Old 13-03-2010, 12:13 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Default Dell Inspiron 1525 battery replacement doubts
Hi all
I have a two year old Dell Inspiron 1525 laptop. For the past couple of months, the battery has begun to seriously deteriorate in performance... If the laptop is switched off with full power, by the time I boot, only 5 minutes is now available before it turns off...
Hence, I am looking at replacing the battery. The following are my doubts
1. The laptop was purchased in the US. Will there be any difficulty getting replacement battery here?
2. Should I contact Dell or will local stores have replacements?
3. Will it be possible to go for 9 cell batteries for improved battery life?
4. Can power surges affect battery life? Is it necessary to connect the power through a surge protector?
5. More often than not I use the laptop when connected to power, but regularly I need to work without power. Hence, I cant remove the battery as recommended by many. Is it better to have the power always on or regularly discharge the batteries?
6. I am thinking of getting a cooling pad to improve battery heat dissipation. I want one that is cheap (less than 1000 preferably) and effective. Please suggest brand and model along with approximate cost.
Thanks in advance
Arun
sakumar79 is online now   Reply With Quote
Old 17-03-2010, 07:00 AM   #2 (permalink)
Default Re: Dell Inspiron 1525 battery replacement doubts
Bump... 40+ views but not even one reply for even one of the points? Guys, please help...
Thanks in advance
Arun
Old 17-03-2010, 10:05 AM   #3 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
No . The same model is also available in India if I recall right.
I would go with Dell personally although a local dealer should be able to procure the same part if he sells Dell products as well.
Yes there is a nine cell battery series which can be used for extended battery life . however at the expense of an increased size.
I do but I cannot answer this for sure. I guess its better to be safe than sorry.
This is a Myth. This may have been true for Ni-Cd batteries. However it is not for Li-Ion Batteries. However it is still recommended to do partial discharges and once in a while so that the indicators on your laptop depict the amount of charge remaining correctly.
Id be wrong to suggest you one here since I don't use one personally .However check out ebay and you will find alot of models for you to pick from. Probably you could google the model types to see for good reviews .
Cheers.
FilledVoid is offline   Reply With Quote
Old 17-03-2010, 05:09 PM   #4 (permalink)
I have enquired with Dell and they said 6-cell battery costs 4.8k with immediate availability while 9-cell battery costs 7k with about 2 weeks waiting time. I have asked for 9-cell itself and they said they will contact as soon as it is available in stock...
So, now, main thing I need is advice regarding cooling pads...
Arun
Old 28-07-2010, 03:49 PM   #5 (permalink)
Living to Succeed
ajayashish's Avatar
i will suggest you to go to Ebay and buy from there. I have a E1705 purchased from US and the battery was dead. I contacted the dell store and they said 7k for a 6 cell battery. I looked on Ebay and purchased one for 2.4k. It works like charm and gives me a backup of around 1:30 mins... rememeber mine is a 17" so backup is less.
I suggest for for ebay and then make the decision.
Q6600+Abit IX38QuadGT+Corsair 4gb 800mhz+ Ultra 120 Extreme+ tagan 600wts+CM690
Alienware M15 - with Gforce 460 1.5gb + 8gb DDR + i7 1.73ghz
ajayashish is offline   Reply With Quote
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/125060-dell-inspiron-1525-battery-replacement-doubts.html
Dell Inspiron 1525 charger, problems, laptop, power cord, battery, manual, specs, battery not charging, review This thread Refback 22-01-2011 02:24 AM
Urgent please suggest (Acer 5740/Dell Inspiron/ Dell Stuido15 )??????? phanisrinivas Hardware Q&A 11 19-04-2010 02:17 PM
New Dell Inspiron 15 reddick Buying Advice 28 22-02-2010 07:39 PM
Can i use a compatible battery with my dell 6400? krazineurons Hardware Q&A 1 23-01-2010 10:42 PM
Buying New Laptop: ~30K Budget MetalheadGautham Laptops and Netbooks 42 28-12-2009 01:55 AM
- by c4u
