Old 21-03-2010, 12:29 PM   #1 (permalink)
Default DDR2 or DDR3? Is Price 2 Performance justified?
Hi Guys,
What would be the performance difference between 4GB DDR2 800 MHz and 4 GB DDR3 1333 MHz RAM on a exactly same Hardware Configuration (CPU, MB, GPU, HDD etc).
4 GB DDR2 800 MHz is approx 4550.00 rupees (Kingston)
4 GB DDR3 1333 MHz is approx 6200.00 rupees (Kingston)
Price difference between DDR2 & DDR3 is around 1650.
Is the 1650 more for DDR3 is worth the money?
Please let me know which one offers better price to performance.
Thank you,
Regards,
Akshara.
aksharatg is offline
Old 21-03-2010, 12:43 PM   #2 (permalink)
PSN~ftw
NoasArcAngel's Avatar
Default Re: DDR2 or DDR3? Is Price 2 Performance justified?
Dude , firstly you can't run the same DDR2 and DDR3 ram on the same mobo unless they have support for the different ram slots... secondly going with DDR3 has advantages which would include being future proof also DDR3 has performance difference against the DDR2 counterpart
Phenom II x4 955 . MSI E-53 . 4GB DDR3 xms3 1600mhz . XFX HD 5770 1GB . NZXT M59 . Corsair VX 550 . Transcend 20 GB SSD.
PS3 slim 250GB
PSN fatalaurora Steam a_headshot
NoasArcAngel is offline
Old 21-03-2010, 01:03 PM   #3 (permalink)
& 4Gb DDR3 from Transcend costs Rs.5200. so switch to Transcend will be better for OP. for such cost he will get G.skill or Corsair or Muskin.
Sam is online now
Old 21-03-2010, 01:08 PM   #4 (permalink)
Hi NoasArcAngel,
I completely agree with you that, there will be performance advantage in DDR3 compared to DDR2. My question was whether that performance advantage is worth the higher price tag.
There are mother boards that support both DDR2 & DDR3. U can use either use DDR2 or DDR3. But you will not be able to use both DDR2 & DDR3 together. Look at the below link.....
http://www.tomshardware.com/news/MSi...lots,7214.html
Regarding feature proof...... "If you have a 4GB RAM, then I don't see any necessity to upgrade the RAM in the next couple of years"....
Please correct me if I am wrong......
Thank you,
Regards,
Akshara.
Old 21-03-2010, 01:25 PM   #5 (permalink)
BE FREE
yep definitely there would be performance boost and future upgrade of rams depends on kinda applications one uses as for most common basic use 2gb ddr ram is more than enough however for high end gaming or graphics development or audio-video editing even 12gb ddr3 2000mz becomes less some times . so choose which suits your needs however stick to ddr3.
"To know that we know what we know, and to know that we do not know what we do not know, that is true knowledge." ~ Copernicus
azaad_shri75 is offline
Old 24-03-2010, 03:04 AM   #6 (permalink)
Point Blanc
which costs 2-3K more than normal boards having support for only one.
DDR3 is all its worth after the prices for it reduced last year, not much decrement in price for neither DDR2 or DDR3 after that.
acewin is offline
Old 24-03-2010, 08:49 AM   #7 (permalink)
15.0 GHz
VarDOS's Avatar
this is also the board which can support DDR2 and also DDR3
Asus P5G41C-M
VarDOS is offline
Old 24-03-2010, 07:24 PM   #8 (permalink)
+1. yes DDR2 & DDR3 supporting mobo cost more. so for that price, get a DDR3 only mobo & be futureproof & also save some money.
Sam is online now
Hardware Price Check and Buying Advice Thread (Kolkata) tkin Shopping 6871 Today 08:08 AM
HD4870 Sluggy Performance ???????? parimal_xp2003 Hardware Q&A 0 03-03-2010 02:56 PM
can i install DDR2 800 with 667 ? suhas_sm Hardware Q&A 7 02-03-2010 06:14 PM
Is my Mobo limiting my Proccy's performance? ajai5777 Hardware Q&A 7 28-02-2010 02:17 AM
Price of photoshop CS4 ra_sriniketan Software Q&A 3 09-02-2010 11:27 PM
- by c4u
