Old 01-04-2010, 10:11 PM   #1 (permalink)
Default plez plez Suggest a Branded PC arround 25k ...
i got no idea which way to go
so can anyone suggest me a branded desktop
in the range of 25k to 30k
for casual home use
should hav 19 inch moniter
thanks
FuriOuS is offline
Old 01-04-2010, 10:59 PM   #2 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Default Re: plez plez Suggest a Branded PC arround 25k ...
This is what you should look at http://www1.ap.dell.com/in/en/home/i...s_s241232in8~~ on given range.
But here are your options on that range http://www1.ap.dell.com/content/prod...57483~0~300269
And as for your 19" monitor req., If I'm not wrong 19" monitor's are not get manufactured nowadays. It's 18.5" (Correct me if I'm wrong)
Well......I suggest to go for assembled one's. You'll get much better rig than branded ones in the same budget.
Well......Here I suggest an assembled rig :
AMD Athlon II X2 240 @ 2.8k
Biostar TA785GE @ 3.7k
2GB 1333MHz Transcend DDR3 RAM @ 2.5k
500 GB WD Blue @ 2.3k
Sapphire 512MB DDR5 HD5670 @ 5.2k (If you want gaming too)
Benq G2020HD @ 6.3k (20" Widescreen)
Zebronics Bijili @ 1.1k
FSP SAGAII 350W @ 1.4k
Logitech/Microsoft Keyboard + Mouse Combo @ Rs. 700/-
L.G. SATA DVD-Writer @ 1.1k
Altec Lansing 2.1 BXR1121 @ 1.1k
Total 28k (Approx)
If you don't need a discrete graphics card(785 Chipsets have inbuild ATI 4200 Gfx card), you can opt for better mobo and better proccy
Like AMD Athlon II X4 620 and Gigabyte 785 U2SH/UD2H
Well.......wait for other members to come in and reply.
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is online now
Old 01-04-2010, 11:28 PM   #3 (permalink)
Total 28k (Approx)
nice suggestion. well he told casual home use, so i think its better drop the graphics card & get an X4. so if non gaming than this should be good:
Processor: Athlon II X4 630 2.8GHz @ 5.1k
Motherboard: Biostar TA785G3 HD @ 4.3k
Ram: Transcend 2GB DDR3 1333MHz C9 @ 2.9k
Hard Disk: Western Digital Caviar Blue 500GB @ 2.3k
Optical Drives: LG 22X SATA DVD-RW @ 1.1k
PSU: VIP Gold 400W @ 1.4 k
Cabinet: Cooler Master Elite 310 @ 1.5k
Monitor: Samsung 2033SW 20" LCD Monitor @ 7.2k
Keyboard Mouse: Logitech Internet Pro Desktop @ 0.6k
Speaker: Creative SBS A300 @ 1.3k
UPS: APC 550va @ 1.8k
total: total coming at 29.5k. after tax & all. total price will be below 30k. check the prices of these components locally or wherever you wish to buy & than hit us back here. will suggest if something not avl.
Sam is online now
Old 01-04-2010, 11:42 PM   #4 (permalink)
Simply a DIGITian
+1 to Sam's config if you are not into Gaming.
@Sam Actually waiting 4 u...!! I know you can suggest far better than me....!!
Hey can you tell me what's the diff b/w Gigabyte MA785GM-U2SH, MA785GMT-U2SH?? Price and spec's are almost same.
Old 02-04-2010, 12:00 AM   #5 (permalink)
well +1 to your config if OP wants put his hand on gaming. just the board is not good. it supports only proccy upto 125W & got 2 DIMM slots.
no. i got less experience than u buddy
Gigabyte MA785GMT-U2SH:
CPU Socket Type: AM3
Memory Standard: DDR3 1800(OC) / 1666 / 1333 / 1066
100% 50,000 hours lifespan of Japanese solid capacitors design
the other board lacks or opposite off all these features. actually Gigabyte got a naming scheme. all the letters: M, T, U2, S, T. all stand for specific standards. will search it for u.
U3S maybe means USB3. not sure. also M stands for mATX. cause MA785GT is a full ATX with Crossfire compatibility (seen in Tom's hardware shootout of boards last yr)
Sam is online now
Old 02-04-2010, 12:08 AM   #6 (permalink)
Simply a DIGITian
^^Thanks It's clear now. I'll do the more neccessary research in google.....!!
Old 02-04-2010, 12:16 AM   #7 (permalink)
no problem. this way my knowledge also increased. however are the boards price almost same? cause AM3 boards seem to cost ~1k more. always. specially if its from well known manufacturers.
Sam is online now
Old 02-04-2010, 12:19 AM   #8 (permalink)
Simply a DIGITian
As far I know both the boards 4m Gigabyte are almost same price(Not sure). I've to check it. Aren't both the boards AM3??
Well......I think we are spoiling OP's thread....!!
Old 02-04-2010, 12:43 AM   #9 (permalink)
actually the GMT is AM3 only. whereas GM is AM2/AM2+/AM3. so old proccy won't fit in the AM3 only board. maybe even the Phenom II 920/940 won't.
well yes.
Sam is online now
Old 02-04-2010, 09:58 PM   #10 (permalink)
Simply a DIGITian
Thanks
well yes.
well....Lets not spoil it anymore :-P
Old 02-04-2010, 10:06 PM   #11 (permalink)
bORn To RIse....
rahul.007's Avatar
for casual home use
thanks
well sam has suggested a good config at your budget.... one suggestion though, get benqe2220 full hd lcd.... 8.4k with vat.... would expand your budget a bit but a great buy.... i went to nehru place and saw it.... it also has an hdmi slot which benq g2220 full hd lcd is lacking....
phenom II 955 B.E 3.2 ghz(its hot) no more:mrgreen:|coolermaster hyper 212 evo:cool: | msi 790gx-g65|msi radeon hd6770:hyper: |corsair 2*2gb + kingston 2gb 1333mhz ddr3|seagate 500gb sata X 2, 1tb X 1|lg dvd|seasonic s12ii 520w:punch: |cooler master elite 310|cooler master 120 mm fans X 2|benq g2220 HD|logitech keyboard+mouse|Creative SBS A100|apc 550va|kodak c913|motorola fireXT:wink:
DO WHAT YOU THINK, BUT THINK BEFORE YOU DO.. :)
rahul.007 is offline
Old 02-04-2010, 10:15 PM   #12 (permalink)
Thanks
no problem buddy
is the cost of E2220 so low? whats price difference between E2220 & G2220?
Sam is online now
Old 03-04-2010, 12:45 PM   #13 (permalink)
bORn To RIse....
rahul.007's Avatar
i saw price of g2220 as 7.65k and e2220 as 8.55k.... 1k price difference....
Old 03-04-2010, 01:46 PM   #14 (permalink)
oh ok thanks. will check it locally once.
Sam is online now
Old 03-04-2010, 03:57 PM   #15 (permalink)
bORn To RIse....
rahul.007's Avatar
anytime
Suggest a good Branded desktop PC gurujee Hardware Q&A 13 26-08-2007 10:07 AM
Suggest me a good phone within 25k Pravas Buying Advice 13 09-05-2007 08:08 AM
Suggest a Good 29" Television in range of 15 - 25k sbhas2k QnA (read only) 2 28-11-2006 09:04 PM
suggest me a good pc for 25k dinesh_mettur Hardware Q&A 4 20-11-2006 07:49 AM
suggest the best buy for around 25k comp_engg_guy Buying Advice 12 30-08-2006 07:46 PM
- by c4u
