Old 30-03-2010, 11:38 PM   #1 (permalink)
Sridhar_Rao's Avatar
Default Setting up secure wireless connection
I am sorry if this is not the right forum for this issue, if not please divert it to the concerned one.
I have BSNL DSL broadband modem and now I got a Dlink wireless router. I followed the instructions (wizard) for setting up the wireless connection. I also remember setting router password and a WPA security key. It generated a file with following text:
Network Security Settings
router password : ******
network name(SSID) : abcd
network security type : Most secure(WPA)
security key : ABCDE12345
When I connected my laptop to the wireless network for the first time, I remember entering the same security key. The wireless connection is fine, but it displays that my wireless connection is unsecure. Why is this so?
Do I have to setup another wireless network key again? I am confused. When WPA is in force, should I set another WEP key?
In wireless network connection properties, 'use windows to configure my wireless settings' is checked. when I select the wireless network and click on properties, the SSID is displayed, network authentication is open, data encryption is disabled. In the authentication tab, Enable IEEE 802.1x authentication for this network is unchecked.
Want to study M.Sc in any medical subjects? Read this www.microrao.com/msc.htm
Microx, a diagnostic microbiology laboratory software application www.labmicrox.com
Sridhar_Rao is offline
Old 31-03-2010, 11:26 AM   #2 (permalink)
change is constant!!
khmadhu's Avatar
Default Re: Setting up secure wireless connection
remove automatic configuration and try adding manually in u r PC.
same thing happened with my Belkin Wifi N router. then i removed all PC configurations and added manually. it Worked
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
khmadhu is offline
Old 31-03-2010, 11:48 AM   #3 (permalink)
Also, see if there is setting to hide the SSID... Should be there... This means that anyone trying to locate a access point will only know that there is one at your place, but wont know its name... This gives an additional protection over and above the password protection... And try to keep the SSID also harder to guess instead of abcd... Also, is your password protection WPA or WPA2? Choose WPA2 over WPA as it is more secure...
Arun
Arun
sakumar79 is online now
Old 31-03-2010, 12:18 PM   #4 (permalink)
Point Blanc
you you can reset the router to default setting and then setup the wireless again
acewin is offline
Old 06-04-2010, 06:42 PM   #5 (permalink)
I contacted Dlink and they gave instructions to set it up. As of now, SSID has been changed, it has been made invisible, WPA2 password has been set. All was OK until two days ago.
I am now unable to connect to internet through the router. I can get connected if I connect directly to the modem. Wonder what is happening?
Making Laptop a wireless hotspot spider Hardware Q&A 0 28-03-2010 08:31 PM
Secure your FireFox by tweaking it manually ritesh.techie Tutorials 3 03-03-2010 03:23 PM
Reference Guide on How to Share DataOne Connection.... Choto Cheeta Tutorials 78 23-04-2008 06:02 PM
Increase bandwidth speeds( finally smthin that works) blademast3r Tutorials 12 16-03-2007 09:08 PM
How Does Wireless Work? sabret00the Tutorials 2 26-12-2006 07:39 PM
- by c4u
