Old 23-03-2010, 01:22 PM   #1 (permalink)
Jack Sparrow
joey_182's Avatar
Question Laptop Cooling Pad-Help this out
After searching for Laptop Cooling pad, which is right now my top most requirement of my laptop, I am stuck with these two affordable results. Check it out..
Giga Ware Cooling Pad
and Belking Laptop Cooling pad
Stuck with these two..
If any of u have used laptop cooling pads then suggest one or other solution.
KHAO PIYO TE AISH KRO!!
http://twitter.com/puneetshrma
joey_182 is offline
Old 23-03-2010, 03:07 PM   #2 (permalink)
harryneopotter's Avatar
Default Re: Laptop Cooling Pad-Help this out
whats ur budget and screen size of ur lappy ? U can get good Notebook coolers from Coolermaster.
Have a look at this link :
http://www.techenclave.com/dealers-p...te-162391.html
Wats the Favourite Mathematical Function of DIGIT FORUM ????
Its "A SINE WAVE" constant
Y ??
They Both keep going "UP AND DOWN, UP AND DOWN............" !!!!!!!!
harryneopotter is offline
Old 23-03-2010, 11:29 PM   #3 (permalink)
Jack Sparrow
joey_182's Avatar
Ya..That looks cool..But
where i can get those in india,chandigarh...?
joey_182 is offline
Old 23-03-2010, 11:57 PM   #4 (permalink)
I like CM... its cool.. where I can buy this... I am from Ahmedabad.
chintan786 is offline
Old 24-03-2010, 12:17 AM   #5 (permalink)
Point Blanc
dont you guys know where electronics/computer parts are sold in your big towns.
---------- Post added at 12:17 AM ---------- Previous post was at 12:06 AM ----------
if you do not know then there are online shops. In Mumbai and Chandigarh both.
Here is the links for them
http://lynx-india.com/index.php?categoryID=79
http://www.techshop.in/store/main.php
http://primeabgb.com/
acewin is offline
Old 24-03-2010, 10:25 AM   #6 (permalink)
Jack Sparrow
joey_182's Avatar
Well I dont knew the exact store..well I contacted lynx-india and I'll go today and ll review here after buying one....
joey_182 is offline
Old 24-03-2010, 11:53 AM   #7 (permalink)
you guys can buy these from SMC's website too....
http://www.smcinternational.in
Though the notepals are not listed there, but u can contact the admin through the contact form easily.
Y ??
Hardware price list/spec sheet comp@ddict PC Components / Configurations 5533 Today 12:49 PM
Sony Vaio CW26FG Review codename_romeo Reviews 28 26-04-2010 07:44 PM
acer laptop and big trouble , urgent help needed fun2sh Laptops and Netbooks 6 19-04-2010 08:10 PM
3.5" SATA HDD powerd by Laptop k_mridul Hardware Q&A 0 28-02-2010 04:21 PM
NVIDIA overclocking,tweaking and cooling....All info you nee funkymonkey Tutorials 6 01-09-2005 08:46 PM
- by c4u
