Old 12-03-2010, 09:41 AM   #1 (permalink)
Default Motherboard for Intel C2D E8400?
Very dated processor, but can anyone pls suggest a good motherboard for this? My ealrier board( I-bit Pro 35, i guess) conked off and want to replace. Thanks
azad is offline
Old 12-03-2010, 11:45 AM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: Motherboard for Intel C2D E8400?
Will you OC..?
asingh is online now
Old 12-03-2010, 11:57 AM   #3 (permalink)
Reviewerus Prolificus
What's your budget? Biostar Tpower P45 might be a good replacement, given that it's an older rig and I assume you wouldn't want to waste too much on a high-end board. This board should be around the 5.5~6K mark.
CPU: Intel Core 2 Quad Q9650 (Ultima 90i cooled)
Mobo: ASUS P5K Deluxe
RAM: OCZ XTC PC8500 4x1 GB - 1066 MHz @ 5-5-5-15
Graphics: ZOTAC GeForce GTX 285 AMP! @ 700/2600 MHz
Storage: 1 TB WD Black + 500 GB WD 5000AAKS
OS: Windows Vista Ultimate x64 (genuine)
SMPS: Corsair HX 850W
Speakers: 'Sangram' modded Altec MX 5021
Cabinet: Lian Li A71F
Display: ViewSonic VX 2025 WM
Lucifer is offline
Old 12-03-2010, 12:08 PM   #4 (permalink)
+1. Biostar T-Power P45 excellent board. should get for even below considering its old stock now.
Sam is online now
Old 12-03-2010, 04:14 PM   #5 (permalink)
Reverse Engineering rocks
Sid_gamer's Avatar
Biostar T-Power P45 is a great board for the E8400....It even had a good rank in the digit test...
i7-920|DFI LanParty DK X58-T3eH6
G.Skill-1600MHz,2Gbx3|ZotacGTX260 AMP2
Seagate 1Tb|CM Silent Pro M600
AOC-2236vW-Full HD|LG DVD/RW
Altec Lansing FX3021|MX-518
Delux DLC SH-490|CorsairH70
Sid_gamer is online now
Old 14-03-2010, 12:33 PM   #6 (permalink)
thanks all, but one problem i hadnt thought about - Will not be able to able to use earlier Vista/hdd with my new motherboard, i have too much data on my hdd and cannot format. Any suggestions/workaround to this ?
azad is offline
Old 17-03-2010, 07:16 PM   #7 (permalink)
The Tech Enthusiast
If you have any external hdd with you, you could install any old linux distro on a USB stick and backup your data on the external drive before you format your drive. Alternately, you could take your HDD to another computer and backup your data there.
Intel DG43GT
Intel C2D E7400
Kingston 800mhz 4GB RAM (Dual Channel)
Palit GeForce GTS 250 512mb
Seagate ST3320613AS
CM Extreme Power 500W
CM Elite335
Windows 7 x86
piyush2202 is offline
Motherboard? aabcrescent Hardware Q&A 0 17-02-2010 03:41 PM
BIOS updates - How to recover sagargv Tutorials 16 22-03-2006 09:35 AM
Built ur own pc. rajas700 Tutorials 3 10-09-2005 09:33 AM
- by c4u
