Old 23-03-2010, 10:29 AM   #1 (permalink)
►T3CHWΦRM◄
CHALLENGER's Avatar
Default Help To Build My Rig
Hii All....First i am working on 3d software's like Maya, Max, Houdini etc.
My budget : 60-70k
Processor : Suggest from this 2
1] Intel® Core™ i7-930 Processor (8M Cache, 2.80 GHz, 4.80 GT/s Intel® QPI)
2] Intel® Xeon® Processor W3530 (8M Cache, 2.80 GHz, 4.80 GT/s Intel® QPI)
Check here :-
http://ark.intel.com/Compare.aspx?ids=37147,41313,41447,
I don't want i7-920 coz difference is only 10$ & i Don't know as I read some of d threads no1 suggest Xeon processor even if W3530 is looks better then i7 { I am not into computer parts but in compare i found Xeon W3530 is better then i7-930 in few features with same price. }
Xeon is having this 2 extra features in same price = ECC Memory Supported & Intel® Demand Based Switching { I really don't know what this features for }
Processor : May i go 4 = Intel® Desktop Board DX58SO
Check here =
http://www.intel.com/Products/Desktop/Motherboards/DX58SO/DX58SO-overview.htm
I like Intel over AMD as after some researches i found AMD is good then Intel but as AMD goes older its giving trouble & becoming slower so i like to buy Intel mb.
Monitor : LCD 22 or 24. I want square monitor as in wide screen sphere looks like egg in 3d software's. 1 of my friend having wide screen so better prefer square 22/24 monitor & specially which going to give less tress to my eyes.
Grafix Card : No idea but i prefer Nvidia
RAM : 2 to 4 gb is ok. Suggest brand.
SMPS : 500w is enough ? or i want more plez suggest.
Cabinet : good cooling & adjustable as well if having some ports like esata, headphones, usb its good.
That's it........ plez give ur suggestion.....Thanks.
---------- Post added at 10:29 AM ---------- Previous post was at 10:10 AM ----------
I think my budget is quite low for this so may be 80k last. Plez try to keep total in 65/75k...Thanks.
CHALLENGER is offline
Old 23-03-2010, 10:55 AM   #2 (permalink)
In the books..Studying
Default Re: Help To Build My Rig
AFAIK , Xeon Processor is for servers.
kanishka is offline
Old 23-03-2010, 10:58 AM   #3 (permalink)
►T3CHWΦRM◄
CHALLENGER's Avatar
But there is no difference between features ? so why they r specially for servers ? Its not possible to use them in desktop pc ??
Old 23-03-2010, 11:26 AM   #4 (permalink)
Xeon processors can be used on desktop PCs just fine.
pranav1994 is offline
Old 23-03-2010, 11:29 AM   #5 (permalink)
They can very well be used in desktop pcs but i think they aren't good for overclocking.
kanishka is offline
Old 23-03-2010, 12:57 PM   #6 (permalink)
I think u should go with i7 as they are specifically designed for Desktop PC. Whereas Xeon processors are for severs
Sam123456 is offline
Old 23-03-2010, 02:46 PM   #7 (permalink)
dissel's Avatar
It means 5.4 aspect ratio monitor,
I am also want to know if any monitor available in this aspect ratio size ?
dissel is offline
Old 23-03-2010, 03:54 PM   #8 (permalink)
Jaskanwar Singh's Avatar
first of all there is nothing like that. amd's processors are not slow and they are VFM than intel. in fact Phenom II X4 Black Edition 955, 965 (priced at 8100, 9100 respectively) perform as fast as Core 2 Quad Q9550, Q9400 (priced at 13000, 9300 respectively)
but sadly they come no where close to core i7. and for your work core i7 is best as they are great for any kind of 2d or 3d rendering.
Core i7 930 2.66GHz @ 14.8k
MSI X58 Pro @ 10.8k
PowerColour HD5770 1GB GDDR5 V2 @ 9.6k
Corsair TR3X2G-1600 XMS3 C9 6GB Kit @ 8.6k
Western Digital Caviar Black 1TB @ 5.3k
LG H55N DVD @1.1K
Corsair VX450W @ 3.8k
NZXT Gamma @ 2k
Logitech Keyboard & Mouse combo @ 0.7k
Altec Lansing VS2421 @ 2.2K
Numeric 1 KVA UPS @ 4.2k
Total - 63.1k
rest on a monitor. you can take suggestions about it from somebody else.
Jaskanwar Singh is online now
Old 23-03-2010, 06:24 PM   #9 (permalink)
►T3CHWΦRM◄
CHALLENGER's Avatar
ohk processor fix. I am going for Core i7 930.
MSI X58 Pro is this mb good for above processor ?
Corsair VX450W is this enough for above conf. ? don't u think 500w or more is good ?
I like HD5770 1GB GDDR5 but I am going for XFX as PowerColour design is not that good. Any other nvidia gfx card choice ?
I like the case. Its cool. Looks r ok but overall great deal 4 its price.
I already have ups, keyboard,mouse & speaker so i want only products which i mention in my 1st post but thanks for suggestions.
Plez if u give me few more good choices in Mb, gfx card & monitor its good for me to choose from.
Thanks again for help.
Old 23-03-2010, 08:30 PM   #10 (permalink)
if you wan't only the cpu components then you can get a really powerful rig for that budget
MSI X58 Pro @ 10.8k (great VFM)
(some other -
BIOSTAR TPower X58 @ 12.5k
ASUS Rampage II Gene @ 17.4k)
Sapphire HD5870 1GB GDDR5 @ 22.9k(ONLY IF YOU GAME SERIOUSLY)
otherwise -
Sapphire HD5850 1GB GDDR5 @ 15.8k
otherwise -
PowerColour HD5770 1GB GDDR5 V2 @ 9.6k(sufficient for your work)
Corsair VX550W(hd5870 or 5850) @ 5k or Corsair VX450W @ 3.8k(hd5770)
NZXT M59 @ 3.8k
i don't know about square monitors
Old 23-03-2010, 08:56 PM   #11 (permalink)
►T3CHWΦRM◄
CHALLENGER's Avatar
Radeon™ HD 5770 1024 MB DDR5 DisplayPort XXX (HD-577A-ZNDC) = PCI-E 2.0
Radeon™ HD 5770 1024 MB DDR5 DisplayPort XXX (HD-577A-ZNDK) = PCI-E 2.1
I like this above 2 models from ati 5 series all features are same except PCI-E support. 1 is havin 2.0 & other 2.1 so whats d difference between them & which is better? Is PCI-E 2.0 & 2.1 is supported by DX58SO MB ???
Plez Help...Thanks.
---------- Post added at 08:56 PM ---------- Previous post was at 08:40 PM ----------
Jaskanwar Singh = I prefer 5770 but if i go for XFX is that ok coz PowerColour design is not that good & there is no such a huge price difference.
Processor = Core i7 930 2.66GHz
Mother Board = NOt sure yet about brand Intel chipset, MSI or any other brand ???
GFX Card = Radeon™ HD 5770 1024 MB DDR5 but (HD-577A-ZNDC) = PCI-E 2.0 OR (HD-577A-ZNDK) = PCI-E 2.1 or any1 having Nvidia SLI choice ??
Cabinet : I will choose 1 from NZXT product. If any1 have other brand choices plez give me ur suggestions soon.
RAM : Corsair 4GB DDR3 1600MHz C9 Titanium OR Corsair TW3X4G-1600C9DHX 4GB Kit ?? I think 4gb is enough for me. May be i will increase it to 6gb later.
Old 23-03-2010, 09:04 PM   #12 (permalink)
why do you wan't DX58SO? if you wan't a high end mobo go for ASUS Rampage II Gene, but still such mobos are not recommended for your work (they are for gamers). MSI X58 Pro is sufficient, a great VFM
THERE IS VERY LITTLE PERFORMANCE DIFFERENCE BETWEEN BOARDS WITH SAME CHIPSET
PCI-E 2.0 & 2.1 have same speed
PCI-E 2.1 card will work with PCI-E 2.0
you have made a good choice for graphics card
---------- Post added at 09:04 PM ---------- Previous post was at 09:02 PM ----------
6GB of ram is recommended for your work. you can go for Corsair TR3X2G-1333 XMS3 C9 6GB Kit @ 7k
Cooler Master Centurion 690 @ 4.2k is another cabinet
Old 23-03-2010, 11:02 PM   #13 (permalink)
►T3CHWΦRM◄
CHALLENGER's Avatar
I am playing games to bro & i completed farcry, farcry2, witcher, stalker soc & cs & more so i want to play few games too like gta 4, Mafiya 2, Diablo 3, Stalker cop & good action n RPG game. I am not a serious gamer so don't want to play games at high end settings but want to play on medium setting for fun as well i am not going to change my pc conf. at least for 3/4 years so i want good mobo too. that's why i am asking for DX58SO which having good cooling + good sound & as i am purchasing intel processor i think its quite good that i go 4 intel chipset DX58SO....any suggestion ??
now only have to choice motherboard & Monitor. I think latest wide screen monitors r supported Softwares like maya, max. Plus i have to check that Radeon™ HD 5770 1024 MB DDR5 DisplayPort XXX (HD-577A-ZNDK) is suported bt maya 2010 or not as every gfx card is not for maya.
Thanks again for ur great help.
Old 24-03-2010, 12:53 AM   #14 (permalink)
Point Blanc
@OP, you wont get square monitors above 19 inch now, certainly not in LCDs.
circle never seems to be oval or an egg in widescreen. certainly you SW is some old SW and does not works in those res, though IMO it is unlikely even older SW wont do that. until and unless you have generated something in square ration i.e. 1:1 and put into full screen and it tries to stretch to cover the display.
get 6GB ram as in core i7 triple channel RAM support is their.
acewin is offline
Old 24-03-2010, 09:35 AM   #15 (permalink)
Super Moderator
asingh's Avatar
@OP:
You would be better suited with a PRO series card. Quadro or FireGL. These are non gaming cards, but certified and tested for 3D work, for the likes you are interested in. Gaming cards, are ill suited for 3D work.
asingh is online now
Old 24-03-2010, 11:37 AM   #16 (permalink)
►T3CHWΦRM◄
CHALLENGER's Avatar
ok so i think i decided to go for....
Processor = Core i7 930 2.66GHz = FIX
GFX Card = XFX Radeon™ HD 5770 1024 MB DDR5 (HD-577A-ZNDK) = PCI-E 2.1 = FIX
RAM : Corsair TR3X2G-1600 XMS3 C9 6GB Kit = FIX
HDD : Western Digital Caviar Black 1TB = FIX
Power Supply : Corsair VX550W = FIX
Mother Board = Intel X58 Express Chipset
http://www.motherboards.org/imageview.html?i=/images/reviews/hardware/1831_p3_1.jpg
http://www.intel.com/products/desktop/motherboards/DX58SO/DX58SO-overview.htm
Plez give me some more details on MSI mb features which is better then intel chipset ya MSI price is really good but i think intel processors r surely going to support more intel chipset & intel as more/good support for many software's.
Cabinet : Not yet decided. As i want easy to remove function for hdd. I like NZXT M59 but i really don't like that vertical drive mounting means i don't know how i am going to remove sata & power supply cables from it ??? If hdd mounting is horizontal then i think its eas to remove cables from hdd...Any suggestions ???
Monitor : Yeh i think many lcd monitor brands finds the problem of some software's which requires square ratio so i think wide screen is ok for me but as my work needs close view with monitor many times plez suggest me monitor which going to care my eyes. 22"/24" is good. Specially suggest me a good lcd brand so that i will check there site for features.
Samsung, viewsonic, benq, aser, dell or any other ????
Thanks for all friends for lots of help n 4 giving me good pc knowledge
Plez feel free to post nay suggestion u likke to give me.
---------- Post added at 11:37 AM ---------- Previous post was at 09:41 AM ----------
What's the difference between MSI X58 Pro & X58 Pro-E ??
Whats d price of MSI X58 Pro-E ???
May i go for X58 Pro-E ???
Old 24-03-2010, 12:00 PM   #17 (permalink)
I am the night! I am....
vickybat's Avatar
Smile Re: Help To Build My Rig
@CHALLENGER
Go for jaskanar's config and stick with the msi x58 pro.Its real vfm and you won't regret.
As far gpu is concerned you should wait for gtx 470 as its just around the corner.
core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book , hp dvd writer,Apc 650 va, logitech z313
vickybat is offline
Old 24-03-2010, 12:20 PM   #18 (permalink)
►T3CHWΦRM◄
CHALLENGER's Avatar
Ya but i think there is no such a big price difference in x58pro & pro-E so why not pro-E ?
Just want to know the difference that's why asking.
Franky i really like the looks of Intel® Desktop Board DX58SO the mb looks much professional then any other x58 ya but as i check some of d sites for MSI i am really falling in love with MSI coz of VFM.
But still i am confuse with mb as they have different features with different prices & really don't know which feature is good for me for mb price & for my work so plez if possible give me some detail info on features of Intel Desktop Board DX58SO & MSI x58pro & pro-E. Or if u give me any site link for compair this 3 product its really going to help me a lot to choose from this 3 mb.
Thanks.
Old 24-03-2010, 01:43 PM   #19 (permalink)
vickybat's Avatar
Buddy the msi pro-e is great board and you is a good overclocker.You cannot oc with the intel board and the bios lacks a lot of features.
So go for the msi eyes closed.
And consider fermi as the gpu when it launches on march 26th.
vickybat is offline
Old 24-03-2010, 01:47 PM   #20 (permalink)
Point Blanc
http://www.msi.com/index.php?func=compareindex
this is your link for msi site's compare products
---------- Post added at 01:47 PM ---------- Previous post was at 01:46 PM ----------
http://www.msi.com/index.php?func=co...1744;1804;1696
and this is link for comparision of 3 boards, I added the x58 platinum board too.
acewin is offline
Old 24-03-2010, 02:00 PM   #21 (permalink)
►T3CHWΦRM◄
CHALLENGER's Avatar
ya i understand that msi is good then intel but just want to compare for my satisfaction as all board r not cheap so i don't want to do hurry to pick 1 without knowing them nicely. I am not a rich guy so i have to think twice b4 final purchase hope u understand.
About gpu no i am going for hd 5770 as i am never in favor to buy latest release products as if they having any bugs i don't want to suffer so i will wait till fermi good reviews from its users then i will going to decide so if its good i will purchase that later. Thanks for help.
If any1 having detail info on this 3 mother boards [ Intel Desktop Board DX58SO & MSI x58pro & x58pro-E. ] plez give me links...Thanks.
---------- Post added at 02:00 PM ---------- Previous post was at 01:54 PM ----------
Hey thanks acewin buddy thats really helpful to compare MSI x58pro & x58pro-E.
IF u have any links to compare intel vs msi plez provide coz i ma strongly looking Intel Desktop Board DX58SO vs MSI x58pro-E Features comparison.
Old 24-03-2010, 02:01 PM   #22 (permalink)
BE FREE
http://www.msi.com/index.php?func=co...d_no=1744;1804
strange as per the link for comparison there is no difference between the 2 boards then why the other is called pro-e:roll:
"To know that we know what we know, and to know that we do not know what we do not know, that is true knowledge." ~ Copernicus
azaad_shri75 is offline
Old 24-03-2010, 03:08 PM   #23 (permalink)
►T3CHWΦRM◄
CHALLENGER's Avatar
hahah...I am also going to ask d same question is there only difference in name ???? coz all other spec. r same for X58pro & pro-E.
Btw whats d difference between sata3 & sata2 as msi board don't have sata3 port but intel dose. plez update me on this..Thanks.
---------- Post added at 02:30 PM ---------- Previous post was at 02:14 PM ----------
---------- Post added at 02:46 PM ---------- Previous post was at 02:30 PM ----------
@vickybat : Intel also offers advance overclocking. check image [left bottom].
---------- Post added at 03:08 PM ---------- Previous post was at 02:46 PM ----------
Intel is in budget too...10k approx.
http://www.amazon.com/Intel-Extreme-Tri-Channel-CrossFireX-Overclocking/dp/B001ISJONM/ref=sr_1_1?ie=UTF8&s=electronics&qid=1269423375&sr=1-1
Old 24-03-2010, 03:30 PM   #24 (permalink)
Point Blanc
havent got anything to compare the two different manufacturers. may be some review sites will do.
do these boards come with on-board gfx I do not think so, so buying a gpu at the time u buy ur rig will be a must. then u will have to decide
---------- Post added at 03:20 PM ---------- Previous post was at 03:17 PM ----------
for msi I know one thing if the specs do not differ then price too wont differ much maybe 200-300
---------- Post added at 03:25 PM ---------- Previous post was at 03:20 PM ----------
check their respective pages for difference, pro-e comes with split-thermal system and blu-ray audio that what makes the difference hahaa(though I was expecting something like that because putting an E most of the time means more energy efficient so MSI would have also done something like that), cant even understand that what they propose for difference.
---------- Post added at 03:27 PM ---------- Previous post was at 03:25 PM ----------
futhur more something written like lossless
• The loss-less content protection technology with full-rate audio enjoyment from Blue-ray Disc
• Support for 24-bit / 192kHz sample rate offers high quality digital decoders and speakers
• support 7.1 channels playback, plus 2 channels of independent stereo sound output (multiple streaming) through the front panel stereo outputs
Live Update 4 is a single utility software that automatically checks BIOS, driver and utility updates and installs for you , which can save your time for searching and lower the risk while updating.
---------- Post added at 03:28 PM ---------- Previous post was at 03:27 PM ----------
Chipset integrated by Realtek® ALC889, which I think makes the blu-ray audio for pro-e
---------- Post added at 03:30 PM ---------- Previous post was at 03:28 PM ----------
couldnt even find a review for the intel original board
acewin is offline
Old 24-03-2010, 05:32 PM   #25 (permalink)
BE FREE
sata3 is new update in sata line up it allows 6gbps data bandwidth as compared to previous 3gbps.
intel board has only 4 ram slots and you will use 3 slots of ram and if you want to upgrade ram you would not have option to add as you would be left with only one slot and only option would to remove present sticks and add 3 4gb sticks, you got it, better go for some other board,
you need to buy gfx card , as these kinda boards don't come with igp.
Old 24-03-2010, 06:24 PM   #26 (permalink)
►T3CHWΦRM◄
CHALLENGER's Avatar
@acewin : Intel mb aslo supports 7.1 & requires Realtek® ALC889 drivers.
For price & review go here....
5star : 10 votes check msi pro-E too on this site just search.
@azaad_shri75 : price is same approx 10k for intel plus i am going to use 3 2gb sticks so in future if i add last 2gb stick then 8gb is more then enough ram for me.
I am never looking 4 board which having lots of unusable ports. I think 4 sata, 4 usb, 4 ram slots r more then enough as in 2day's word 2tb hdd is available so no1 going to add more then 3hdd i think but still 4 ports r enough. ya if u r giving more ports in server specify boards then its ok but for home pc 4 is enough i think. [Intel is having 6 sata & 2 esata, msi is having 7 sata & 1 esata ]
Usb ports r now a days not a problem to increase as external ports r available plus cabinet also offers few ports so adding 6/8 ports is waste i think. [ Intel 12 usb, MSI 8 usb ]
What d use of more then 4 slots for ram ?? 8gb is more then enough for home pc as well 4gb sticks r available so we can put 16gb ram. [ Intel 4 slots, MSI 6 slots ]
So i really don't know why this mb brands wasting space by adding useless ports. Good space is really important for good airflow, for good coolers or for anything good which is more useful.
Old 24-03-2010, 06:35 PM   #27 (permalink)
BE FREE
you are right in your sense hitherto some one needs 12gb ram for eg or 4drives of hdd in raid and another four sas drives - all for eg, it depends on personal use,
what I was trying to say was of triple channel memory is standard for optimum performance for i7 9x series of cpu.
Old 24-03-2010, 06:38 PM   #28 (permalink)
►T3CHWΦRM◄
CHALLENGER's Avatar
Really sorry but i don't want to start Intel, MSI war here but I really want to put my money in good purchase. Plez understand me.
As Intel & MSI both mb prices r not that different i have to choose 1 from them so now i have to choose only 1 from this 2 mobo.
Till now u r told me to go for MSI but no1 give me any specific reason that why i should go 4 MSI over Intel. I want reason plez. If ur posting go for MSI just coz u read msi is good or u have msi board then plez don't do that. As i am in few other computer forum few users only copy-paste conf. from other forums even if they don't know anything so plez don't do that if u have real knowledge which1 is good then plez specify d reasons which really going to help me in nice way.
Plez don't get me wrong as i am not saying u all r copy-pasting but i just want few good reasons to go for MSI as i am Intel fan & i really in favor of intel coz processor is from intel & intel have good software's as well technical support on web which is quite nice thing about intel.
So plez if u have pros & cons for Intel & msi I really like to read them b4 final purchase.
Old 24-03-2010, 07:24 PM   #29 (permalink)
Super Moderator
asingh's Avatar
You are hardly listening to what people are saying. People have mentioned to you umpteen times, that the MSI boards are OC/hardcore gaming series boards. The vanilla Intel is just for the basic X58 chipset. See the number of DIMM slots on the DX58SO. It is '4'. Now to optimize the tr-channel DDR3 architecture you need DIMM modules placed in multiples of '3'. I.E. 3,6..etc. Once you fill 3 slots on the DX58SO, you are not left with many choices. Regarding the SATA ports on the Intel board, you can read this. Once the GPU is docked, some of the SATA ports are blocked out.
Overall, vs. the MSI board the Intel Board is:
1. Not well laid out.
2. Cluttered.
3. Not good chipset cooling.
4. OC is slightly difficult. Not impossible though.
Regarding difference between the MSI PRO and 'E' version. The latter offers Blu-Ray audio and better chipset cooling.
Also, in a prior post I mentioned that you might not be able to do 3D work with a gaming card. That too a measly HD5770. Are you sure, your 3D software will support/run flawlessly on a gaming edition card.
Old 24-03-2010, 08:11 PM   #30 (permalink)
PSN~ftw
NoasArcAngel's Avatar
^+1 even i would say that...@asigh that dude does not seem to be reading your posts
Phenom II x4 955 . MSI E-53 . 4GB DDR3 xms3 1600mhz . XFX HD 5770 1GB . NZXT M59 . Corsair VX 550 . Transcend 20 GB SSD.
PS3 slim 250GB
PSN fatalaurora Steam a_headshot
NoasArcAngel is offline
How to edit Build system paths in Visual Studio 2005 Pragadheesh Software Q&A 0 09-03-2010 03:05 PM
Please help in building a new rig: Urgent falling Hardware Q&A 36 07-02-2010 02:25 PM
Hi all :) I want to build a rig for Rs. 35000. papul1993 Hardware Q&A 5 09-12-2009 09:53 PM
Win XP SP3 Final (Expected this week) Yoda Technology News 9 20-03-2008 08:43 PM
- by c4u
