Originally Posted by ajai5777
It may be a dumb question but what exactly is the differnce when even the wattage is same?
In my 5yr old PC it was frontech 400W smps.It had no stability issues even with power hungry p4 3ghz ,sound card ,tv tuner card,dvd rw,2 HDD's and 9500GT.
For my current config i planned a premium PSU.Later i thought that new proccy and new HW are not power hungry also i wasnt going to upgrade my graphics card from 9500GT which doesnt need a 6 pin power connector.So i went for Zebronics 450 W sata plus for just 500 bucks.As expected no problems for the new config.In both config i used an APC UPS.
Now i think its better to change the PSU when i go for a graphic card upgrade.
But actually what is the point to go for a 2k PSU in mid range PC's when .5k SMPS are available?
its not a dumb question at all. many many times members here ask why can't a simple home pc run on a cheap psu if high end parts not used.
well if the setup is very simple, without graphics card (or even if there is, something very basic). non OC proccy, & all. a 400W or even 500W local psu is enough. but the thing is that they not reliable at all. they use to get damage very easily. little fluctuation & PSUs dead. & moreover they many times not get damage alone, but along with HDD or motherboard. & specially Optical medias (DVD writer).
so if someone is purchasing a pc on a tight budget he/she may go along with the bundled default PSU but i always request buyers to get something better if budget permits. PSU like VIP, PowerSafe or Zebronics Pro good enough for simple setups. however if midrange graphics + OC is included a sub 3k, 80+ certified PSU from some reputed international manufacturer best combo.
well in your case, its good. your graphics card is very less power hungry. proccy will eat up somewhat amount of power. but the main thing you missed is when a board gets old, the caps slowly dry up (all old boards ships with electrolyte caps) & the power consumption subsequently rises up.
