1.) The problem started around a year back. The hdd was slowing down and was always busy. I thought the hdd was failing. I checked it with Seatools. The tests failed. It was Seagate 160gb. I sent that to the service centre and they replaced it within 2 weeks.
This went on for 3 more times!!
I was mentally very disturbed. I bought a Seagate 320gb as a standby so that if one goes to service centre i can carry on with the other one.
Now after around 4months of usuage with the new 320gb, the same problem has started. This time it is freezing for few seconds and then the clicks/commands were getting executed. I installed the replaced new 160gb to check whether this is a cable problem or not. I changed between the 2 cables and the connectors on the motherboard.
The result is: that the 320gb behaving the same way and the new 160gb is always showing busy(the led keeps glowing). But till now working fine(used for oly one day). In the Seatools test, 320gb failed in Short DST and the rest but the 160gb passed.
Now plz tell me where the problem lies? Is it the motherboard then?
I had an Asus P5B-VM. That m/b developed some snags in between all these dramas. I got a replacement after about a month and a half. It was P5Q-VM. This is around 5 months old.
2.) Due to some recent financial crisis I cant buy a laptop right now. But looking to buy a branded cpu only. Am learning web development and will be working soon. So plz suggest me a branded cpu which will work fine for Dreamweaver, Photoshop and the likes. I will buy it within this coming Tuesday.
I hope u all will seriously feel the trouble that i am facing. I really dont know what to do.
Plz help me
