in this budget nuthing beats Sandisk Sansa Clip+. A tiny Match box size MP3 player with a micro SD card slot for memory expansion (upto 32 GB) and superb sound clarity.
Wats the Favourite Mathematical Function of DIGIT FORUM ????
Its "A SINE WAVE" constant
Y ??
They Both keep going "UP AND DOWN, UP AND DOWN............" !!!!!!!!
Last time i checked Sansa MP3 players were not available in india!!! I am have iPod classic n Cowon iAudio 7 pair them with a good set of headphones and both sound more or less the same... Audio quality is great. But when it comes 2 features u name it n iAudio has it all, it supports all de famous audio formats, has sound n Fm recording, lyrics support and above all de battery life is almost 3 times that of de iPod!
buy anything but an ipod. their batteries die out in just 1 year and need replacement, which is expensive and can only be done by them.
Who said that ???
I have a 6 yr old Nano and a 2yr old iPod touch still giving good backup times and needed no replacement till now not a single part. Many of my cousins and friends own them no one has replaced battery as far as I know.
Please don't bash some product just because you have to say something. Use it and if you had any problems then bash it.
ipods tend to be a tad overpriced. Sansa Clip + Creative EP630 and you've got your best travel companion. Superb sound quality, radio, expandable memory and a screen. A steal if you ask me!
Intel DG43GT
Intel C2D E7400
Kingston 800mhz 4GB RAM (Dual Channel)
Palit GeForce GTS 250 512mb
Seagate ST3320613AS
CM Extreme Power 500W
CM Elite335
Windows 7 x86
