Old 28-03-2010, 09:42 AM   #1 (permalink)
9437077259
go4saket's Avatar
Default Corsair 4 GB Flash Drive turns into 1.86 GB
Hello friends!
I have a Corsair 4 GB Flash drive which I have been using without any problem since the last 1.5 years. Since yesterday I have been facing problems with my flash drive as many a times its not detected by my system and even if it is, it asks me to format it. After formatting it, it started showing a total capacity of 1.86 GB and even after that accessing is a problem as it is accessible some times and undetectable the other times.
Can any one help me out of this? Is my flash drive gone bad? If yes, from where can I get it replaced as I guess thee is a 10 yr manufacturers warranty in Corsair's Flash drives.
Thank you.
Win 7 Ultimate
Abit IP35-E Mobo,C2Q 6600,4GB DDR2 RAM,XFX 8600GT 256MB DDR3 Gfx ,Seagate 1TB HDD,Sony DVD RW,500w SMPS,19" Viewsonic VX922 TFT,Logtech G5 Mouse,Altec Lancing 2:1 Speakers.
go4saket is offline
Old 28-03-2010, 10:14 AM   #2 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Default Re: Corsair 4 GB Flash Drive turns into 1.86 GB
1. Go to Disk Management
2. Delete the Pen Drive Partition.
3. Create a partition.
Thats it. Now see if it works. Otherwise try using the same in some other PC's if the problem persists it's time to get replaced. For more about replacing see corsair's website.
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is online now
Old 28-03-2010, 01:55 PM   #3 (permalink)
9437077259
go4saket's Avatar
Even in Disk Management it shows a total of 1.87 GB and there is no option to delete a partition in a flash drive.
Win 7 Ultimate
go4saket is offline
Old 28-03-2010, 02:25 PM   #4 (permalink)
Legendary Darknight
latino_ansari's Avatar
go replace the pendrive...
latino_ansari is offline
Old 28-03-2010, 06:45 PM   #5 (permalink)
can you please tell whats the file system on the pen drive is? FAT / FAT32 / NTFS?
parimm is offline
Old 28-03-2010, 07:23 PM   #6 (permalink)
9437077259
go4saket's Avatar
It has FAT32...
Win 7 Ultimate
go4saket is offline
Old 28-03-2010, 07:39 PM   #7 (permalink)
Simply a DIGITian
Ok. Boot through bootable XP CD. And when the partitions shows up. Just select the pendrive partition and delete it(D by default). And then just exit(F3 default). Now boot into your OS and go to Disk Management and create partition. And after creating partition, if the problem persists, its time to replace the drive(if under warranty) otherwise buy a new one.
Tutorial: Flashing k550i to w610i !! a_k_s_h_a_y Mobiles and Tablets 822 13-10-2010 08:25 AM
Multi Partition a USB Flash Drive in Windows Krazzy Warrior Tutorials 16 11-05-2010 09:02 PM
How to convert ordinary flash drive into U3 smart drive? thetopcyborg QnA (read only) 13 02-11-2008 11:59 PM
Sony PlayStation 3 (60GB) kinshuk99 Gamerz 6 16-06-2007 12:02 PM
How to use flash drive as RAM in Vista?? dOm1naTOr Software Q&A 7 25-03-2007 08:26 PM
- by c4u
