Old 21-03-2010, 07:14 PM   #1 (permalink)
D PrankMaster
prankie's Avatar
Default Upgrade within 10k?
Hi,
The Title says all. I already have decent SMPS+cabinet, monitor, speakers.. I need to upgrade the rest. I'm currently using sempron 2500+, I won't be gaming much. I just need a decent spec within 10k, soon, as I'll be buyin the system within 2-3days.
Plz suggest?
My Rig: AMD Phenom II 1090T | Gigabyte GA880GM-USB3| Sapphire HD6850 | 2x4GB Corsair Vengeance DDR3 1600Mhz | 2x500GB Seagate HDD | Silverstone Strider 500W | Alteclansing Octane 7 | Microsoft Natural Ergonomic 4000 | Logitech MX518 | Rantopad H1 | APC 0.6KVA
My Gadgets: Nikon D3100 | PSP1000 | XBOX360 20GB | Sansa Clip+ | Soundmagic PL50 | Meelectronics M9BK
prankie is online now
Old 21-03-2010, 09:31 PM   #2 (permalink)
Default Re: Upgrade within 10k?
AMD Athlon II X2 240 - 2925
Gigabyte AMD 785G mobo - 4450
2GB DDR2 RAM - 2150
DVD Writer - 1100
250 GB HDD - 1725
Total comes to 12.5k... If you want closer to 10k, you can go for mobo based on nVidia 6100 or GF7025 chipset which cuts down cost by about 2k...
Arun
sakumar79 is online now
Old 21-03-2010, 10:19 PM   #3 (permalink)
D PrankMaster
prankie's Avatar
What abt Intel C2D 5400? I think its more OC friendly and gives better bang for bucks.
Old 22-03-2010, 06:38 AM   #4 (permalink)
To the best of my knowledge, both perform reasonably similarly, but the amd mobos are more rich in features, esp with regard to gfx...
Arun
Free upgrade to 2 Mbps Airtel Broadband!! aashish.joshi Broadband and DTH 2 13-03-2010 10:40 PM
mobile under 10k coolnikk Buying Advice 1 26-02-2010 11:17 PM
PC upgrade under 15k vinyasmusic Chit-Chat 4 02-02-2010 10:03 PM
Windows 7 upgrade version: The dos and don'ts Gauravs90 Technology News 5 09-11-2009 11:02 PM
Budget PC upgrade under 10K ravikanth Hardware Q&A 5 21-09-2009 12:20 PM
- by c4u
