Old 27-03-2010, 03:07 AM   #1 (permalink)
Smile Help me choose a Tablet for Rs,3000
Hi frienzz i plan 2 buy a Tablet for using in Photoshop purpose ..But unfortunely i don't have idea about it...if someone have idea.. plz suggest me..which one is best for my work...
sabarishwar is offline
Old 27-03-2010, 02:22 PM   #2 (permalink)
CG Artist++
Hsakarp_kahtap's Avatar
Default Re: Help me choose a Tablet for Rs,3000
Go for I-Ball Pen Tablet 5540U (13.97cms x 10.16cms)Working Area: 5.5x 4 inches (140 x 102 mm-A6 size @ Rs.2650 @ nehru Palace (Computer Empire) or If u Can Exeed ur budget with Rs. 300-600 more u will I-Ball Pen Tablet 8060U (20.32cms x 15.24cms) Working Area: 8 x 6 inches (203 x 152 mm-A5 size) both of them are SOHO Series . check other details on i-Ball Offical Site
AMD Phenom 1055T @3.5 GHz|| MSI 890 GXM- G65||12 G.B G-Skill Ripjaws 1600 MHz || Segate 500 GB*2 + 1T.B|| CM 690 II Advance|| Cosair VX 550|| MSI NGTX 460 || APC 650 || WD MY Passport 500 G.B USB 3.0 ||
Last edited by Hsakarp_kahtap; 27-03-2010 at 02:39 PM. Reason: Add Modle no and specifiaction
Hsakarp_kahtap is offline
Old 29-03-2010, 09:13 AM   #3 (permalink)
clmlbx's Avatar
Don't buy I-ball ...that is ****
best graphics tablet are by Wacom...ya it is little costly but don't buy any other stuff bcoz all others are useless..
I already own a I-ball g-Tablet and it is useless... I made decision on price and really regretting that ...
Buy Wacom ......best
clmlbx is online now
Old 31-03-2010, 12:32 PM   #4 (permalink)
Point Blanc
seems you are confused wacom to something else, check the prices http://www.wacom.co.in/price/price.php
to the OP, mate your decision to go with I-ball is ok though not the best product for tablets still cheap and in your budget. I am not sure of other manufacturers
But if you think of investing good lot then wacom is what you should consider.
acewin is offline
Help me choose a laptop for 42k Chetan1991 Hardware Q&A 5 02-04-2010 11:18 PM
Adam Tablet - Competition for Ipad Ramakrishnan Technology News 19 26-03-2010 09:57 PM
Earphones: Help me to choose.... anish_sha Hardware Q&A 4 24-01-2010 02:39 PM
Play with Registry Editor kal_21 Tutorials 16 26-12-2007 09:02 PM
The Wacom Bamboo Pen Tablet: First Impressions goobimama Reviews 21 30-11-2007 07:08 PM
- by c4u
