Old 03-04-2010, 02:42 PM   #1 (permalink)
Unhappy How To Connect Pc And Laptop With Router ?Plzzz Help
Hi, i have a pc and laptop...i want to connect both of them and want to access each other hard drive files...i don't want to connect them thru lan...! My Pc is connect with my beetel router with lan cable....and my pc does not have any wifi card.... my laptop is connected with router through wifi adapter....now i want to connect both of them ...pc & lap....i can do that with the help of lan cable ...but i want to connect both of the without any cable ...bu the HELP OF ROUTER ...??? CAN WE CONNECT BOTH OF THEM ?
sumitkala is offline
Old 03-04-2010, 08:53 PM   #2 (permalink)
Tron91's Avatar
Default Re: How To Connect Pc And Laptop With Router ?Plzzz Help
You say router? Or is it just a bridge/hub?
I think you will have to manually set the IP address in both ur laptop as well as ur desktop. If your router got any ip address set it within the same range in ur desktop and laptop. If the router supports DNS, allow it to assign address to ur laptop and desktop automatically. And configure your laptop and desktop to acquire the IP address automatically from the router. Keep the router on during that time.
This might not work though, my memories of my CCNA classes have faded actually.
-- I am Old! I may be Primitive! But still I Rock! --
Intel C2D E7200 1.59 GHz, 2.53 GHz :: PIII Xeon :: 2 GB :: 250 GB + 320 GB HD
Tron91 is offline
Old 03-04-2010, 10:52 PM   #3 (permalink)
I M A *STAR*
saqib_khan's Avatar
Which OS are you having in your laptop and desktop? Have you shared the folder which you want to share ? (stupid question but sometimes we forget to do this).
Blogging at:
Technostarry
saqib_khan is offline
Old 03-04-2010, 11:13 PM   #4 (permalink)
Tron91's Avatar
Doesn't matter what OS one uses, untill u can get ur machines to detect each other. After they can find each other comes the task of folder sharing, etcetra, etcetra ...
Tron91 is offline
Old 05-04-2010, 08:18 AM   #5 (permalink)
M using Windows 7 in both d system..Yes Sharing Is On !! ......@Tron91 Thnxs buddy but m lil noob in all dis....i can connect lap n pc very easily thru lan cable .....but my pc nor my lap ...can detect each other ..... MY TCP/IPv4 in pc is Ip->192.168.0.1 Default Gateway 192.168.0.2....and in lap itz opposite...My preferred DNS Server in both laptop n pc are same itz 202.56202.54......!! do i have to do any router setting ??
{sorry for poor english}
Old 05-04-2010, 03:02 PM   #6 (permalink)
Tron91's Avatar
Through which do you connect to the internet? That machine will be the gateway for the other machine in ur home network. But if you just want both your machine to connect try this setting:
desktop: ip 192.168.0.2 gateway: 192.168.0.1
laptop: ip 192.168.0.3 gateway: 192.168.0.1
if this doesn't work u might need to configure ur router.
Tron91 is offline
Old 05-04-2010, 05:05 PM   #7 (permalink)
The High 5 Flyer
sam9s's Avatar
My My My what recomendations.............anyway....
If i read you post correctly, you have you PC connected with beetle router and you say your laptop is connected with a router as well, is it the same Beetle router you are talking about??, or r u confused with a beetle Modem. Anyway assuming its not beetle Modem and you do not have any internet connection. This is how it should be..............
1. No modem and no internet connection.
PC ==== LAN CABLE ===== > Beetle Router (thats it simple)
You dont have to assign any ipss if you are using a Router, thats what DHCP is your router will automatically assign them. Keep the setting to automatically assign IP
Once this is done, use your laptop to search a wifi connection, which it should as a Beetle connection.
Now again assuming the sharing is enabled you should see you computer name while searhing for teh same on you laptop. Mak sure the workgroup for both the systems is same.
There are lot of other factors as well, but try these and report and we shall see what can be done from there......
sam9s is offline
Old 06-04-2010, 11:39 AM   #8 (permalink)
Hello,
I have a new Linksys router WRT54gs and a new Dell laptop.
The router works well with the cable attached but when I go to wireless
I get a strong signal but unable to get on the internet with WEP security.
With security disabled the wireless works fine. But will not connect to the
internet with WEP security on. I tried to use the CD install disk that comes
with the router but ir does not help.
denialmark is offline
Old 06-04-2010, 05:13 PM   #9 (permalink)
The High 5 Flyer
sam9s's Avatar
Originally Posted by denialmark View Post
Hello,
So whats your question??? you wanna set up WEP security for your router??
If that is the case..... you need to go in to your router page by typing address http://192.168.0.1/ which is your router page. Then click on wireless and then under wireless click on wireless security. Under security mode select WPA Personal. WPA Algo : TKIP. WPA Shared key would be your password which should have one uppercase alphabet and a number. Once you have put the key just save the settings. Close the page and now try to connect using your laptop. The laptop should find the connection and when you wll try to connect it will ask you the key which is same as you typed in the router page.
I hope that is what you were trying to do. If there is something else let us know.....
sam9s is offline
Old 12-04-2010, 12:04 PM   #10 (permalink)
i have a beetel router cum modem....my pc do not have a wifi card ok !! and connected with router with the lan cable ....rite ? and my lap is connected with router through wifi ok ??? now i want to share my pc files or lap files or in simple wrlds i want to connect lap n pc ... i can do that by connectin each other by lan cable or connectin each other with lan cable with help ok router....but i want to connect lap n pc with help of router ...so that i can acess my files from any room ..... {sorry for bad english }
How to transfer data between A PC and a Laptop through a WiFi router? yashodhan92 Laptops and Netbooks 1 07-11-2007 10:28 PM
Connect TV to Pc blademast3r Tutorials 17 23-10-2006 04:59 PM
Nokia Software Updater neerajvohra Technology News 16 31-08-2006 02:26 PM
how to connect pc to laptop through lan? tweety_bird_bunny Laptops and Netbooks 1 03-09-2005 09:19 AM
How 2 connect a desktop PC & a laptop? //siddhartha// Laptops and Netbooks 2 28-08-2005 07:22 AM
- by c4u
