16.3k should get for 16k only.
now graphics card. as u play most games in low details. & the apps u mentioned won't need a Pro card so a gaming card will suffix. increase your budget to 21.5k & get Sapphire HD5670 512MB GDDR5 Artic Cooling @ 5.3k.
Sam is online now
Old 03-04-2010, 03:30 PM   #3 (permalink)
bORn To RIse....
rahul.007's Avatar
well i am not into gaming at all and sometimes play call of duty 4, hitman 2, nfs carbon without ani discreet graphics with my msi 790gx g65 at 1920*1080(full settings).... all these run like a hot knife out of butter.... but as you said you use cad (imaging and 3d rendering apps), a discreet gpu would surely boost your perforemance.... buy what sam has suggested....
phenom II 955 B.E 3.2 ghz(its hot) no more:mrgreen:|coolermaster hyper 212 evo:cool: | msi 790gx-g65|msi radeon hd6770:hyper: |corsair 2*2gb + kingston 2gb 1333mhz ddr3|seagate 500gb sata X 2, 1tb X 1|lg dvd|seasonic s12ii 520w:punch: |cooler master elite 310|cooler master 120 mm fans X 2|benq g2220 HD|logitech keyboard+mouse|Creative SBS A100|apc 550va|kodak c913|motorola fireXT:wink:
DO WHAT YOU THINK, BUT THINK BEFORE YOU DO.. :)
rahul.007 is offline
Old 08-04-2010, 09:33 PM   #4 (permalink)
spm
thanks for the reply guys.
actually i am ignorant about the amd stuff so some one please tell me the details of the amd cpu x4 and there naming details.
spm is offline
Old 09-04-2010, 10:12 AM   #5 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
AMD is the best for budget solutions. Athlon II X4 630 is a quad core CPU just for 5k.It outperforms all of the core2duos and some c2q's of intel.It has 512 KB L2 cache for each core.Its the best performing budget quad core.
With 785G chipset you can play your games with decent settings.But not new titles.I think you can play most games till 2009.It has the IGP HD 4200.
Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|Realwatts Pro 500W|APC 650VA
ajai5777 is offline
Old 10-04-2010, 08:44 PM   #6 (permalink)
spm
does this igp hd 4200 means something similar to the one in the hd 4200 graphics cards of ati. as both are owned by amd.
and when i searched for the biostar motherboard i got one with sideport memory and one without it...
does sideport memory increase the gpu performance significantly..
spm is offline
Old 10-04-2010, 10:17 PM   #7 (permalink)
yah its same. & the graphics card u talking most probably is HD4350. not HD4200. HD4350 is 2 times more powerful than HD4200 IGP. however the HD4200 OC past 100%, without any special cooling, making it match HD4350 in most games.
sidport memory is an optional memory. though it speed games up, but not too much. so one may purchase a cheaper HD4200 mobo without sideport. OC the core to 900Mhz(default 500Mhz). add system memory & it'll be a good for casual gaming @ 1024X768. even Crysis will run flawlessly.
however Biostar TA785G3 HD is a cheap mobo with sideport in form of 128Mb DDR3 & good cooling for the HD4200 chip. OC should be fun
Sam is online now
Old 11-04-2010, 09:00 PM   #8 (permalink)
spm
thanks everyone for the help.
thanku sam
spm is offline
PC Upgrade help! ojha_riddhish Hardware Q&A 6 27-03-2010 08:00 AM
Upgrade within 10k? prankie Hardware Q&A 3 22-03-2010 06:38 AM
Free upgrade to 2 Mbps Airtel Broadband!! aashish.joshi Broadband and DTH 2 13-03-2010 10:40 PM
PC upgrade under 15k vinyasmusic Chit-Chat 4 02-02-2010 10:03 PM
Windows 7 upgrade version: The dos and don'ts Gauravs90 Technology News 5 09-11-2009 11:02 PM
- by c4u
