Old 16-03-2010, 03:12 PM   #1 (permalink)
Default Please suggest a Gaming Laptop for my budget
Hi
I am looking for Gaming Laptop. My budget is 30K extendable to 35K.
Please suggest a Lappy which has powerful Processor, Fast & Plenty Memory, Beefy Graphics Card, Fully Reliable Motherboard. Tough Build Quality, Excellent Service & Customer Care Support would be added advantage.
Thanks in advance
prakum is offline
Old 16-03-2010, 03:28 PM   #2 (permalink)
PSN~ftw
NoasArcAngel's Avatar
Default Re: Please suggest a Gaming Laptop for my budget
Dude i would recommend you buy a desktop pc in that budget... you can get a laptop for that much but dont expect it to play with eye candy turned up and high resolutions decide
---------- Post added at 03:27 PM ---------- Previous post was at 03:19 PM ----------
here are your options they are on the higher side of your budget though ...
---------- Post added at 03:28 PM ---------- Previous post was at 03:27 PM ----------
NEW Dell inspiron 14. for 35k exact + 1k shipping and other levies
Phenom II x4 955 . MSI E-53 . 4GB DDR3 xms3 1600mhz . XFX HD 5770 1GB . NZXT M59 . Corsair VX 550 . Transcend 20 GB SSD.
PS3 slim 250GB
PSN fatalaurora Steam a_headshot
NoasArcAngel is offline
Old 16-03-2010, 08:06 PM   #3 (permalink)
Reverse Engineering rocks
Sid_gamer's Avatar
In that budget you can't expect to go full guns for gaming....
You'll get a nice desktop in that budget as far as gaming is considered but as your requirement is a lappy then Dell Inspiron 14 which NoasArcAngel already suggested is good to go..You can customize it according to your needs on Dell's Website....
---------- Post added at 08:06 PM ---------- Previous post was at 07:56 PM ----------
Hey Noas, what version of Dell Inspiron 14 did u suggest him (the core i3 or the core 2 duo)...coz there are at least 3 to 4 versions of this lappy on Dell's website..
i7-920|DFI LanParty DK X58-T3eH6
G.Skill-1600MHz,2Gbx3|ZotacGTX260 AMP2
Seagate 1Tb|CM Silent Pro M600
AOC-2236vW-Full HD|LG DVD/RW
Altec Lansing FX3021|MX-518
Delux DLC SH-490|CorsairH70
Sid_gamer is online now
Old 16-03-2010, 09:15 PM   #4 (permalink)
PSN~ftw
it is this one :
the one with core i3 and 2gb ram and a ATI HD 4330
PS3 slim 250GB
Old 17-03-2010, 11:42 AM   #5 (permalink)
Sid_gamer's Avatar
Yeah, better he goes for core-i3 rather than going for Core 2 Duo though...
Old 17-03-2010, 06:33 PM   #6 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
a 35K lappy budget for gaming is really tough (I hv SONY VAIO E SERIES, 48K price with corei3-330M, ATi 5650 1GB) and even then i never expected to play crysis at the highest max settings (Even many PCs fall to their knees doin tat..lol..) but my gameplay is smooth at fullHD reso of 1920x1080 and i love it..
if u can extend ur budget then u can get ACer 5740 wich has gr8 features..
Cheers n e-peace....
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 17-03-2010, 07:43 PM   #7 (permalink)
The Tech Enthusiast
you'd be really hard pressed to find a gaming notebook for 35k......
get yourself a good desktop and you'd be thanking yourself for it.......
@ashu: HD 5650 should handle Crysis very well man! I play Crysis on 1440x900 All settings maxed, No AA, No AF with a FPS of around 34 avg fps on a GTS 250 512mb (Overclocked).
Intel DG43GT
Intel C2D E7400
Kingston 800mhz 4GB RAM (Dual Channel)
Palit GeForce GTS 250 512mb
Seagate ST3320613AS
CM Extreme Power 500W
CM Elite335
Windows 7 x86
piyush2202 is offline
Old 17-03-2010, 11:19 PM   #8 (permalink)
aah, i see,well yup today i was playing crysis warhead on Gamer settings (wich was optimally selected by the in game option) so i guess since im playing on 1920x1080 reso so maybe tats the case im stutturing (in frames) a bit, i guess i shud lower down the reso to 1600'ish and keep the settings at gamer levell,,wat u say..??
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 18-03-2010, 10:01 AM   #9 (permalink)
The Tech Enthusiast
Yeah you could try that. Try keeping the AA off too. To be very frank, you practically don't see much of a difference until you keep AA more that 4x. I don't have Crysis Warhead actually, I have the original Crysis so I really don't know what changes Gamer settings have.
You could also try the following:
Turn On Trilinear Optimization
Turn On Triple Buffering
It improved my frame-rate a bit.
Intel DG43GT
Intel C2D E7400
Seagate ST3320613AS
CM Elite335
Windows 7 x86
Old 18-03-2010, 09:41 PM   #10 (permalink)
ooh is it..??? i thought tat turning them OFF wud be good. neways will try that and post my results... thanx again for the tip..
also, u play it on a PC or a lappy.. ??? (crysis i meant)..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 23-03-2010, 10:10 AM   #11 (permalink)
The Tech Enthusiast
Sorry for replying late, have my exams going on at the moment!! I play Crysis on a PC. If I had to use a laptop for gaming i wouldn't touch anything short of Alienware. Other laptops heat up on load and don't have even half the power of what an Alienware has to offer. Plus, my PC came for half the price of the cheapest Alienware laptop, so I'm sticking to PC for now!
Intel DG43GT
Intel C2D E7400
Seagate ST3320613AS
CM Elite335
Windows 7 x86
please suggest laptop < 35k sharma_atul85 Hardware Q&A 8 08-02-2010 08:26 AM
Suggest a Laptop. Budget 50K. freakitude Laptops and Netbooks 20 19-03-2008 08:16 PM
Please suggest a laptop in 50 K range... ~Phenom~ Laptops and Netbooks 15 30-10-2007 03:44 PM
A sub-30k Laptop ...? con_tester Hardware Q&A 9 30-12-2005 03:04 PM
- by c4u
