Old 26-03-2010, 01:11 AM   #1 (permalink)
Make Way the LORD is Here
ssk_the_gr8's Avatar
Default An MFD for 8k
budget= 8k, can be extended to 10k
as the guy i'm getting it for has had a bad experience with HP so he wants any other brand and the other requirement is printing should be as cheap as possible, ink should be really cheap & it should be able to work with refilled ink
(Gen.1:26-27) New Testament
FORUM RULES - Updated
Don't Buy from Sulekha
ThinkDigit Forum Workspace Showoff Contest
ssk_the_gr8 is offline
Old 26-03-2010, 01:52 AM   #2 (permalink)
Point Blanc
Default Re: An MFD for 8k
another brand there are alot many canon/epson/brother.
may I ask what bad experience with HP
acewin is offline
Old 26-03-2010, 09:20 AM   #3 (permalink)
Revolution's Avatar
Question Re: An MFD for 8k
Is Refilled Cartridges work with today's modern Chipped printers/AIO ?.....
Revolution is offline
Old 26-03-2010, 11:03 AM   #4 (permalink)
any other brand other than HP
and he's a cybercafe guy so he wants to use cheap cartridges even though i've adviced him against it
Old 26-03-2010, 03:31 PM   #5 (permalink)
Point Blanc
I gave you the brand names canon/HP/brother/epson -- now if u wanna remove HP remove it.
well nothing is cheap, now if you are for printing photos then canon is good, document prinint I will rate for HP, try to look for canon MX328
do not know brother models to suggest you one.
acewin is offline
Old 26-03-2010, 08:34 PM   #6 (permalink)
canon mx328...will check it out
any other suggestions?
Old 27-03-2010, 09:35 AM   #7 (permalink)
Point Blanc
yeah but most of them are out of mind and you have taken HP out.
BTW where do you live, if here in Bangalore go into some showroom check out available printers and their prices. you still did not say what problem he got in the HP,
and MX328 is continuation of MX318 which was a very good printer
check here http://compareindia.in.com/products/...ional-devices/
check for less than 10000 checkbox. select brands you want
I see Samsung-SCX-4300 also in your range which is very good and economical for
about canon printer it can always be said they have best photo print quality
---------- Post added at 09:35 AM ---------- Previous post was at 09:33 AM ----------
as I said I do not know brother printers so you need to dig in a little, though I will also try to read some reviews but latter.
acewin is offline
Need suggestions buying a MFD ishanjain Hardware Q&A 1 10-02-2010 04:56 AM
MFD / AIO : Which one to buy... Quiz_Master Hardware Q&A 5 15-09-2007 09:15 AM
Which is a better MFD??? go4saket QnA (read only) 1 06-12-2006 06:54 PM
laser printer or mfd sujeet2555 Peripherals 4 08-09-2005 09:27 PM
Printer+Scanner or MFD Query delhibhai1000 Peripherals 6 13-06-2005 11:19 AM
- by c4u
