20-03-2010, 10:38 AM
Fullbring
Build My Rig...
Hi Guys,
Now only a few days left for new rig to come....
so i want frm all of u suggestions(which i need always most)
My Config will be:
1. Core i-5 750 2.66 - 10.2k
2. Gigabyte GA P55 US3L - 6k
2a. MSI P55 CD53 - 7.5k
3. Corsair 4GB DDR3 1333MHz - 6.5k
3a. Corsair 2GB * 2 DDR3 VS2GB1333D3 G - 5.9k
4. WD 500GB - rs2375
5. Corsair VX450 - 3.8k
5a. Corsair VX550 - 5k
6. Powercolor HD5770 v2 - 9.6k
6a. Sapphire HD5770 (juniper) - rs9750
7. CM Elite RC-330-KKN1-GP - 2k
8(optional): a external fan for better cooling
Total: rs 40375
Doubts: between 2 & 2a
shud i go with 3a...in dual channel mode
is 5 sufficient or 5a is required for my config...coz i want a smooth running system...
which is best 6 or 6a
will the step 8 is needed or some other tips for cooling...
is the step 7 ok....coz i cant increase my budget beyond 45k...
Hope 2 get good replies frm u guys...
Note: the shops i have shortlisted is E-Lounge,Primeabgb & mahavir...if u know ne other shop where i can get best deal pls tell...
20-03-2010, 11:06 AM
Sami Hyypiä, LFC legend
Re: Build My Rig...
I think a Phenom II config would be more value for money than Core i5
21-03-2010, 11:08 AM
PSN~ftw
Re: Build My Rig...
yea amd would be a better choice at this budget also you would need a external cooling fan ... make it 2 if you case supports it
---------- Post added at 11:07 AM ---------- Previous post was at 11:05 AM ----------
go for the cheaper motherboard and get good ram you can go for the MSI - 785G E-51 chipset for 4.5k with AMD.... and then get better performance ram for 6k or so
---------- Post added at 11:08 AM ---------- Previous post was at 11:07 AM ----------
a corsair VX 450 should be more than enough for the job, if you don't plan on upgrading.. but if you want you can be like me take a VX550 and then later upgrade to a HD 58xx series card
Phenom II x4 955 . MSI E-53 . 4GB DDR3 xms3 1600mhz . XFX HD 5770 1GB . NZXT M59 . Corsair VX 550 . Transcend 20 GB SSD.
PS3 slim 250GB
PSN fatalaurora Steam a_headshot
21-03-2010, 05:01 PM
Make Way the LORD is Here
Re: Build My Rig...
a phenom II rig is a much better choice at this budget
22-03-2010, 10:03 AM
Fullbring
Re: Build My Rig...
so will the phenm II rig performs better & a gud future proof config...
22-03-2010, 10:32 AM
PSN~ftw
Re: Build My Rig...
Duh... dude a phenom II will perform better + you can get better DDR3 ram like 1600mhz or so...
PS3 slim 250GB
22-03-2010, 10:39 AM
Fullbring
Re: Build My Rig...
confusing.....confusing....
but i dnt think 1600Mhz will boost in performance difference as compared with
1333Mhz
i was getting G-Skill 1600Mhz @6.5k in primeabgb...
22-03-2010, 11:45 AM
Crowman
Re: Build My Rig...
Please post a link to any comparative review when making statements like these. Also, kindly avoid generalising. Perform better in what sense? From the reviews I see, the i5 is better at video encoding, consumes lesser power, is marginally better at gaming, way ahead in synthetic benchmarks, but may lack an upgrade path.
http://www.techspot.com/review/193-i...750/page7.html
22-03-2010, 01:25 PM
Fullbring
Re: Build My Rig...
Oh...so can i stick with i5...after so much of discussions with asigh,topgear,desiibond...i've selected core i-5...& now they r confusing....me...
ne ways krow wat u think abt my above post...ne changes...
22-03-2010, 06:09 PM
Re: Build My Rig...
if i5, take 1600Mhz rams, then memory won't come on your way if you OC your system. for Phenom II, 1333Mhz will do as stepping the multiplier up, got no relation with memory speeds. so 1333Mhz value ram is same.
for cabby, take NZXT Gamma or some cool cabby. Cooler Master Elite has got too old & too common. all looks same. yaak. & 1 fan? only? if i were you, i'll fit in 3-4 fans. such good config & 1 fan. also you not getting a heatsink, which means you won't OC for now, at least. rest everything as you wish. still for future upgrade, Phenom II X4 + 790GX looks very good.
22-03-2010, 07:30 PM
Fullbring
Re: Build My Rig...
I wont overclock...
will NZXT Gamma be in my budget....???Cooler Master Elite is good
& how much will 3-4 fans costs?
Btw by default we have 3 fans ryt...1 PSU + 1 GCard + 1 CPU + 1 Side fan
extra fans r needed by how much ?
22-03-2010, 11:14 PM
Re: Build My Rig...
I wont overclock...
well Gamma should cost 2.1k if ordered from Prime or Lynx. & i read many many reviews. its totally flawless & must say, gamers delight. i got capacity to add 5 fans but not need to fit all. the style bring to mind of a delicious gaming rig, maybe not from Alienware. but surely a descent gaming rig.
hahaha, you rite. already got 4 fans. well 3 of them are private property. still PSU fan can work as exhaust provided you fit extra fan to keep the inside air cool so PSU not heat up badly. proccy fan is useless for other stuff. graphics card fan i can't comment. not own one. so to save money i'll recommend 1 front 120mm-140mm intake fan. a side 80mm intake fan. & PSU fan as exhaust.
Xigmatek 120mm Orange LED fan: 450. same for cooler master fans.
Sunbeam 120mm fan LED:350-450.
NZXT 9 blade non-led white 120mm fans: ~450 (best, looks cheap).
23-03-2010, 07:59 AM
Crowman
Re: Build My Rig...
IF fans are needed, then look no further than:
Cabinet fan: Scythe Slipstream SFF21G 120mm. [Best CFM vs noise ratio]
Heatsink fan: Delta AFB1212HHE 120mm. [Brought down temperatures on my TRUE by 15 degrees, but is noisy.]
Don't buy LED fans, except when you want to go bling bling. Performance matters more.
---------- Post added at 07:59 AM ---------- Previous post was at 07:52 AM ----------
Both should not cost more than 550 bucks.
23-03-2010, 09:48 AM
Fullbring
Re: Build My Rig...
ok i will add one side fan so total 4 fans now....
does NZXT gamma comes with transparent sidepanel if not then no use
of LED fans normal fan will do...
thanx
do i really need 2 go with 1600Mhz RAM instead if 1333Mhz...coz i was getting 4GB 1600Mhz G-Skill
Ram frm prime..& they told it was the cheapest in RAM...????wat u say...
& well i have CRT monitor....so i will need a DVI to VGA converter coz i guess 5770 wont have dat..
@sham.shab : is this the cabinet u r saying...
but i dont like its front side...looks awkward to me....
24-03-2010, 09:45 AM
Fullbring
Re: Build My Rig...
Whaaaatttt...no replies..no suggestions...
pls guys...read my above posts & comment on dat...
so dat i can build a best config for my needs...
30-03-2010, 11:08 PM
Re: Build My Rig...
if you wish to OC. else no.
should have created the thread on Q&A, rather than here. anyway it looks cool. however personal choices depends. ok made a list of cabbies avl under 3.8k for u (me2 actually).
Collermaster Elite 360 Rs :1908/- (no fans included) ---> fully black. looks cool.
Coolermaster Elite 342 Rs :1964/- (1X120mm front fan)
NZXT Gamma Rs :2030/- (1X120mm rear fan)
Coolermaster Elite 341 Rs :2019/- (1X120mm rear fan)
Coolermaster Elite-331 Rs :2132/- (1X120mm rear fan)
Coolermaster Elite-333 Rs :2132/- (1X120mm rear fan)
Thermaltake WING RS101 Rs :2205/- (1X120mm rear fan)
Thermaltake WING RS201 Rs :2310/- (1X120mm rear fan)
Thermaltake Matrix Rs :2573/- (1X120mm rear fan)
Thermaltake Wing RS301 Rs :3045/- (1X120mm rear fan)
Antec TWO HUNDRED AP Rs :3310/- (1X120mm fan + 1X140mm top) ---> check once.
Coolermaster Gladiator 600 Rs :3535/- (1X120mm LED+ 1X140mm top)
NZXT M59 Rs :3750/- (1X120mm LED side, 120mm front, transparent side) ---> gamma + style + side panel + 1 LED fan.
31-03-2010, 08:52 AM
Wise Old Ghoul
Re: Build My Rig...
buy any cm elite series cabby
almost same
go for vx 550W (future proof)
for proccy:i'l suggest u to go for phenom 955/965(more value for money than core i5)
31-03-2010, 09:39 AM
#19 (permalink)
Fullbring
Re: Build My Rig...
Thanx Sam....
But which one shud i buy....
02-04-2010, 01:55 AM
#20 (permalink)
Re: Build My Rig...
Thanx Sam....
both almost same. consider warranty + the heatsink. even if u don't OC the card, a good heatsink is an added bonus. specially if the fan is silent one.
02-04-2010, 09:44 AM
#21 (permalink)
Fullbring
Re: Build My Rig...
hmmm...
& i have CRT monitor so is DVI to VGA adapter provided with 5770 or i have 2 buy a separate one???
02-04-2010, 12:07 PM
#22 (permalink)
Re: Build My Rig...
hmmm...
won't u change monitor?
well, Sapphire always provide all connectors with its card. even the low end ones. just check its website once. it should provide i feel
no idea about PowerColor though. BTW, why u not considering XFX? they too have HD5770 i think. however will surely cost a tad more.
02-04-2010, 03:05 PM
#23 (permalink)
Crowman
Re: Build My Rig...
^XFX RMA is by Rashi Peripherals. Avoid it at all costs.
02-04-2010, 10:32 PM
#24 (permalink)
Re: Build My Rig...
oh yes. DAMN. thanks a lot krow. totally forgotten it  Rashi the worst dealers of pc peripherals & components.
03-04-2010, 09:20 AM
#25 (permalink)
Fullbring
Re: Build My Rig...
ok....well i have 2 use my gOOd old LG CRT for atleast 6-7months more....after dat hunt for LCD...
20-04-2010, 09:03 AM
#26 (permalink)
Fullbring
Re: Build My Rig...
hi guys...the time has come..
this friday i m goin 2 LT road for the ultimate config....buy...
wish me luck dat i get the best deal....
currently i will buy VX450 but can it handle two HDD + HD5770 + other
essential parts....???? or shud i buy VX550 to b more future proof
@asigh: I m not jokin i m goind this friday......for sure....
20-04-2010, 12:11 PM
#27 (permalink)
Team Digit
Re: Build My Rig...
The VX450 will do just fine. I don't know what you mean by essential parts but I sure hope it doesn't mean a second 5770
21-04-2010, 12:21 AM
#28 (permalink)
Re: Build My Rig...
should work just fine, provided as cyberjunkie told, essential parts = i5 + mobo + ram & so. not another HD5770.
21-04-2010, 09:17 AM
#29 (permalink)
Fullbring
Re: Build My Rig...
oh ya thanx..i will surely post the config & its prices after friday,,,,
25-04-2010, 11:12 PM
#30 (permalink)
Re: Build My Rig...
friday came & went. now come on. post the prices.
