Old 01-04-2010, 10:06 PM   #1 (permalink)
Too hot for this forum.
Smile Maximum RAM support
Hi guys.
wanted to know maximum RAM i can put in my laptop -
dv5-1006- ax (HP).
currently, there's (2+1) GB in the lappy. Can i possibly put in (4+4) GB.
My OS is 64bit Windows 7.
Thanks in advance.
Life's too short.Why use Dialup?
s_aerin is offline
Old 02-04-2010, 12:09 AM   #2 (permalink)
The High 5 Flyer
sam9s's Avatar
Default Re: Maximum RAM support
Yes you can put 8GB that is the Max your notebook can have. You need to keep any 64bit version of windows for that, which you already have.
More Details...
http://h10025.www1.hp.com/ewfrf/wc/d...roduct=3761247
sam9s is offline
Old 02-04-2010, 01:56 PM   #3 (permalink)
Smile Re: Maximum RAM support
thanx for the reply.
Had already gone thru the link u provided. This doesn't specify max ram i can use.
As a general rule, 64 bit Vista / Windows 7 wud support 8 GB ram , but i wanted to know whether there's any hardware constraint wrt dv6-1006ax.
s_aerin is offline
Please suggest cor2duo processor and motherboard & ram at 10k sanads Hardware Q&A 20 27-03-2010 11:19 AM
Which is better RAM? kanishka Hardware Q&A 11 19-03-2010 04:41 PM
Ram support problem Amir.php Hardware Q&A 3 19-11-2007 01:06 PM
Tech Support Showdown 2007 aryayush Technology News 1 23-06-2007 04:49 AM
- by c4u
