Old 23-03-2010, 01:02 AM   #1 (permalink)
Default Home PC for very basic gaming within 30k - please suggest
My uncle wants to buy a new PC for surfing, watching movies and playing some basic games. He was adamant on buying an i5 earlier but now seems to be willing to listen to reason and let go of that idea. Can you please suggest a PC for him keeping in mind the following things:
  1. Budget is around 30k.
  2. A 19" or 20" display will be preferred.
  3. Intel is preferred over AMD because of its availability here.
  4. A good UPS is also required.
  5. The motherboard should have a slot for graphics card, which will be added later.
  6. Is a good PSU required in this case? Even if he does add a gfx card later, it will be a very cheap one.
All suggestions are welcome. Also, is an i3 a good idea in this case? About RAM - should it be DDR3 or DDR2?
Intel core i5 750 with DP55WB mobo
4 GGB DDR3 RAM@1333MHz Transcend
CM Extreme Power Duo 600W
XFX GTS 250 512MB
Win XP Pro 32-bit
bippukt is offline
Old 23-03-2010, 08:59 PM   #2 (permalink)
Default Re: Home PC for very basic gaming within 30k - please suggest
Processor: AMD Athlon II X4 630: 5.0k
Motherboard: Biostar TA785G3 HD: 4.5k or MSI 785GN-E65: 5.6k or Gigabyte GA-MA785GMT-UD2H: 5.5k
Ram: Transcend 2 X 2Gb DDR3-1333Mhz C9: 5.5k
Hard Disk: Western Digital 500Gb Caviar Blue: 2.4k
Optical Drives: LG 22X SATA DVD-RW: 1.1k
PSU: FSP Saga II 400W: 2.1k
Cabinet: NZXT Gamma: 2k else CM Elite 310: 1.8k
Monitor: BenQ G2020HD 20" LCD Monitor: 6.5k
Keyboard Mouse: Logitech Internet Pro Desktop: Rs. 0.6k
Total: 29.5k. for mobo get the MSI or Biostar. both got 128Mb DDR3 sideport memory. will help in a bit of gaming. also share 512Mb ram with the graphics so if 32bit OS used rest of 3.5Gb used as ram.
also the PSU is low cost & can handle any sub 10k graphics card. more cheaper PSU not recommend.
Sam is online now
Old 24-03-2010, 04:21 AM   #3 (permalink)
Point Blanc
for monitor samsung or dell also would cost similar 500 bucks more
Samsung 2033SW 20" LCD Monitor @ 7.2k
rest is good. you will be adding taxes on most of the components, so you can reduce the price furthur by considering Athlon II X2 245 2.9GHz @ 3.1K for proccy, basic moderate gaming or movie watching and all wont get affected. for motherboard go for Gigabyte GA-MA785GMT-UD2H with good display options(HDMI), better power saving and connection ports like IEEE 1394 which is firewire, e-SATA ............................
---------- Post added at 04:21 AM ---------- Previous post was at 04:20 AM ----------
these suggestions are on Sam.Shab's above post.
acewin is offline
Old 24-03-2010, 08:14 AM   #4 (permalink)
15.0 GHz
VarDOS's Avatar
get this one
Processor : AMD Phenom X2 555BE
Motherboard : Biostar TA790GX a3+
RAM : Kingston Value Ram 2GB DDR3, 1333MHz
HardDisk : WD 500GB Blue AAKS 16MB Buffer
Cabinet : Cooler Master CM310
Powe Supply : Corsair VX450
Graphics Card : ASUS HD4850 1GB
LCD (Monitor) : Benq G2220HD
Keyboard + Mouse : Logitech Internet Pro
If you dont want GFX card remove it. The total rig costs 35k
VarDOS is offline
Old 24-03-2010, 07:45 PM   #5 (permalink)
actually i added 4% VAT on most of the products. so price got increase by ~1.5k. still the total cost should be within OP's budget.
Originally Posted by Varad Dilip Choudhari View Post
get this one
Processor : AMD Phenom X2 555BE ---> 5.2k
Motherboard : Biostar TA790GX a3+ ---> 5.8k-6k
RAM : Kingston Value Ram 2GB DDR3, 1333MHz---> 2.7k
HardDisk : WD 500GB Blue AAKS 16MB Buffer ---> 2.3k
Cabinet : Cooler Master CM310 ---> 1.8k
Powe Supply : Corsair VX450 ---> 4k
Graphics Card : ASUS HD4850 1GB ---> ~6.5k
LCD (Monitor) : Benq G2220HD ---> 7k
Keyboard + Mouse : Logitech Internet Pro ---> 0.6k
total is coming at around ~36k. way over OP's budget. add to it optical drive missing. total passed 37k now.
Sam is online now
Old 24-03-2010, 09:25 PM   #6 (permalink)
15.0 GHz
VarDOS's Avatar
^dude just remove the GFX card.
VarDOS is offline
Old 25-03-2010, 01:13 AM   #7 (permalink)
well still price will be high. cause i missed 1 thing, the monitor is the 22" FULL HD. costing about 7.5k. so going IGP means dropping the monitor to a smaller one, 20". & PSU to a bit cheaper one, FSP Saga II 400W. total will then be with OP's budget. but ultimately it becomes almost same as to what i suggested at the beginning.
Sam is online now
Old 25-03-2010, 08:09 AM   #8 (permalink)
15.0 GHz
VarDOS's Avatar
Here are the revised costs
Processor : AMD Phenom X2 555BE ---> 5k
Motherboard : Biostar TA790GX a3+ ---> 5.5k
Cabinet : Cooler Master CM310 ---> 1.5k
Powe Supply : Corsair VX450 ---> 3.8k
Total : 35k Approx.
There is no need for dropping the monitor size, cuz the motherboard can handle 1080p, also don't ever think to change the PSU, Corsair is FTW, and also has good efficiency and can maintain the system well balanced.
You can get the system below 30k, if u remove the GFX card. Or increase your budget by 5k and get this rig.
Visit my thread : How's this config?
VarDOS is offline
Old 25-03-2010, 10:51 AM   #9 (permalink)
Wise Old Ghoul
Piyush's Avatar
hey listen guys
he stated that he'll be going for intel not amd(availibility reason)
Piyush is offline
Old 25-03-2010, 11:40 PM   #10 (permalink)
Originally Posted by piyush120290 View Post
hey listen guys
I was looking for intel conf...and all the members posted AMD...amd...lol
Guys he's looking for Intel...go for it...
neerajvohra is offline
Old 26-03-2010, 01:12 PM   #11 (permalink)
Well, it is true that I was looking for an Intel config, especially an i3 config. But the AMD configs are not useless either. I will go and ask if they are available - i5 is too expensive and I assume that an AMD Phenom X4 will be better than an i3. The other components, especially the RAM, will remain the same irrespetive of Intel or AMD, right?
Anyway, if someone can suggest an i3 config as well (just the mobo+CPU+RAM), it will be very useful. There are only two types of i3 processors available, but I am not sure they are so different in their price. Also, I can't figure out a reasonable motherboard for them.
XFX GTS 250 512MB
Win XP Pro 32-bit
bippukt is offline
Old 26-03-2010, 03:50 PM   #12 (permalink)
stick with Intel Original mobos. they are cheap. & are easily avl. you'll loose IDE port + OC capacity.
Sam is online now
Old 26-03-2010, 04:16 PM   #13 (permalink)
15.0 GHz
VarDOS's Avatar
^ don't go with intel, better stick with ASUS. As said you will loose OC capacity + IDE port + bad customer service + low upgrade ability.
VarDOS is offline
Old 26-03-2010, 08:54 PM   #14 (permalink)
hansraj's Avatar
Most of the PC users today have been using the PCs for 5-10 years now and among them; almost everyone has realized that AMD is value for money. Its only a matter of pride (may be) and show off, to own a high cost Intel proccy but an old hand would vouch for AMD. AMD has come up very well.
Unless of course u r looking at the fastest available processor right now!!
With regards to availability of AMD it may not be avbl in the shelf as easily as intel ones but AMD Athlon II x 4 630 or 620 are becoming quite popular now and you may not have to wait long for it if u place an order.
"An eye for an eye leaves the world blind." - Gandhi
Athlon II X 4 620 Quad Core, Gigabyte GA-MA 785 GPMT, G-Skill DDR3 1333 Mhz 2GB X 2, Seagate 1 TB + Seagate 80 GB, Win 7 Ultimate 64 Bit
hansraj is offline
Share your Tweaking Tips here Raaabo Software Q&A 305 23-06-2011 09:53 AM
Suggest Cheap Gaming PC for Bulk buying Ricky Hardware Q&A 39 19-05-2010 09:51 AM
High end gaming & graphics machine - suggest config rajatrao PC Components / Configurations 30 27-03-2010 06:47 PM
hi, services in windows. legolas Software Q&A 11 22-04-2005 12:13 AM
help me wid win xp services... mohit Software Q&A 2 12-03-2005 09:53 PM
- by c4u
