Old 18-03-2010, 01:21 PM   #1 (permalink)
GhostRecon's Avatar
Smile TV Tuner for LCD - Suggestion Plz
Hi Guys,
I'm looking for a good TV tuner card for my BenQ 22 inch LCD monitor...
My budget is Rs. 2000-2500 (max)
The card should be able to record shows in good resolution and should give good picture quality in LCD.
Also please suggest whether I should go for internal or External
I'm from Kolkata.
Thanks in advance.
AMD Phenom II X4 925 2.8 GHz | MSI 785GM-E51 | Corsair 2X2 GB 1333MHz DDR3 RAM | Corsair VX550 PSU | BENQ G2220HD 22 inch LCD Monitor | Sapphire Radeon 5770 | Segate 500GB | LG 22X Writer
GhostRecon is offline
Old 18-03-2010, 04:22 PM   #2 (permalink)
Point Blanc
Default Re: TV Tuner for LCD - Suggestion Plz
internal will cost lesser than external.
check this link http://lynx-india.com/index.php?categoryID=458&show_all=yes
internal ones will come out to be more powerful in recording than external.
There is only Hauppauge given on the site which is above 3K
acewin is offline
Plz help to store data to avoid loss.. kelton Hardware Q&A 14 10-05-2010 05:48 PM
is it good deal?,reply fast plz. jigu Hardware Q&A 6 19-02-2010 01:25 PM
plz help buying a pc ?? dmanojkmr Hardware Q&A 0 05-02-2010 06:00 AM
FRONTECH tv tuner card - stuck lost - urgent help needed sincereheart QnA (read only) 8 27-08-2008 01:37 PM
linux suggestion for tv tuner card anarchist Open Source 13 12-03-2008 04:03 PM
- by c4u
