Old 11-03-2010, 11:43 AM   #1 (permalink)
Default Amd a2 x4 630 / p2 x2 555 be???
pals....
my mobo is ASUS M4A78-E
3GB DDR-2
USAGE:- Photoshop CS2 + ACDSEE 10 (12 HRS NON-STOP USAGE DAILY)
needed a right procy.....
AMD A2 X4 630 / P2 X2 555 BE???
which 1 will be better 4 my usage.... as it is.....without OC.
and which cooler would be good (max budget :- 1500rs)
and if i plan 2 unlock the 555...???
buyin on 15th so needed help urgent..
thanx
angel
The Day Walker! is offline
Old 11-03-2010, 01:58 PM   #2 (permalink)
Default Re: Amd a2 x4 630 / p2 x2 555 be???
X2 555 & X4 630. both are AM3 proccies. may need a bios update for the board.
get X2 555. for cooler, if u go for X4 630, stock cooler more than enough. for X4 B55 (X2 555 unlock) u may need a better cooler. something like CM TX3(Rs.1300) or Scythe Katana3 (Rs.1600). or may instead u may try running at lower voltage. so temp wil b low. so u may avoid a OEM HSF all together.
Sam is online now
Old 11-03-2010, 03:30 PM   #3 (permalink)
Jaskanwar Singh's Avatar
@ sam
won't he benefit by X4 630 because he uses photoshop and photoshop benefits from 4 cores
it is not a guarantee that his X2 555 will unlock to 4 cores
Jaskanwar Singh is online now
Old 11-03-2010, 03:45 PM   #4 (permalink)
Originally Posted by Jaskanwar Singh View Post
@ sam
yes u rite but also the unlocking chance of X2 555 is very high. say >95%. but to be on safe side, 630 is a good proccy & it cost 300 bucks less than X2 555 in most places.
Sam is online now
Old 11-03-2010, 05:44 PM   #5 (permalink)
k..guys......
will go for x4 630
but 2 quote,,,,
at my place x4 630 is 400rs costlier the x2 555..........
then wot should i opt against.....another system....
usage:- just data storage and supplier to the network.....(500GB x 3, RAID 5)
AMD x4 955 BE / AMD x2 555 BE (unlocked if it succeeds else stock)
thanx
agel..
Old 11-03-2010, 06:00 PM   #6 (permalink)
Originally Posted by The Day Walker! View Post
k..guys......
will go for x4 630
but 2 quote,,,,
thanx
agel..
i suggest X2 555, it'll surely unlock to X3 B55 (100% surety). unlocking to X4 B55 (90% surety) so i telling overall 95% surety proccy wil unlock.
Sam is online now
Old 11-03-2010, 06:08 PM   #7 (permalink)
pulsar_swift's Avatar
Now tell me one thing, if AMD has failed or disabled 2 core of 955BE and made its X2 555BE, there should be some reason right ? Even if unlocked what would be the life of the processor and impact on its performance ?
pulsar_swift is offline
Old 11-03-2010, 07:31 PM   #8 (permalink)
so u mean,
x4 wont help much in data storage...or both will perform same in data storage system???
thanx
angel
---------- Post added at 02:01 PM ---------- Previous post was at 12:39 PM ----------
@pulsar...
ur rite bro....... but i just needed 2 know....
will quad core help in anything,,,,, when used in a storage pc or will x2 be enough??
as such i m providing it with 3gb ddr3
thanx
angel
Old 11-03-2010, 08:00 PM   #9 (permalink)
quad core will help in photoshop
but since you need your system for storage only x2 will suffice
even a cheaper than 5k processor will just do fine for storage only
Old 11-03-2010, 08:09 PM   #10 (permalink)
AMD - Aaja Meri Darling
AFAIK of two weeks ago, the X4 620 already was below 5k, something like 4.7k ? while the X2 240 was at 2.75k , a 2k difference between a duo and a quad
AMD Athlon II X4 620 | ASUS M4A785TD-V EVO - 785G
Xeno is offline
Old 11-03-2010, 09:47 PM   #11 (permalink)
k guys..thanx
then ill go in 4 555BE if i m lucky then ill b able 2 unlock it..else will run in x2....
thanx
agel
Old 11-03-2010, 10:19 PM   #12 (permalink)
Wise Old Ghoul
Piyush's Avatar
unlocking dual cores to multi cores?!?
is it true that this technique is only possible on some particular mobos?
Piyush is offline
Old 11-03-2010, 11:41 PM   #13 (permalink)
well according to AMD, a mobo having ACC (advanced Clock Calibration) can unlock. but i hav read literally 100s of mobo reviews based on AMD 770G, 780G, 785G, 790GX, 790X (not 790FX, not interested in it). & i can just say is even if a mobo got ACC, it'll unlock cores. 101% sure. but it won't be stable. Asus & Asrock are master of unlocks. they unlock processors & is mostly stable. moreover u may even OC it. but with Biostar, ECS or Foxconn, etc. at most you can unlock. now stability wil depend on specific board & condition of the processor. if proccy too much defective, Asus & Asrock wil unlock it & maybe stable (mayn't be prime95 stable). with other cheap boards you can't boot into windows also.
yup. for data storage. Athlon II X4 240 is enough. & DDR2 based board. no need spend lots on DDR3 + AM3 board.
so u mean,
thanx
angel
well it'll surely benefit from Quad core. but more if the speed of quad is high & add to it a dedicated shared cache, L3. Athlon 630 Vs Phenom X3 B55 (if 4th core fail to unlock), i think X3 B55 wil perform better.
cause of defects.
life wil be normal. no affect on life. just you can't run heavy benchmark like Prime95 torture test or intel burn test. chances are it'll fail. u can run all games on the unlocked processor.
AMD (also intel) quality checking is so high if a processor have even minute problems in its core (GPU also. thats what HD5830 is. defective HD5850. & HD5850 is defective HD5870) its disqualified. so they are again harvested & their defective cores locked. i not know how AMD checks these processors but most of their defect are never visible to customers. just that few processor cores are so badly damaged they can't be stable, ever.
but benefit is, in most X2 processors all 4 cores intact. so can be unlocked. in few one 3 cores can be unlocked. & very slim percentage of processors got both the cores too badly defective.
& to stop this unlocking, AMD taken harsh step. ACC not supported in AMD 880G, 890G & 890FX. its upto board vendors to find a way unlock cores.
Sam is online now
Old 12-03-2010, 10:57 PM   #14 (permalink)
Wise Old Ghoul
Piyush's Avatar
[QUOTE=Sam.Shab;1215069]well according to AMD, a mobo having ACC (advanced Clock Calibration) can unlock. but i hav read literally 100s of mobo reviews based on AMD 770G, 780G, 785G, 790GX, 790X (not 790FX, not interested in it). & i can just say is even if a mobo got ACC, it'll unlock cores. 101% sure. but it won't be stable. Asus & Asrock are master of unlocks. they unlock processors & is mostly stable. moreover u may even OC it. but with Biostar, ECS or Foxconn, etc. at most you can unlock. now stability wil depend on specific board & condition of the processor. if proccy too much defective, Asus & Asrock wil unlock it & maybe stable (mayn't be prime95 stable). with other cheap boards you can't boot into windows also.[QUOTE=Sam.Shab;1215069]
i see.....
do u know any cases of unlocking the cores but no stability or vice versa?
coz it is getting interesting for me
Piyush is offline
Old 13-03-2010, 12:46 AM   #15 (permalink)
tom's hardware did a shootout of 7 785G based mobo few months back. there i not clearly remember but 2-3 board were not able give stable platform whereas rest of the board with same processor was very much stable. i think the processor was 3 core energy saver version of Phenom II. X3 905e or something.
so just board having ACC not enough if it can't make unlocked processor stable. though X4 B55 should be stable as AMD 45nm manufacturing process is improved now with less core defects.
Sam is online now
AMD Launches 6 Core CPU-ready 890GX Chipset Mobo topgear Technology News 7 06-03-2010 05:55 AM
mobo for amd a2 x4 630??? The Day Walker! Hardware Q&A 3 05-03-2010 04:05 PM
AMD to be taken over by Nvidia????? Abheek Technology News 42 02-03-2008 09:18 PM
It's time for AMD to give it up Indyan Technology News 21 19-12-2007 05:50 PM
AMD Athlon™ 64 X2 Dual-Core arrives !!! mohit CPU / Motherboards 2 31-05-2005 12:54 PM
- by c4u
