Old 28-03-2010, 06:40 AM   #1 (permalink)
Revolution's Avatar
Question Basic Networking !
Need help!
I have total three PCs.
I want to connect(wired) them all at a time.
I already have a 8 port netgear Switch.
And PC1 have local(LAN bases fixed IP) cable broadband.
Tell me how to connect then all while PC! net is ON.
I want transfer big files from one PC to another.
DC++ will work here ?
Thanks in advanced.....
Revolution is offline
Old 28-03-2010, 10:19 AM   #2 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Default Re: Basic Networking !
1. Connect all the 3PC's to Switch.(Your 1st PC will need two NIC, 1 for broadband and other for LAN)
2. LAN them
3. On PC1, set your internet connection to share.
That's it.
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is online now
Old 28-03-2010, 06:42 PM   #3 (permalink)
Originally Posted by Revolution View Post
Need help!
why do u want to use DC++ ? you will waste a lot of cpu resources calculating the hashes. just use windows file sharing
parimm is offline
Old 28-03-2010, 06:58 PM   #4 (permalink)
Revolution's Avatar
Unfortunately I have only one NIC card(on board gone kaput) at PC1 and I want to share only data not net.
Old 28-03-2010, 07:03 PM   #5 (permalink)
Simply a DIGITian
Ok then dump the idea #3 of sharing net. Follow other two intructions. When you'll be using net just unplug the LAN and vice-versa.
Old 28-03-2010, 07:33 PM   #6 (permalink)
Revolution's Avatar
But the PC1 already running net with fixed IP.
So.how to set up the IPs for the rest ?
Please tell me in detail I'm noob in networking......
Old 28-03-2010, 07:44 PM   #7 (permalink)
Simply a DIGITian
As you have only one NIC, you can't run internet and LAN at same time. Only one of them will work.
I know alliance broadband comes with Fixed IP. Just note them down. You need to set it again when you'll be using net.
And in LAN use 192.168.1.1, .2, .3, .... till you cover all the PC's.
Otherwise just set it to "Obtain address automatically"
See this site http://hubpages.com/hub/Setup-LAN-with-Hub-or-Switch
Old 28-03-2010, 09:27 PM   #8 (permalink)
Revolution's Avatar
Thanks!
Working but data transfer is very slow.
Showing 100Mbps connection.
Is there any way to transfer data faster ?
Home PC for very basic gaming within 30k - please suggest bippukt Hardware Q&A 13 26-03-2010 08:54 PM
BSNL Broadband Networking prateek007391 Software Q&A 2 15-03-2010 08:54 AM
information abt the networking exam baby girl Career Planning and Progression 2 25-02-2010 01:13 PM
Extensions and Their Definitions Sparsh007 QnA (read only) 3 28-11-2006 07:25 PM
- by c4u
