Old 22-03-2010, 05:54 PM   #1 (permalink)
Default Suggest Cheap Gaming PC for Bulk buying
Hi,
I have been assigned a task of setting up low cost gaming arcade comprising of 10 terminals.
So now I need advice of TD members ..
Requirement is simple..
-->Should be able to play all famous latest games (no issue of quality.. but must be playable)
--> Cheapest possible PC Configuration!!
--> Thats it..
I went out and found that I can go for ..
Intel Dual Core 2.5 GHz.. (not c2d to cut down cost to half)
9400 series Card
1 GB RAM
250 HDD
17" or 19" Monitor
Can get above for Rs. 16-17K
But I am not sure as not in touch regarding latest offering and right price..
So kindly suggest.. if I can further get cheaper computer for this purpose, most probably task is to get each PC range of 15K ..
Can I opt for AMD as cheaper option and also use boards with decent onboard graphic options !!!
~Ricky
» Looking for someone to partner with me in Indian Linux forum
Free domain is available ! I am also at Indian Forums.
Ricky is offline
Old 22-03-2010, 08:08 PM   #2 (permalink)
Jaskanwar Singh's Avatar
Default Re: Suggest Cheap Gaming PC for Bulk buying
i think to play the latest games you need to exclude the monitor from your budget
---------- Post added at 08:08 PM ---------- Previous post was at 06:37 PM ----------
here goes the config -
Athlon II X2 240 2.8GHz @ 2.9K
ASUS m2n68-am plus @ 2.2k
A-data 2GB DDR2 800MHz @ 1.8k
XFX HD4650 512MB DDR2 @ 3.1k
Western Digital Caviar Blue 320GB @ 1.9k
FSP Saga II 400 Watts @ 2.3k
Cooler Master Elite 310 @ 1.5k
total - 15.7
Jaskanwar Singh is online now
Old 22-03-2010, 11:49 PM   #3 (permalink)
total - 15.7
little change:
ASUS m2n68-am plus @ 2.2k ---> graphics card extra.
XFX HD4650 512MB DDR2 @ 3.1k ---> better sparkle 9500gt 512mb @ 2.5k
FSP Saga II 400 Watts @ 2.3k ---> default psu
Cooler Master Elite 310 @ 1.5k ---> zebronics biji with psu @ 1.5k
skipping graphics card is not an option. IGP still lags a bit if playing latest games. a graphics card is very much necessary.
Sam is online now
Old 23-03-2010, 01:31 AM   #4 (permalink)
Thank you for the inputs.
Zebronics Bijli.. can you tell little more about its PSU power ratings ? Can it run 9500GT card effectively ?
Isn't there any option like mobo+graphic card combo with onboard dedicated graphics ?
~Ricky
Ricky is offline
Old 23-03-2010, 07:47 AM   #5 (permalink)
Crowman
Krow's Avatar
He suggested FSP Saga 400 Watts for PSU. It is 80+ efficient. Can run 9500GT very well.
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 23-03-2010, 04:51 PM   #6 (permalink)
PSN~ftw
NoasArcAngel's Avatar
Amd Athlon II x2 240 -> 3k
MSI K9N6PGM2-V Motherboard -> 2k
A-Data 2GB DDR2 RAM 800mhz -> 2k
Western Digital HDD 160GB -> 1.5k
Powercolor HD 4670 512MB GDDR3 -> 3.5k
Zebronics Bijli Pc case with 400w PSU -> 2k
Acer 15.6" X163WA LCD -> 4.5k
total : 19k
---------- Post added at 04:37 PM ---------- Previous post was at 04:36 PM ----------
dude for staying future proof for 1 year i suggest a 4670 , if you want to cut down get a minimum 9 series gpu / you can get a 8600GT 256MD GDDR3 for 3.5k
---------- Post added at 04:43 PM ---------- Previous post was at 04:37 PM ----------
---------- Post added at 04:51 PM ---------- Previous post was at 04:43 PM ----------
alternatively, why don't you send a e-mail to DELL or HP business solutions i am sure they would be ready to oblige and make you a good gaming pc for 20k ....@10 pcs
Phenom II x4 955 . MSI E-53 . 4GB DDR3 xms3 1600mhz . XFX HD 5770 1GB . NZXT M59 . Corsair VX 550 . Transcend 20 GB SSD.
PS3 slim 250GB
PSN fatalaurora Steam a_headshot
NoasArcAngel is offline
Old 23-03-2010, 06:27 PM   #7 (permalink)
there is but performance so bad that its better buy an ultra cheap mobo & get a better graphics card with the rest of money.
total : 19k
nice config. but screen will b very small. even if its square.
it'll run anything upto HD5770 or GTS250. & its a good company, Forton Power Supply (FPS).
Sam is online now
Old 27-03-2010, 06:09 PM   #8 (permalink)
Here we don't have 240 but some 525 with 7MB total cache memory
Also, they have iBall PSUs if asked for good one.
iBall standard 400 watt : Rs. 700
iBall Sprint 450 watt : Rs. 1800
..is that iball can be trusted ?
~Ricky
Ricky is offline
Old 27-03-2010, 06:23 PM   #9 (permalink)
525? whats that? heard Phenom II X2 545 only
iBall Sprint? better take VIP 400W Gold. it should cost 1.4-1.5k & is better than iBall stuff.
Sam is online now
Old 27-03-2010, 06:39 PM   #10 (permalink)
Crowman
Krow's Avatar
Considered buying the thing online? Where are you located Ricky? That may help a lot in locating a good dealer nearby.
Krow is offline
Old 27-03-2010, 09:47 PM   #11 (permalink)
Wise Old Ghoul
Piyush's Avatar
Hi,
--> Thats it..
9400 series Card
1 GB RAM
250 HDD
17" or 19" Monitor
take a look
amd 780 based mobo ~3.5-4k
transcend 2GB DDR2 800MHz @ 1.8k
till now its around 14k
for monitor increase ur budget a li'l bit and buy a 15/17 inch lcd
Piyush is offline
Old 28-03-2010, 01:42 AM   #12 (permalink)
Originally Posted by piyush120290 View Post
take a look
a 780G board will cost below 3.5k. a 785G will cost below 4k. i'll recommend a 785G, better avl. & also for HDD, he can get Samsung F3 Eco 500Gb for as low as 2k.
Sam is online now
Old 28-03-2010, 11:05 PM   #13 (permalink)
Wise Old Ghoul
Piyush's Avatar
well.. ok
but what about his budget?
its kinda difficult
Piyush is offline
Old 28-03-2010, 11:29 PM   #14 (permalink)
well.. ok
its kinda difficult
if he getting graphics card & as its for mass buying. i feel even 760G will suffix. 785G will have no good effect. also boards from Bio* cost pretty low. hif he get 10 bio mobo, he will may get each 760G mobo (old stock) for as low as 2k maybe. also X2 240 will cost low. say 2.7k/pps.
but the final conclusion is, a gaming pc for as low as 16k is impossible. he'll need 18k or more.
Sam is online now
Old 30-03-2010, 08:41 PM   #15 (permalink)
Here they say RAM is kind of costly these days, generic RAM is around 1100-1200 Rupees these days. I in plan to give a visit to Delhi to buy the stuff once its finalized.
Do you think Zebronic Bijli with PSU you can handle graphic cards as I heard that most of the card failures are because of poor PSU being used !
Also as suggested here .. integreted 785G chipset from AMD.. how are they compared to dedicated graphic card.. anyone with personal experience with both ?
Also, I see that a general board will cost around 2K + 2.8 to 3K for 9500GT card = around 5K
So spending 1K extra is worthy or should buy integrated solution ie. like 780G for Rs. 4K ?
~Ricky
Ricky is offline
Old 30-03-2010, 08:52 PM   #16 (permalink)
the 9500 gt is more powerful than the onboard hd3200 graphics of 780g chipset
---------- Post added at 08:52 PM ---------- Previous post was at 08:50 PM ----------
the Zebronic Bijli comes with 400W PSU which can handle 9500gt easily
Old 30-03-2010, 09:16 PM   #17 (permalink)
9500GT twice as powerful as 780G/785G (OC will bring about only about 25% better boost in performance). get as cheap 9500GT as possible. cause 1Gb version or even DDR3 versions cost more & don't justify performance with the added cost.
the 400W PSU not so good but not too bad that they can't even power a lower end card. will handle 9500GT or HD4670. also HD5670 & GT240. it can power upto a 9600GT (highly not recommended until & unless the card belongs to your enemy ).
Sam is online now
Old 03-04-2010, 03:41 PM   #18 (permalink)
bORn To RIse....
rahul.007's Avatar
just read all through.... i think you should go with9500gt.... you dont have too many options at this budget
phenom II 955 B.E 3.2 ghz(its hot) no more:mrgreen:|coolermaster hyper 212 evo:cool: | msi 790gx-g65|msi radeon hd6770:hyper: |corsair 2*2gb + kingston 2gb 1333mhz ddr3|seagate 500gb sata X 2, 1tb X 1|lg dvd|seasonic s12ii 520w:punch: |cooler master elite 310|cooler master 120 mm fans X 2|benq g2220 HD|logitech keyboard+mouse|Creative SBS A100|apc 550va|kodak c913|motorola fireXT:wink:
DO WHAT YOU THINK, BUT THINK BEFORE YOU DO.. :)
rahul.007 is offline
Old 15-04-2010, 08:34 PM   #19 (permalink)
Guys .. can anyone tell me current pricing for nehru place..
They are way high than suggested here:
Athlon II X2 240 2.8GHz + ASUS m2n68-am plus = 4870 (as expected )
But
9500GT 512 MB is asking Rs. ~3500 !!..
9400 1 GB for Rs. ~2600
What do you suggest.. I still have 1 week to make the purchase..
~Ricky
Ricky is offline
Old 15-04-2010, 09:25 PM   #20 (permalink)
But
its way too high. if u not mind buying online, may talk to MediaHome guys. if they got it on stock.
Sam is online now
Old 17-04-2010, 10:17 AM   #21 (permalink)
icebags's Avatar
don't forget abt the monitor itself ::
u should probably buy 15" (resolution 1024X768 is supported by all games - old or new) stuff and avoid buying anything of higher resolution that requires much graphic power.
also, its best if u as them what games they will play and check their normal requirements. if they later run CRYSIS in a 17/19" monitor @ 1440X900 and say its not running smooth, u will be in trouble.
icebags is online now
Old 17-04-2010, 03:39 PM   #22 (permalink)
I will not go less than 19" monitor but thats not a problem as games allow resolution settings, so will adjust them at playable settings... this is we mostly do if game do not run properly.. isn't !!
@SAM
At mediahouse website, they do have 9500GT but listed at Rs. 3500 , other things are more than market price.
~Ricky
Ricky is offline
Old 18-04-2010, 11:57 AM   #23 (permalink)
icebags's Avatar
Ricky-ji, most 19'' monitors have native resolution of 1440x900, u set any less resoltion and the picture will look wacky and stretched < > .
and always remember more resolution = you need more grafix power.
my 19" montor runs @ 1440x900 with a XFX 8800GT at the just "smooth" condition with some modern games at high settings. for ex. Devil may cry. crysis refuses to run that much smooth at ultra hi setting tho - FPS drops @ 17/18.
i just think you should check these stuff with customer. or customer may cry.
pls check those new 18.5" monitors those have native resolution of 1366 x 768. but idk if this resolution is supported by most games. check check !
Last edited by icebags; 18-04-2010 at 11:59 AM. Reason: no reason, no reason at all !
Old 18-04-2010, 09:04 PM   #24 (permalink)
+1. good point even i missed to mention earlier. Ricky its about consumer. so get 17" monitor or 18.5" with low resolution. else game will look UGLY.
Sam is online now
Old 19-04-2010, 09:08 AM   #25 (permalink)
Point Blanc
BTW, HD4670 is much better than 9500GT, so if you are pushing on getting nVidia think again.
acewin is offline
Old 19-04-2010, 08:06 PM   #26 (permalink)
OC'd HD4670 = 9600GT, which is 2 times faster than 9500GT, even the GDDR3 edition.
Sam is online now
Old 03-05-2010, 12:05 AM   #27 (permalink)
I made the purchase and settled with 9500GT(1GB) + amd II X2 250 + M2n68am Se2 + 2GB kingston RAM + 500W CoolerMaster PSU + WD 320GB hdd + Iball Cabinet .
However, slight mistake, instead of m2n68am Plus board , I purchased m2n68am SE2 .. means fewer ports and dimms .
Anyways, I noted it only after when all PCs were ready ...
Tat everything is working find except sound... Installed windows7, I can see that hd sound is listed in device manager and when installed included driver, its hows realtek hd sound but when I try to play any sound, windows says.. "no sound card found " !! This is problem with all system built.. !.. any solution ?
~Ricky
Ricky is offline
Old 03-05-2010, 01:21 AM   #28 (permalink)
shouldn't have bought the Extreme Power PSU. its not good. for that price many good options already available.
Sam is online now
Old 03-05-2010, 08:36 AM   #29 (permalink)
I thought coolermaster was good, besides it was the only option, rest were mostly unknown brands like icool, adcom but cheaper.
What do you think about the problem of sound in every pc ?
~Ricky
Ricky is offline
Old 15-05-2010, 05:57 PM   #30 (permalink)
Problem of sound solved, was merely about incompatible drivers !
~Ricky
Ricky is offline
Very high end configuration rig needed..Please suggest kanishka PC Components / Configurations 179 14-07-2010 07:00 AM
High end gaming & graphics machine - suggest config rajatrao PC Components / Configurations 30 27-03-2010 06:47 PM
Please suggest a Gaming Laptop for my budget prakum Hardware Q&A 10 23-03-2010 10:10 AM
Suggest a 19-20 inch LCD monitor for gaming meetdenis Hardware Q&A 6 13-03-2010 06:17 PM
Buying a new PC... need suggestions! rahul941400 Hardware Q&A 24 18-02-2010 04:21 PM
- by c4u
