Old 16-03-2010, 07:23 PM   #1 (permalink)
Question hard disk crash problem
today i got an error "non system disk replace the disk and press enter"i understood that somehow i have lost my windows when i tried to reinstall xp i saw that even all my partitions were gonewhich means that i have lost all my datai created the partition from there only that is from windows xp's cd only and tried to install on it on c drive but it gave an error that it was not able to copy some filei tried installing xp from that cd on my friends computer and it got installed successfully which means that my hard disk has crashedso pls tell me how to repair iti dont want any recovery of my data i only want my hard disk to be repairedso pls help me out...............
anant197 is offline
Old 16-03-2010, 07:46 PM   #2 (permalink)
Democracy is a myth
rhitwick's Avatar
Wink Re: hard disk crash problem
U've done three mistakes,
1>Mis-interpretation of the error message: That error doesn't mean ur XP is gone, it CAN also mean some loose cable, RAM issue etc. If posted at the first time, I would have asked you to try those first. Re-install comes at the last phase of sorting a windows issue
2>Format error. While formating and creating partitions u've wrongly (I guess so) selected large disk support or something similar which takes the whole drive and installs OS.
3>Actually formating it rather trying to recover ur data first. U should have tried recovering ur data first rather just re-installing OS.
What u should do now.
1>Forget about recovering ur data. They are gone!
2>Unplug all cables that goes into ur HDD, DVD Writer etc and re-connect
3>Change RAM slots.
4>Remove CMOS battery and reinsert after a while (2-3 mins)
5>Clean ur DVD ROM lens.
Best of luck.
P.S. Ur HDD has not crashed yet.
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is offline
Old 16-03-2010, 09:33 PM   #3 (permalink)
PSN~ftw
NoasArcAngel's Avatar
Default Re: hard disk crash problem
1st. IF .... there was a RAM issue the pc would give 3 beeps and not boot up...at all
2nd. this happens only if you have a corrupt hard disk . a trashed boot loader or a non-bootable drive in the primary boot up drive
3rd. to fix this try running the pc without any disk / floppy drives in your pc .. if the problem still persists... get a windows cd run recovery mode and type fixmbr in the command prompt
if all fails ... your hard disk has gone kaput ... additionally as a safety measure make sure you check the Booting options from your Motherboard BIOS
Phenom II x4 955 . MSI E-53 . 4GB DDR3 xms3 1600mhz . XFX HD 5770 1GB . NZXT M59 . Corsair VX 550 . Transcend 20 GB SSD.
PS3 slim 250GB
PSN fatalaurora Steam a_headshot
NoasArcAngel is offline
Old 17-03-2010, 07:57 PM   #4 (permalink)
The Tech Enthusiast
well you can still recover your data if you've formatted the drive, Try EASEUS. Works very well but you gotta pay for full functionality. make sure you rule out simpler possibilities before you jump to formatting next time!
Intel DG43GT
Intel C2D E7400
Kingston 800mhz 4GB RAM (Dual Channel)
Palit GeForce GTS 250 512mb
Seagate ST3320613AS
CM Extreme Power 500W
CM Elite335
Windows 7 x86
piyush2202 is offline
hard disk partition problem mind021 QnA (read only) 3 01-09-2007 07:51 PM
10 reasons why PCs crash U must Know looksvivek Tutorials 18 03-07-2007 11:26 PM
Hitachi Travelstar Hard Disk Problem codeash Hardware Q&A 2 15-08-2006 08:00 PM
PROBLEM WITH HARD DISK coolrupesh Software Q&A 1 01-11-2005 12:40 PM
ULTIMATE HARD DISK SETTINGS - brain racking question sincereheart QnA (read only) 6 16-10-2005 12:53 PM
- by c4u
