01-04-2010, 02:03 PM
Connecting 5 x 1 Tb HDDs
Hi, I have 5 x 1 Tb HDDs and i would like to have a setup wherein i can connect all 5 harddisks at the same time and use them. Right now I am using an external casing and connect each and every hdd individually to copy data.
I heard about those harddisk racks, but they are too costly.. and are they reliable? Or does anybody have a good alternate solution?
Thanks.
01-04-2010, 02:06 PM
Re: Connecting 5 x 1 Tb HDDs
Do you want to make it internal or external.
please give your System configuration.
01-04-2010, 02:13 PM
I would prefer to use them in an external way as my cabinet is very small one.
System configuration is: AMD II X4 940 BE @ 3 GHz, 4 Gb DDR2 RAM, Gigabyte motherboard (dont know the model name correctly).
Thanks.
01-04-2010, 04:08 PM
Buy something of this sort:
You'll get it at around Rs. 12-15K
Otherwise you have to connect each HDD separately through individual enclosures.
I'm using 2 x 2 bay enclosures from the same company above. They have both USB and eSata connections and they're working like a charm.
This is the best thing if you want to connect the HDDs externally.
Phenom II X4 940, Gigabyte MA790GP-UD4H, Corsair 6GB DDRII, AOC Fovi F22, Creative Gigaworks T3 Speakers, NZXT Phantom, Corsair GS600, 15 TB HDDs, Shure SRH440, Klipsch S4i, Ipod Touch 64gb
03-04-2010, 12:24 AM
Core i7 (nehalem) Owner
from where did u purchase them..?? its a gr8 solution,  wow...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
05-04-2010, 09:37 AM
@ static_x,
I need to connect 5 HDDs mate.. they have products to connect only 4 HDDs at the maximum, and how much did they charge you for shipping?
Thanks.
05-04-2010, 09:50 AM
Hey that's really a long long story ...
I did lot of efforts to get it directly from the company. You can visit icydock.com for details.
I directly contacted the company (@china), and after uncountable email exchanges they finally accepted my order.
I got my 2 bay enclosure @ 7.1K but it is worth all the pain i took...
---------- Post added at 09:50 AM ---------- Previous post was at 09:44 AM ----------
Originally Posted by prasanna7287
@ static_x,
Thanks.
The product image was just for an idea. It also has a model with 5 bays. But the price will go up accordingly. And i do not understand the purpose of running all the 5 HDs at the same time. This enclosure is hot swappable and therefore you can use any HD when needed and that too with a single push of a button
They charged me $32 for the shipping of 2 bay enclosure
05-04-2010, 12:10 PM
@ statix_x, I had my eyes on: MB455SPF-B.
But what you suggest must be cheap and efficient too..
Thanks for the input pal.
05-04-2010, 02:55 PM
@ static_x,
Thanks.
MB455SPF-B is okay but it is not supposed to be an external unit. You have to fit the entire thing to your 5.25" bay and consumes 3 - 5.25" bay for that.
It is almost half the cost of what I've suggested you. But the one posted above comes with 4 bays only.
06-04-2010, 01:04 AM
thanx for the update buddy, appreciate it.. will look online if sum1 is selling these in India.. thanx again..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
