Hi all,
I currently have a 17 inch CRT and I need to get a 19-20 inch LCD monitor.
My primary use will be gaming and the reason I am not going for bigger screens is that I fear I will lose out on performance while playing games.
My current config is -
2 x 1GB @ 800 MHz Kingston RAM.
Cooler Master 460W PSU.
Gigabyte GA-EP45-UD3L.
C2D E7400 2.8 Ghz.
ZOTAC GTX 260^2
With this config, I can play games like COD4, FarCry2, FIFA 10, Crysis, STALKER, etc with high settings enabled at pretty good fpses. I would need similar performance on the new monitor also. So please consider this while suggesting.
I do not need a widescreen. The aspect ratio should be 4:3
If there are no good/cheap non-widescreen monitors, please suggest a widescreen in the 19-20 inch category.Important factors are build quality and viewing angle.
