Old 25-03-2010, 08:11 PM   #1 (permalink)
Jaskanwar Singh's Avatar
Default processor doubt
i would like to clear my biggest doubt-
will a core i5 750 beat phenom II x4 965 & 955?
Jaskanwar Singh is online now
Old 25-03-2010, 08:23 PM   #2 (permalink)
Default Re: processor doubt
unfortunately, yes. it'll beat. both 955 & 965 same fast as:
Core 2 Extreme QX6850, QX6800
Core 2 Quad Q9550, Q9450, Q9400
Core i5-650, -660, -661, -670
in games. also OC potential is lot more in the Intel chips.
Sam is online now
Old 26-03-2010, 01:46 PM   #3 (permalink)
but if a person wan't oc then?
what is the performance difference except in gaming?
Old 26-03-2010, 02:30 PM   #4 (permalink)
not a newbie.....
papul1993's Avatar
AMD is the way to go for value for money and the phenom processors are quite good. they cost less than the i5
papul1993 is offline
Old 26-03-2010, 03:10 PM   #5 (permalink)
even then i5 better. but only i5 750. rest of the dual cores i5s are nonsense. you only get a faster graphics core. but with Phenom II's you free to choose between IGP & discrete graphics. so all these factors should be brought into consideration. before just going out & getting an i5.
yah. for VFM, AMD best.
Sam is online now
- by c4u
