Old 11-03-2010, 01:21 AM   #1 (permalink)
lalam's Avatar
Default Need help with UPS
Since i do not know much about electronics i can't really be specific and am indeed a bit confuse but anyways i would really appreciate if you could help me in buying a better UPS.
I would just like to know what are the things that i should consider when deciding to buy a UPS?
lalam is offline
Old 11-03-2010, 01:44 AM   #2 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Lightbulb Re: Need help with UPS
Well, first you need to consider your PC's power usage and your desired backup time in case of power cut. If your PC components are power hungry (like quad core processors, graphic cards in SLI etc) and you want to have more than 15 minutes of backup time, then it's a good idea to go for as higher as possible Wattage rating for the UPS. And talking about brands, APC is the best in the market in my opinion.
It would be better if you post your PC hardware configuration and desired backup time.
debsuvra is offline
Old 11-03-2010, 05:01 PM   #3 (permalink)
Point Blanc
Default Re: Need help with UPS
first and foremost your budget and rig(wattage) you are buying.
most of get blinded by APC when we talk about UPS, I would say I am one of them.
I have seen HP 800VA Premium(friend), APC 1100VA(me), and Microtek 1KVA(friend).
all 3 buy were suggested by me.
Microtek one gave probs, HP one havent heard from the fellow recently but I can vouch for it. APC I am blinded cant see anything beyond it , for onething it did not give me probs, and when it showed signs of it I got it replaced under warranty.
My hardware seller stopped selling HP saying there were issues in warranty claims for it. Now I wont repeat what debsurva has said and will wait for your response, as furthur reply waits on that.
acewin is offline
Old 13-03-2010, 12:40 AM   #4 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
to the OP: plz giv me ur config so tat i can suggest u a UPS...
@ Acewin: well so u are regretting tat urs was an APC ups..lol...??
(i hv 2 UPSes) one a 1500VA (980W) pure sine wave ups and the other a 500VA stepped sine wave ups from APC, and both are working gr8,,,,so no complaints here,,,
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 13-03-2010, 02:53 PM   #5 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Exclamation Re: Need help with UPS
I'm also using an APC 500W. And if you take my word, there can be no complaints with APC. Period.
debsuvra is offline
Old 13-03-2010, 03:33 PM   #6 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
The thing about electronics is that you could pick something up where a thousand folks you know have had good experiences but purchase the same thing and end up with a broken unit. That said I have personally used apc and also helped a couple of folks buy some ups for their systems which happen to be apc and they have worked pretty good till date. I have had a good experience. With microtek also.
FilledVoid is offline
Old 13-03-2010, 05:59 PM   #7 (permalink)
Revolution's Avatar
APC Smart Series UPSs are really good.....
Revolution is offline
Old 14-03-2010, 12:16 AM   #8 (permalink)
yeah totall agreed.. lol..
yup, u said the right thing,
yup, apc is really good....
SMART UPS range of APC UPS=Pure sine wave UPS (ideally used for Active PFC type of psu)
BACK UPS range of APC UPS=stepped/modified sine wave UPS
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 14-03-2010, 06:06 AM   #9 (permalink)
Revolution's Avatar
Question Re: Need help with UPS
@ashu888ashu888
u got apc smart series ups.
pls tell me about its price and quality.....
Old 14-03-2010, 12:07 PM   #10 (permalink)
@ revolution: i hv got 2 UPS's from APC (for 2 of my systems...)
1.) APC BACK UPS (Stepped/modified sine wave) 500VA..I hv been using this UPS since 5 yrs and its been working w'out a single glitch, there hv been many voltage fluctuations and this UPS has handled every damn power glitch with ease...i hv NOT even changed the battery and its still working as new...gives me gr8 back up time of 15mins (with a 19" lcd and the then P-4 based system but now an Atom based system)
2.) APC SMART UPS (Pure sine wave) 1500VA,980W..I purchased this pure sine wave UPS for my Core i7 rig (seen in my siggy) in feb 2009 for Rs. 16K as i had Active pfc PSU and also for the reason tat my BACK UPS ups was NOT able to take the load.. its working gr8 too, i hv always trusted this brand and its the best, its damn costly but wen u see ur monster rig, internet and telephone surge all protected adn working gr8, then the price invariably gets justified in 4-5 years...
Cheers n e-peace.....
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 14-03-2010, 02:59 PM   #11 (permalink)
+ for APC, Stay away from local stuff
PraKs is offline
Old 14-03-2010, 03:41 PM   #12 (permalink)
BE FREE
use this link to calculate your need
http://www.apc.com/tools/ups_selector/index.cfm
"To know that we know what we know, and to know that we do not know what we do not know, that is true knowledge." ~ Copernicus
azaad_shri75 is offline
Old 14-03-2010, 05:35 PM   #13 (permalink)
lalam's Avatar
Sorry guys came in to check this rather late and thanks a lot. Bought APC Back-UPS RS 1000VA 230V.
Once again thanks to all who answered, appreciated.
lalam is offline
Old 14-03-2010, 06:12 PM   #14 (permalink)
BE FREE
Congrats, is it 670W one, what did it cost you?
Old 14-03-2010, 11:02 PM   #15 (permalink)
to the OP: Congrats on ur purchase and even more happy tat u got urself a product from APC..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 15-03-2010, 12:15 AM   #16 (permalink)
Tech.Masti's Avatar
Whats the price ?
Tech.Masti is offline
Old 15-03-2010, 05:33 AM   #17 (permalink)
Revolution's Avatar
@ashu888ashu888
Thanks for ur feedback!
Smart series is better but really expensive,at least for me.
I'm planning to buy a Active PFC PSU but have no choice but have to run my PC without any UPS cos I can't afford that UPS.....
Old 17-03-2010, 07:26 PM   #18 (permalink)
yeah, i totally agree with u buddy.. its a huge huge price so im NOT surprised tat u option outta it..
Plz enquire abt other brands selling pure since wave UPS (never operate PC w'out a UPS) its risky and shortens the life of ur components.. hope u will understand..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 17-03-2010, 08:04 PM   #19 (permalink)
GhostRecon's Avatar
APC 650V is good . Bought it a few days back. So far no trouble.
AMD Phenom II X4 925 2.8 GHz | MSI 785GM-E51 | Corsair 2X2 GB 1333MHz DDR3 RAM | Corsair VX550 PSU | BENQ G2220HD 22 inch LCD Monitor | Sapphire Radeon 5770 | Segate 500GB | LG 22X Writer
GhostRecon is offline
Old 17-03-2010, 09:43 PM   #20 (permalink)
@GhostRecon
Does APC gives beeps with damn big sound when light goes off ?
PraKs is offline
Old 17-03-2010, 11:17 PM   #21 (permalink)
@ Ghost recon: congrats on ur purchase, dnt worry, let a year or two pass by and still u wont face any problems with it..
@ praks: well the beep is loud enough to be heard beyond 2 rooms...i mean its clear tone beep...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 18-03-2010, 12:12 PM   #22 (permalink)
GhostRecon's Avatar
Originally Posted by PraKs View Post
@GhostRecon
Yeah that it does.... ......According to FAQ, u can control the frequency via software... never tested though...
http://sturgeon.apcc.com/kbasewb2.ns...9?OpenDocument
@ ashu888ashu888 ..... Thanks mate. And yes APC rules...... bought an old one back in 2002........ 8 yrs of uninterrupted service....
Old 18-03-2010, 09:39 PM   #23 (permalink)
well, even i hv NOT testedthis so called freq setting.. and i guess its available only in the higher (and also more costlier) versions of APC UPSes.. lol...
yup, its a gr8 brand, ppl can never go wrong..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
UPS backup calculation iiamvin Hardware Q&A 3 22-02-2010 10:37 PM
UPS help tarun_don Hardware Q&A 3 31-01-2010 11:52 AM
APC UPS problem prvprv Hardware Q&A 1 28-01-2010 05:08 PM
Is 500V UPS enough? Knight QnA (read only) 35 08-01-2005 07:52 PM
- by c4u
