Old 21-03-2010, 08:16 PM   #1 (permalink)
Tech Lover
sanads's Avatar
Default Please suggest cor2duo processor and motherboard & ram at 10k
Hello friends
I am sanjib I have bit of problem with heating problem of my old amd x2 4800+ processor after 1 and half hour it gets shutdown immidiately. so I am thinking to taking a new core2duo processor with motherboard and Ram. I had a zion 1gb ram 533 if it get work with new motherboard or also get a ram too.
please help me quick.
thanking all of u
sanads is offline
Old 21-03-2010, 08:33 PM   #2 (permalink)
Jaskanwar Singh's Avatar
Default Re: Please suggest cor2duo processor and motherboard & ram at 10k
amd heating problem is an old story
the processors that amd releases now do not heat much
please tell which psu and cabinet you use
for that budget you are better off with amd -
Athlon II X3 435 2.9GHz @ 4k
ECS A785GM-M @ 4.4k
Transcend 2GB DDR3 1333MHz C9 @ 2.5k
total - 10.9k
Jaskanwar Singh is online now
Old 21-03-2010, 08:45 PM   #3 (permalink)
Tech Lover
sanads's Avatar
I dont want amd please suggest intel pro
thanks Jaskanwar Singh
sanads is offline
Old 21-03-2010, 08:58 PM   #4 (permalink)
the intel config -
Core 2 Duo E7500 2.93GHz @ 5.1k
Jetway I43GM1-HG @ 3.3k
A-data 2GB DDR2 800MHz @ 1.8k
total - 10.2k
---------- Post added at 08:58 PM ---------- Previous post was at 08:56 PM ----------
but still i suggest amd one
Old 21-03-2010, 08:58 PM   #5 (permalink)
ECS A785GM-M @ 4.4k
total - 10.9k
+1. heating issues long gone & dead. & if he takes Core2Duo now it'll b like giving himself a punch.
Fore intel,
E7500 + G41 mobo will cost 8k. with 2k, get 2Gb ram. 1 stick. sell your old ram stick. still i telling you again, take Core2Duo or any Core2 proccy now & suffer later.
& yes the old X2's gets hot very much. & were very buggy. Athlon II X2 & even X3 are some of coolest processors in market.
Sam is online now
Old 21-03-2010, 09:00 PM   #6 (permalink)
amd is better performing
no heating issues please believe me
Old 22-03-2010, 03:44 PM   #7 (permalink)
Which cabinet and psu do you have?
Old 22-03-2010, 04:53 PM   #8 (permalink)
vndprkh.09's Avatar
Arrow Re: Please suggest cor2duo processor and motherboard & ram at 10k
Amd heating problem not gone yet..i too have the same problem...
what's the profit to go for a cheap over heating processor then a high budget cabinet to cool them..
╘•|paяakђ ∞┼ ČĴ ----------------๒๏гภ ╬๏ г๏ςк
vndprkh.09 is offline
Old 22-03-2010, 05:12 PM   #9 (permalink)
@vndprkh.09
WHICH PROCESSOR DO YOU HAVE?
---------- Post added at 05:12 PM ---------- Previous post was at 05:07 PM ----------
heating problem was with old athlon xp & x2 and not with newer athlon II x2 , x3, x4
Old 22-03-2010, 11:40 PM   #10 (permalink)
yup. the new Athlon II X2s are coolest proccies. much more cool than their Core2 counterparts.
Sam is online now
Old 23-03-2010, 01:18 PM   #11 (permalink)
Sami Hyypiä, LFC legend
Liverpool_fan's Avatar
Athlon X2 does not have heating problems either. Since the Hammer architecture, AMDs have absolutely no heating problems. Sigh it has been over 6-7 years since AMDs had those proccys having heating problems and still noobs call AMDs have heating problems. Sheesh! :/
Experience true education in Computer Science - http://www.udacity.com | http://www.coursera.org
Read before asking / messaging any moderator for any query: FAQ + answers for new members
Don't use forum for chatting. Visit http://webchat.freenode.net/?channels=krow, enter nick and connect.
Liverpool_fan is offline
Old 24-03-2010, 03:35 AM   #12 (permalink)
Point Blanc
if u want best performance for money amd wont disappoint you.
acewin is offline
Old 25-03-2010, 11:22 AM   #13 (permalink)
Wise Old Ghoul
Piyush's Avatar
Hello friends
thanking all of u
believe us bro
a lot has changed now
AMD processors are dominating the market right now
just because of their "value for money"
and dont worry about the heating conditions
it was a long time back that these proccy produced so much heat
Piyush is offline
Old 25-03-2010, 12:22 PM   #14 (permalink)
coolguy12374's Avatar
Guys my Athlon 5200+ too got heating issues and goes kapput.I am using ordinary I-Ball cabinet with SMPS.Is it coz of my smps or bugs in da procy.If i go for Athlon II X2 240,will the heating issues be still there or do i have to buy a new smps.Pliz suggest.
coolguy12374 is offline
Old 25-03-2010, 06:23 PM   #15 (permalink)
well except the top of the line AMD flagship cpu's i.e. Phenom II X4 955 & 965 BE. rest are pretty much cool. only they run hot. so you may decide go Athlon II X2's way without any bit of worry.
Sam is online now
Old 25-03-2010, 08:57 PM   #16 (permalink)
Ok i agree with you.Am planning to go for Athlon II X2 250.But do i need to change my smps?Will my ordinary iball 400w bundled with the cabinet sufficient to give the power requirements.I dnt want another procy dead.
Old 25-03-2010, 09:26 PM   #17 (permalink)
i not think X2 250 avl in india. & moreover its cost too high. passes even the X3's. better get X2 240 + VIP 400W or FSP Saga II 350W.
Sam is online now
Old 26-03-2010, 06:28 AM   #18 (permalink)
Tnx 4 da rep bt i think X2 250 is avl in india.Ceck dis link http://www.lynx-india.com/index.php?...tID=7475.Price dif betwen X2 240 n 250 is abt 300 rupees only so thought beter go 4 X2 250.
Old 26-03-2010, 04:11 PM   #19 (permalink)
oops. sorry missed it. so you getting X2 250 from lynx? also the PSU?
Sam is online now
Old 27-03-2010, 05:26 AM   #20 (permalink)
Yeah so wat are ur suggestions.
Old 27-03-2010, 11:19 AM   #21 (permalink)
if they giving good pricing, get it. for PSU, i not think you'll get VIP in lynx. & FSP maybe slightly overpriced. so, either get FSP from lynx or search VIP locally.
Sam is online now
Need Ra or Ram to Mp3 converter ismart Software Q&A 4 11-04-2010 02:04 PM
Upgrade within 10k? prankie Hardware Q&A 3 22-03-2010 06:38 AM
Suggest good phone @8K to 10k. sudhir_mangla Buying Advice 9 05-09-2009 09:42 PM
Suggest a mob for budget around 10k ymhatre Buying Advice 11 23-02-2006 08:14 AM
suggest me model 10k budget dotcommakers Buying Advice 20 16-12-2005 06:11 PM
- by c4u
